I've just processed a session in Astro Pixel Processor, but despite calibrating with flats, I still ended up with a HUGE gradient. Any ideas as to why?
Here is the stacked result and the master flat
Stuart Taylor:
Bernhard Suntinger:
What camera do you use?
A ZWO ASI2600MCpro? When yes ->Have you bought the camera in 2021/2022?
Have a look at this forum thread: https://www.astrobin.com/forum/c/astrophotography/other/asi-2600-mc-pro-bright-white-circle-in-subs/
Bernhard Suntinger:
Can you send me your light frames?
I´ll have a look at them...
I had a similar problem with a 135mm f2 lens.
What is the exposure time of your flats? There is an interesting series of videos by Adam Block where he deals with overcorrections of flats happening. He mentions that also undercorrections (as in my and probably your case) may occur and he claims that very short exposure times for flat files with CMOS sensors may introduce such errors. Adam recommends that exposure times for flat files should be well above one second to avoid potential issues.
For details watch these videos:
Do Your CMOS Images Look like THIS?? (Part 1) - YouTube
Do Your CMOS Images Look like THIS?? (Part 2) - YouTube
Do Your CMOS Images Look like THIS?? (Part 3) - YouTube
Good luck and clear skies
Wolfgang
Stuart Taylor:Bernhard Suntinger:
I can't seem to find a personal message function in Astrobin. Is there a way I can send you a link to my lights?
Stuart Taylor:
this is interesting. I did not know this. However, I just checked my flats and the exposure time was 2.63s (I try to keep the brightness of my flats panel low-ish). But this is useful to know! Thanks
andrea tasselli:Stuart Taylor:
Not sure it's true. My flats are significantly shorter than 1s and never had the issue. The issue is in the use of flat panels.
I would be reluctant to challenge Adam Blocks statements. He did not claim that the problem must occur for any Camera/lens combination. The statement is that it can occur.
Clear skies
Wolfgang
Bernhard Suntinger:
These are your stakked images (without flat correction).
Björn Hoffmann:
I recently ran into a similar problem with APP and the reason was kind of surprising. When I took the flats (and darkflats) after the session I forgot to give APP the filter information. Thus, the fits header was not containing my l-enhance filter. When loading lights and flats in APP, it notices this information and does not assign those flats to the lights automatically, because it seems to not be a match from the fits header. So you have to choose "use for all channels" in the pop-up window when loading your flats and all other correction frames.
Torben van Hees:
I can also do that if you give me access to the data.
Stuart Taylor:
This is interesting. But I don't think it would apply to my situation because I am shooting with OSC and a L Pro filter (which was kept on for flats also). So all stacking calibration etc was with exactly the same optical train.
Björn Hoffmann:
You take your lights with the L-Pro. Then this information will be stored in the fits header.
Andy Wray:
Just to confirm what Torben has said .. that is definitely the problem. I found the same issues of size discrepencies and bayer matrix incompatibilities looking at your master light and flat that you uploaded. The flat shows up as a grayscale 8 bit 6248x4176, the light shows up as a 24 bit RGB 3146x2165.
Ken Rockelein:
I'm having a similar issue with my new setup right now as well. It's an AstroTech 115 triplet with the ASI294mono camera
Connor Kessler:
I also have the 294MM as well as the 294MC. In case you haven't tried this yet, I have found that the 294MM (and MC) really, really don't play nice with short exposure calibration frames, especially when trying to calibrate flats/darks etc with bias.
