Free C8 with Starizona SCT corrector/reducer? Or save for an Edge HD?
10 replies1.4k views
Dave Ek avatar
I've been imaging for a couple years now, with a fairly short FL refractor (SW Esprit 100 f/5.5), with good results. It's not the best rig for small targets, though, and I've been eyeing the Celestron Edge HD 8" now for a while. However, out of the blue I'm being given a nearly-new C8 OTA with Starbright coatings, and I'm wondering if it would be worth getting a hold of a Starizona corrector/reducer and giving the C8 a try for smaller targets? Is it worth a go, or would I be wasting my money? (The Edge is fairly pricey and hard to find right now, from the looks of it, but then again so is the Starizona reducer.)
Waddayathink? Anyone with first-hand experience with the Starizona reducer and AP? I've been fairly impressed with the Starizona Apex ED-L reducer so far, so that's worth something.
Dave
John Noble avatar
Dave,
I've not tried the Starizona reducer but I have tried the Celestron 0.7 Reducer on the edge and it works well so I'd guess Starizona will be just as good. I'm assuming you are not talking Hyperstar - that's a whole other debate of which I have no experience.
I've just sold my Edge mainly because I wasn't getting any better resolution between it and my refractor and I ran a lot of side by side tests and the seeing was always the limiting factor. Admittedly I was using 660 mm and 930 mm FL on the refractors which is a bit longer than yours.
Bottom line if you have good seeing and guiding you will see a difference between the 8" and your refractor if you don't you wont (assuming 3.7 micron pixels on my ASI 2600)!
I really enjoyed the Edge HD 8 but it's not cheap, and I'm sure you will get equally good images on chips up to APSC size with the C8 just don't expect a step change over the refractor. So I would go with the C8 and see what happens before investing in the Edge.
P.S I'd also say while the Edge is a good scope based on what I see on this site in the images and the forums a good f4 or f5 Newtonian will probably not cost much more than the reducer alone and will meet all your long focal length needs, if your using smaller pixel CMOS cameras.
Lynn K avatar
I have a Edge 8 and a C8.25 & C11.  I only use the Edge 8 for visual.  It allows the use of wide field eyepieces. I do not use it for astrophoto because of the Celestron reducer design.  It doesn't accommodate the use of attached 2" focuser well.  One needs to use the standard mirror shifting focuser.
As for as know there is no difference between the corrector plate, primary and secondary optics in a Edge and standard SCT.  The difference is the placement of a flat field corrector in the baffle tube.  The optics of  Edge scopes seem to be better   centered.  That is necessary for performance of the baffle flattener.
A starizona SCT reducer/flattener accomplishes the same results as the Edge Flattener, but the Starizona also reduces the focal length and can be use easily with a 2" focuser.  I use the older SCT F7.5 version with my C9.25.  I have also use it with the the C11.  I primarily use the C11 for Hyperstar.  I have never use the Starizona reducer/flattener  with a APS-c size chip which it should accomidate.
In order to get the best performance out of the C8, you may need to re-center the Secondary/Corrector.  Since the C8 is a spherical optical system, it can function well even if the secondary is not perfectly centered. So, Celeston dose an OK jobe.  The Edge flattenter requies better centering. I have recentered all my SCTs.  Starizona has instructions.
I live in a Bortle 7 area and have to do mainly narrow band.  So, Galaxies are pretty much out.   I prefer a wide field refractor and use a Tak FSQ106ED at F3.64 and AP130GTX at F4.5.  I only use the C9.25 at a dark site for galaxies.   I use a Feather Touch 2" focuser with the Optec/Starlight Boss system.
Lynn K.
rhedden avatar
I have an old C8 (Starbright) with an 0.63x reducer, an 1100 EdgeHD, and an Esprit 100ED, so I can comment on all of the above.
Old C8 with reducer: not designed for photography; field is not flat; stars are seagull-shaped in the corners.  Put it in the basement and use it for visual.  Why anyone would consider this system to be an upgrade over an Esprit 100ED is a mystery to me.
1100EdgeHD: works great with the reducer for a small sensor.  Will make the Esprit look like a toy when you first put it onto a smaller galaxy, but just wait until you try to process the LRGB data.  The stars will be "soft" in LRGB because it is not apochromatic like the Esprit.   Ugly LRGB stars are a problem I have not fixed in 10 years of owning the scope, except with narrowband filters.  Having a lot of trouble here with an APS-C sensor due to chromatic aberrations and distorted stars around the edges.  I am going to try it again at f/10 and the APS-C sensor without the reducer, but do you want to image at f/10?  Requires a heavy-duty mount with excellent tracking, or you can kiss the higher resolution goodbye.  Will obliterate planetary nebulae in narrowband, and you will be very happy - but not a great galaxy scope compared to f/4 imaging Newts, RCs, Dall-Kirkhams, etc.
Esprit 100ED:  Nice star shapes and colors, but stars are actually larger (at the same image scale) compared to the EdgeHD due to the small aperture.  Can be set up with autofocuser more easily.  Vignetting is not a problem with APS-C.  No chromatic aberrations whatsoever.  Takes longer to image small galaxies, and you may want to use 2x drizzle to get a smaller image scale like I do.  Field of view is huge, so you can potentially image multiple galaxies at the same time.
This spring, I have been imaging some very small galaxies with the Esprit 100ED at the native 550 mm focal length.  The tricks are 2x drizzle to get 0.7" per pixel, and using Starnet++ to remove and shrink the bloated stars.  These galaxies are really small - and what's wrong with these results?
Nice galaxy, ugly LRGB stars with the 1100 EdgeHD and the 0.7x reducer:
Tiny narrowband stars with the exact same system:
Helpful Insightful
Dave Ek avatar
Lynn K:
Lynn K.
I'm in Bortle 4 and at 8400 feet elevation so seeing isn't terrible here. The camera I use is probably not the best choice for 2000mm FL (because of the 3.7 micron pixels) but is probably not so bad with the Starizona 0.63x corrector..
Dave Ek avatar
1100EdgeHD: works great for a small sensor.  Will make the Esprit look like a toy when you first put it onto a smaller galaxy, but just wait until you try to process the LRGB data.  The stars will be "soft" in LRGB because it is not apochromatic like the Esprit.   Ugly LRGB stars are a problem I have not fixed in 10 years of owning the scope, except with narrowband filters.  Having a lot of trouble here with an APS-C sensor due to chromatic aberrations and distorted stars around the edges.  I am going to try it again at f/10 and the APS-C sensor without the reducer, but do you want to image at f/10?  Requires a heavy-duty mount with excellent tracking, or you can kiss the higher resolution goodbye.  Will obliterate planetary nebulae in narrowband, and you will be very happy - but not a great galaxy scope compared to f/4 imaging Newts, RCs, Dall-Kirkhams, etc.
I wouldn't go so far as to say that any SCT would be an *upgrade* over the Esprit 100. I love my Esprit 100, but its wheelhouse is not shooting the small stuff. I have a C6 right now with the Celestron 0.63x reducer, and the Celestron reducer is really not good for AP use, which is why I'm considering the Starizona corrector, which people seem to think highly of.
Well written Insightful Respectful Concise
rhedden avatar
My advice: go get a 10" or 12" f/4 imaging Newt and never look back.
The older non-EdgeHD C8 is the problem itself, not the reducers.  These telescopes do not have flat fields, and they were not designed to be astrographs.
Well written Insightful Concise
alexbb avatar
I kept this topic opened as I haven't completed the image until a couple of days ago.
My SCT is a Celestron C9.25, not a C8, but the Starizona reducer/corrector does a much better job than the Celestron reducer/corrector.
Check this image for star shape: https://www.astrobin.com/58ifv6/
It was a bit cropped and reduced to a pixel scale of ~1 arcsec/pixel.
You can ignore the C6 + Celestron reducer/corrector contribution to the image, I used it mostly as a test for iR, but it wasn't too different than the R channel and it only contributed starless.
AwesomeAstro avatar
Yeah although I've used it on the 8se and not the C8, I can also vouch for the Starizona corrector being not just slightly, but significantly better than all others (celestron, antares, meade). It has enough internal optical elements to not only correct the coma to essentially perfection, but also to prevent ghosting from reflections off of the camera sensor back to the glass, and back to the sensor again. This produces a substantially cleaner field in terms of gradients, and helps the flat frame calibration work much better.
I genuinely don't know if this will behave the same way on the C8, but I can't stress enough that it perfectly corrects abundant coma in my 8se; if it's intended to also be used on the C8, you will get a killer scope with a very flat field and great low gradients. See a detailed review for it on my site here.
As for the 8" EdgeHD, this scope kicks butt and has a perfectly flat field. It's much more expensive (I was lucky to get it at a steep discount second hand, or else I wouldn't have one), but it does its job. Here's the kick though, it depends on if you want to focal reduce your 8" SCT or not! The EdgeHD is great natively, but the focal reducer built for it (which cannot be the starizona one) also has gradient problems, just like the lower quality reducers did on the 8se, so I don't use the EdgeHD when I want to lower the focal length. I still have the 8se with the starizona corrector too, and I use this setup for lower focal lengths! It produces EdgeHD-quality results at the lower focal length (no coma, flat field, etc.).
This applies to you, because if you want to focal reduce it, don't bother with the EdgeHD! Just use the starizona on your free tube, assuming it's compatible with the C8. Truthfully I imagine it is.
Dave Ek avatar
Great to know! I'm going with the Starizona reducer (if it's ever back in stock). Thanks for sharing your experience with it.
Well written
AwesomeAstro avatar
Dave Ek:
Sure thing! With good flats you will like its performance. Maybe you can find one used too!
C8, Baader focuser and a Starizona SCT corrector
I own an old Orange tube Celestron C8. It's in excellent (like new) shape with good clean optics capable of some well defined sharp DSOs. I know that some of you may say,"Just order a Celestron Edge HD and be done with it." $2000 for th...
Direct experience with C8 and Starizona corrector for DSO imaging.
Nov 5, 2023
Need Help w/C8 - OAG & Starizona Corrector
To give a little background, I’ve been imaging now for about 3 years and have often used my C8/CGEMII with a 60mm guide scope with no real problems. I’ve often been warned about differential flexure and that an OAG was ideal for this focal length, wh...
Specific advice on C8 with Starizona corrector setup for imaging.
Apr 16, 2024
Will it ever end?
Tube sizes, thread sizes, backfocus, pixel size… I finally unboxed my edge hd 8, installed the 0.7 reducer, the celestron oag (sooooo much better than the zwo one). Next was the 11mm celestron extension. Which is knurled. Why isn’t every extension tu...
EdgeHD 8 with reducer experience, relevant optical configuration discussion.
Oct 24, 2023
C8 Edge HD for galaxies and DSO's vs 120 mm apo
Hello to all, I typically use my 70mm apo for astro work - its my only AP scope and I have been gathering images for about 8 months. I have about 6 months of guiding under my belt, and the rig works fine. My rig - Mount: NEQ6 Camera: Canon 60D and a ...
Discusses C8 Edge HD reducer option directly relevant to author's purchase consideration.
Jan 29, 2021
