Borg 0.7x Super Reducer
3 replies175 views
Robert Huerbsch avatar
Anyone used the super reducer with other brand triplets? Threaded connection to 2.5" focuser, full frame correction and preset markings on barrel for focal length of the scope look great.  But 130mm of backfocus is even more than the Riccardi reducer : (
It would give me two more useful focal lengths of 295mm @ f/4.1 with my GT71 (super wide-field) and 637mm @ f/4.9 with the AT130
For example, SH2-240 requires 4 panels for me to do right now, but I could fit it in 2 panels with the super reducer, and at f/4.1 instead of f4.7 would be able to integrate sooner as well.
http://www.sciencecenter.net/hutech/prices/borgparts/html/7870.htm
Wei-Hao Wang avatar
There are a few things for you to worry.  First, it's an old product.  It may not be available now.  The BORG website no longer lists it.  The two reducers listed on BORG's website are optimized for its current FL series refractors, and they don't have continuously adjustable lenses to match the focal length of many different objective lens.
Second, I am not sure what the 130mm backfocus means.  It may not be what you think.  If you look at the website you mentioned, you see two example configurations listed.  For example, for the DSLR, you need two additional adapters, 7923 and 5005.  Both are very thin.  There isn't too much additional distance between the reducer and a DSLR.
Finally, this reducer (and all other BORG reducers) is optimized for doublets, not triplets.  BORG refractors are doublets, so this is very understandable.  The catch here is, for the same focal length, a doublet and a triplet may have different field curvatures, and therefore different optimal configuration for a reducer or a flattener. The reducer may still work on your triplet, but the required lens position may not be the focal length indicated on the reducer tube.  You may need to try several different positions and find out which one works the best for your triplet.
Good luck.
Helpful Respectful
thanks for your comments! The description reads for triplets, while the 7072 is optimzed for two of their doublets. I was able to source one for an excellent price so will be testing next week  smile
I saw some AB photos with it on Tak scopes and it looked good
Wei-Hao Wang avatar
I think the word triplet on the page means that this reducer has three lenses. It doesn’t mean it is optimized for a triplet objective lens.
Anyway, if you can find one with a good price, it is worth a try.
Focal reducer advice.
Hey guys! I am brand new to Astrobin, and I am addicted! I am also fairly new to astrophotography, so I will be asking all kinds of questions! My first one has to do with focal reducers. I am currently using a Celestron C8N F/5. I just switched from ...
Discusses focal reducers for telescopes, directly addresses field of view widening.
Sep 5, 2018
Barlow/Powermate with Star71
Has anyone tried a Barlow or Powermate on the Star71 for lunar/planetary? I tried a cheap 2x Barlow I have and was not able to focus due to it taking too much back focus. I wonder if a Televue Powermate would be more successful. I also am thinking ab...
Discusses back focus considerations with reducer on focuser, relevant to your setup.
Oct 19, 2016
