I tried to update my PMC-8 firmware and I can't use my mount (iExos-100) any more. Plz help.
1 reply290 views
Cristian Arhip avatar
I started the firmware updating procedure and then my mount (iExos-100) disconnected from the pc. I had the "delete old version before download" option checked and I think that the old firmware was deleted, but the new one hadn't time to be installed. Now the mount isn't connecting anymore to my pc neither using wifi or wired connection. The wifi network simply doesn't show up. I tried to use the universal firmware configurator but with no success. Plz, help.
Gernot Schreider avatar
Please check the forum at https://espmc-eight.groups.io/g/MOUNTS.
There you can connect quickly to the guys from Explore Scientific and they will certainly be able to help you
Gernot
CEM70 Disconnects via USB
Hi All, I've been having a recent issue with my CEM70 dropping connections. I have the CEM70 connected via USB to a mini PC. It is powered by a 12v 5a adapter that is plugged into the wall. (via power brick) I've run this same config for abou...
Mount disconnection issue via USB similar to your WiFi/wired connection problem.
Nov 26, 2023
ASIair Plus - Version 2.1.2 (11.01) Tracking / Guiding Issues with Sky-Watcher EQ6-R Pro
Has anyone else's tracking / guiding stopped working since the firmware update? Yesterday, before I could use the ASIair app, I needed to do a firmware issue. No problem. Then, I did my usual setup, polar alignment, focusing, etc. Everything was ...
Firmware update caused tracking/guiding issues; may have recovery solutions.
Apr 3, 2024
NEQ6-PRO won't connect to laptop
Hi there! I am a beginner and have recently bought a guidescope and guidecam (Touptek - PlanetPro). This camera has a USB B port and one for the St4 autoguide - cable, which connects to the autoguider port on my NEQ6 - pro (old model - not the green ...
Mount won't connect to computer; troubleshooting may apply to your situation.
Feb 3, 2024
