Andy Wray:
Jean-Baptiste:
Look at the stars shape, take a lot for example at the open cluster of CCDMike , the stars have a regular round shape
sorry I am in the transport with am iPad, not easy to bring out the details with copy paste of images :-)
Here's my latest image (corners and centre) .. What do you see? I do see some tracking issues, but there may be some collimation issues also?
In my opinion, things are quite simple if you take a few subs and look at the stars, comparing how they look.
- Collimation/alignment issues result in non-uniform stars. E.g. stars will be wider at the bottom right of the sub. There is a change if you rotate the camera (the place where stars get wider will follow the rotation).
- Tracking/guiding issues result in elongated stars, along the same axis: all your stars will be
0-shaped. They also get worse with longer exposures.
- Correction issue tend to be radially symmetric. If stars are smaller at the center and wider as you go towards the edges of the field (all edges), then you have a correction issue. Wrong distancing, perhaps the sensor is too wide for the corrector, perhaps the corrector just isn't good.
- If the stars have strange shapes but consistently so (let's say every star is shaped like a triangle, all triangles pointing the same way, or let's say the color blue is not aligned to the other colors) then you have a build/optics problem.
- Anything else is usually an accident. E.g. extra diffraction spikes typically mean some cable got in the way.
In the picture that you show you have a clear (but mild) tracking issue because all stars (including central ones) are slightly elongated along the same axis (like a / ). There is perhaps a very small alignment issue because to me at least the bottom-right corner looks slightly better than the others. But it is even milder, too mild to bother in my opinion. Mind you, it does not have to be collimation. It could be e.g. a tiny tilt of the focuser due to weight or even of the camera sensor from its construction. I would not worry about it. Best to focus on the tracking/guiding if you want to see a visible impact on your images (again: personally I wouldn't worry about that either, I think it's too mild to bother. And it is not necessary to change anything physically. Perhaps just take slightly shorter subs or reject a little more aggressively).
Regarding the original question, I must note that even though my F/5 holds collimation excellently, aligning the secondary was quite a nightmare and I had to try it three times (several hours every time) to get right. What helped me was the concentric circles collimation eyepiece.
Dimitris
