ZWO OAG V2 issue with Skywatcher 2" coma corrector for F5 Newts
4 replies430 views
Andy Wray avatar
Just wanted to highlight an issue I've experienced having just purchased the ZWO OAG V2.  The problem is that the M42 thread on the coma corrector is so long that it hits the mirror stalk on the OAG before it is totally screwed in.  As such, all the tightening pressure is against the stalk rather than the flat face of the OAG. It feels nasty and can't be either good for the mirror stalk or for obtaining a truly flat field.  That said, I have been using it for a few days like that capturing M81 and M82:
M81 and M82 - Early posting ... need much more acquisition time
My solution to the problem was to buy:
* a pack of M48 spacers
* a pack of M42 spacers
* a new female to female 9mm M42x0.75 extension tube to replace the ZWO 11mm one
My train now looks like:
- 2" coma corrector
- 1mm metal spacer (+1mm) Totally fixes the stalk clash issue.
- OAG V2 (+16.5mm)
- 0.5mm metal spacer (+0.5mm)
- 9mm extension tube (female to female) (+9mm)
- ZWO male-to male M42 adapter (+2mm)
- 0.5mm plastic spacer (+0.5mm)
- ZWO 8x1.25" filter wheel (+20mm)
- ZWO ASI1600mm (+6.5mm)
That's a total backfocus of 56mm (an extra 1mm for the filter glass effect)
I went for the 9mm rather than a 10mm extension tube as it gives me the option to tweak the backfocus inwards if I need to.
Just wanted to share as the Skywatcher/ZWO combo is very common and I had not seen it mentioned before.
Fredrik Ödling avatar
Thanks for the information.
I'm also using a f5 (200pds) newt with the 2" skywatcher CC (the 0.9x "short" one) and was looking to get an OAG for next imaging season together with the new ZWO EFW 7x36mm and a 533mm. I didnt pull the trigger on the OAG yet, I'll have to keep this in mind although your solution seems to work fine!
Andy Wray avatar
Fredrik Ödling:
I haven't had a chance to try the new spacer setup yet (clouds ), but because I have 3mm either way of travel on the helical focuser I know that adding the 1mm spacer in front of the OAG can't possibly cause me any problems.
Michael Ring avatar
The same problem exists for Esprit Flatteners, their thread is quite long. My soluion was to put them in my turning machine and to shorten the threads ( a millimeter was enough when I remember correctly..)
The new OAG-L is better, there you have 5mm of threads from the front plate and another 3mm from the prism to the front plate, That's ~3.2 mm more than the old OAG.
Concise
Steven avatar
I'm having issues with this aswel..  On an Esprit, like Michael said.
But because the setup that I'm going to be using, I might not be able to fit spacers in without ruining the backfocus.
So I might have to attack the threads of the flattener. Don't have a turn table though.. might have to attack it with a Dremel, but that's not quite as "precise" as it might need to be
Either way, I'm also having issues with the AOG+Filterwheel combo..
the AOG doesn't quite line up right with the filter wheel, meaning I can't really get my guide camera in the right position.
(using a 290mm, normal one.. not the mini). And again, can't really ad spacers to that one to fix that.
Any suggestions on that? Ideally without the suggestion of ditching this OAG, getting the OAG-L, as that one isn't compatible with the "non-mini" versions of the camera's... But that might be the "better" solution to the issue.
New to SCTs
I'm looking at getting an Edge HD 9.25 in the near future, if they ever get back in stock, and was looking for some advice. I currently have a CEM60 mount and would be imaging with either an ASI1600MM, ASI178MM, or ASI224MC. When I get the scope,...
OAG compatibility issues relevant to your planned Celestron OAG setup.
Sep 29, 2020
