RGB Filter question - Baader vs Astronomik DeepSky
MarcTareq Abdullabobzeq25
27 replies1.9k views
Marc avatar
first off, I am almost certain this must have been asked before, but wasn't able to dig up a thread. Apologies!
I am about to pull the trigger on a QHY163m + QHY 7-slot filter wheel in combination with my 4" TS Triplet APO and 3" Reducer/flattener.
I have now to decide which LRGB Filter(s) to buy and am torn between:
Baader LRGB and Astronomik DeepSky RGB + L2
I did a bunch of searching on the interwebs, but there seems to be no clear recommendation one way or the other. Astronomik had somewhat mixed reviews in the past (2011ish), but seems to have improved a lot in the past year or two. Baader on the other hand has consistently produced good filters, but are not marketed quite as "top notch high end" as the DeepSky Set from Astronomik.
The way I see it:
Baader seems cheaper and narrow band filters in particular are a lot cheaper than the Astronomik ones (Baader 7nm Ha = 150€, Astronomik Ha 6nm = 280€). But they are twice as thick (i.e. add around 1mm to my working distances after the reducer) and may or may not produce halos around brighter stars. Baader filters have also been reported to not be fully parfocal, which would be annoying of course when running exposure series.
Astronomik are more expensive, but marketed as reflection free, super resistant and are thin enough to not matter as far as my working distances are concerned (not an issue one way or the other, really). Astronimik filters are also said to be fully parfocal.
So..what do do?! Any experiences that could help me decide? The price difference for the LRGB Set really isn't the issue, but it starts adding up when considering NB filters (which I want from the same manufacturers  for focusing purposes). Leaning towards Astronomik - assuming the criticism of Baader filters is in fact warranted. But wouldn't mind saving a few hundred bucks if the Baader filters would give me similar results.
Marc
Respectful Engaging
Die Launische Diva avatar
Hello Marc,
I have no experience on the subject but maybe this LRGB filter test be helpful.
HTH and Clear Skies!
Marc avatar
Thanks, I also stumbled across Tommy's little review/test. His images seem to support the idea that Astronomik has a bit of an edge over Baader (stars look a bit tighter to me), but that both brands will produce some degree of artifacts; this seems unavoidable.
Well written
Caspar Schumann avatar
Marc, take a look at my Pictures, i only  take Photographs with Astronomik- Filters. CS Caspar
Tareq Abdulla avatar
Marc, did you buy or decide on which RGB filters yet?
I have an option for you if you still look for one.
Marc avatar
yes I went with the Baader ones but haven't had time to test them yet. i've been told that the halo and reflection issues are very much dependent on the imaging system - no way of telling beforehand how it will work out. Some people have had zero problems with Baader filters, others did - sometimes with only one color channel, or a particular NB filter. But the same is true for Astronomik.
So I am hoping that I won't run into problems smile Will update this thread once I had the chance to take a few subs..
/M
Great, congratulations then!  smile
Marc avatar
Maybe as a small update since I haven't had too much time to test them yet (awful streak of bad weather here):
10mins Ha exposures - little to no problem (minor artefact around very bright stars, see my gallery for example)
LRGB Galaxy imaging - no issues at all, looking good (nothing to show yet, need more integration time)
LRGB imaging of bright stars - well, this is where we get into some problems. Tried the Pleijades the other night and am getting very noticable reflections on the blue channel. This is likely an issue with my imaging system overall and not specifically with the filters (triplet apo + multi-lens flattener/reducer). Some things I can try, like flipping the B filter over (recommended by Baader in such instances). Or stay clear of very bight stars (less ideal, but of course an option, plenty of objects left still)
Congratulations!
I tested mine and sounds it is doing fine, i am talking about LRGB only, i don't have NB set yet, and my Astrodon Ha 5nm 1.25" is definitely a top quality no doubt.
Marc avatar
Here are a couple of things I have learned in the meantime:
I had to fashion small black card board rings (width about 1.5mm)  to put on top of the filter to cover the edge of the glass. It seems that the multi-coating does not stretch all the way to the edge, which can produce unwanted reflections inside the filter when taking flats. Cost me grant total of 15 bucks, but debugging the issue resulted in more than a few grey hairs.
I have since added the Baader UHC-S filter to deal with skyglow in my area. The background really benefits from this and the filter produce stighter stars than the normal L filter, but it also results in "nasty" halos around even moderately bright stars.
bobzeq25 avatar
Marc:
Here are a couple of things I have learned in the meantime:I had to fashion small black card board rings (width about 1.5mm)  to put on top of the filter to cover the edge of the glass. It seems that the multi-coating does not stretch all the way to the edge, which can produce unwanted reflections inside the filter when taking flats. Cost me grant total of 15 bucks, but debugging the issue resulted in more than a few grey hairs.
I use the milder Baader Neodymium for this, halos haven't been a problem.
https://www.astrobin.com/333099/?nc=user
Robert Huerbsch avatar
I would get the DeepSky RGB and Astrodon for narrowband… I have the Deepsky filters
Marc avatar
That would probably be my recommendation as well, in hindsight. The price is a bit higher, but I have at least not heard of any such issues. That said, for LRGB I am mostly happy (color representation etc looks good), but I had to put in some effort to make them work in my setup. People's mileage may/will vary, I suppose.
Marc avatar
And another update -
ended up selling the Baader Filters. The price is unbeatable to be sure, but it comes with certain sacrifices in my experience. I was getting pretty severe halos especially on the OIII filter (see my image of the North America Nebula for an example), but also the blue channel. I was never quite able to tell for sure how much this was due to my imaging train or the filters. I also disliked that the filters did not come with blackened edges or a plastic ring to make handling easier, and togive you any chance of knowing which filter was which just from looking at them smile And lastly, for some reason Baader decided to make one side of each filter highly reflective, almost mirror-like. I am sure there is a reason behind it, but I also fail to see how this is going to work in certain imaging trains - like refractors with reducers. It just screams "problem" to me.
Anyway, I now did what I probably should have done in the first place - buy Astronomik filters (UHC, Deepsky RGB and Ha 6nm for now). Out of the box these make a very good impression, no weird reflective surfaces, nice protective (and labelled!) rings. Fit in my filter wheel without problems and my first tests look promising so far.
Marc
Roman Pearah avatar
I'm thinking of going with Astronomik across the board as well, but I'm a bit stuck on what to get for the Luminance filter (when not just using Ha for that). Their site suggests the Deep-Sky RGB set should be paired with the L1, L2, or L3, but possibly the CLS-CCD if you live in high light pollution. I'm not sure what constitutes "high" but I can say that I live in Bortle 4 verging on 5 plus a lot of close street/security lamps where I set up in my driveway (probably enough to make it a solid 5 effectively). They also say that the L3 is designed to work with the Deep-Sky to minimize halos. I'm thinking the L3 is right for me given that I'd probably want at least the L2 for having corrective optics in the chain and because I'm working with a short focal length. I'm curious why you went with the UHC, which I hadn't even been considering as it's classed as a "visual" filter.
My equipment for context: AT72EDII (72mm APO refractor) + 0.8x reducer/flattener + OAG + EFW (1.25) + ASI1600MM Pro.
Marc avatar
I am in a bortle 4 zone as well and find that the CLS filter gives very good results. The background separation at least feels more easy during processing.
bobzeq25 avatar
I'm Bortle 7, use (with Deepsky RGB) either the L2 or a Baader neodymium.   On emission nebulae, Ha , sometimes O(III) also.
The CLS cuts out too much signal for me, particularly on targets other than emission nebulae.  On emission nebulae, I think narrowband is far more effective.
Bottom line.  A CLS gathers dust on my shelf.  <smile>
Jarrett Trezzo avatar
Definitely agree with Bob. I never recommend any kind of light pollution filter in something like a Bortle 4 (that's considered basically as a dark site in my book). A UHC is very extreme too, having two wide bandpasses only around OIII/H-beta and H-alpha, so I'm perplexed by that choice as well.
I'm in Bortle 5 verging on Bortle 6 and only use standard Luminance filters and the gradients are pretty easy to clean up with the right tools. In my opinion you only lose by using strong LP filters like the CLS in anything lower than a Bortle 7. Even when I lived in Bortle 7, I had good results with just the Luminance filter too, just needed a lot of time.
Roman Pearah avatar
Very helpful, thanks. Sounds like I should stick to the L3 plan.
Well written
I am still thinking about which RGB filters set i should buy, give me votes or recommendations.
Miguel G. avatar
Hi there!
This is a rather old post but I'm also interested in more feedback about these filters.
Cheers
Well written
bobzeq25 avatar
I'm sticking with what I said in my two posts, after a lot more experience.
For RGB, the Astronomik Deep Sky.  For L, one of the Astronomik L filterss, or the Baader neodymium.
Note that Marc spent some time with the Baaders, didn't like the results, sold them, bought Deep Sky, and is now happy.  I don't think that's an idiosyncratic response.
Peter Maasewerd (pete_xl) avatar
In case you use a refractor I would strongly recommend to use L and B filters that open way above 400nn. Changing from Baader CCD L and Blue to Astronomik Deep Sky Blue and L3 significantly improved the FHWM values and star colors with my 130/910 and 80/480 apos.
Marc avatar
I am still happy with my Astronomik filters - although I was never able to really figure out what made the Baader filters behave so poorly in my imaging train.
Baader has since revised their filters and now advertises a new version specifically optimized for CMOS sensors. And many people are getting good results with Baader - so I would not count them out. They are certainly cheaper than Astronomik… but my personal experience in the hobby has been (several times…smile that trying to cut corners/costs always came back to bite me in the behind smile
Ruediger avatar
Marc:
Baader has since revised their filters and now advertises a new version specifically optimized for CMOS sensors. And many people are getting good results with Baader - so I would not count them out. They are certainly cheaper than Astronomik... but my personal experience in the hobby has been (several times...) that trying to cut corners/costs always came back to bite me in the behind ;)
Hi Marc,
I have the new LRGB an NB 4nm Baader CMOS filters. Meanwhile they are at the same price range. e.g. LRGB Baader 50,4mm: 545,00EUR, Astronomik LRGB 50mm: 579,00 EUR.
I think it is still too early to really give an statement about the new CMOS types. I have replaced all my old Baader filters with the new ones, but I did not notice a significant change, which was quite disappointing to me. Normally I am a huge fan of Baader products since they are really good, but about the filters I have mixed emotions. I consider them as solid mid range class filters, but there is still a gap to the best ones.
Rüdiger
More ZWO filter questions
I see now that ZWO has a 7 position filter wheel and OPT is offering a complete filter set combo with camera and filter wheel. THe NB filters are stated by OPT to be 7nm bandpass. My question is newbie, ie, what are they referring to and is it only N...
Discusses filter selection and comparison between manufacturers for astronomy.
Jan 14, 2017
Recommendation of 31mm NB filters for the ZWO mini filter wheel and ASI 1600 MM Cool
Hi, My camera and filter wheel are on order but I need to decide on Narrow Band Filters. My scope is a Borg 125SD ar f3.9, so I need to us the 31mm unmounted option. I only know that 31mm NB filters are made by Astronomik at 6nm and Chroma at 3nm. Th...
Discusses Astronomik filters; relevant for comparing narrow band filter options.
Sep 19, 2016
About to pull the trigger - few quick questions
Hi everyone, I have been thinking about upgrading from a DSLR to a cooled cam, with my budget restricting me to either a system based on the KAF8300 or indeed the ASI1600MM-C. I would use this with a 102/714mm triplet APO (TS) and a 0.79 3" redu...
Discusses filter options relevant to cooled camera imaging setup considerations.
Mar 9, 2017
Light pollution filter - which way is better?
Hello to anyone who would have an opinion.. I am wanting to buy an Astronomik light pollution filter for use with a CCD refractor and CCD SCT LRGB setup. Should I get one to replace my L filter when shooting or should I get one to go forward of the f...
Discusses Astronomik filters for LRGB astrophotography setups with CCD cameras.
Apr 10, 2018
Imaging comets via LRGB-NB
Hi, so next month a comet will come to say hello and I was wondering if anyone has some insights into how to image a comet using LRGB and possibly NB imaging through my F5.5 APO. I understand that, with OSC cameras, one would do images in intervals a...
RGB Filter question - Baader vs Astronomik DeepSky — relevant to LRGB filter selection for comet imaging.
Nov 9, 2018
