Jim Brown avatar
Hi All,
Anyone out there doing narrowband? I'm messing around with colors, but haven't really found a combination of Ha, SII, OIII  I like yet.
Thanks,
Jim
pfile avatar
yep. i usually just do straight SHO and then fix the colors to look like the 'blue' hubble palette. but i guess that only works if there is enough SII and OIII in the target.
rob
jeff avatar
I'm starting to look at it.
Juan Conejero via Rob Morse suggestion:
·       OIII = Blue Channel
·       Ha*0.2+OIII*0.8 = Green Channel
·       SII*0.8+Ha*0.2 = Red Channel
(Juan Conejero calls this a more ‘natural’ representation; note healso says that if saturation is not an issue, then instead consider SII +
0.8*Ha for Red, 0.2*Ha + OIII for Green and pure OIII for Blue).  Note I have seen others who use different
mixes, such as mixing 50/50 SII and Ha to create the Red Channel, 85/15 OIII
and Ha for Green, and 100% OIII for Blue.
also have seen on PI forum..I need to find the post to remember who authored it..it was in response to someone named Brad:
Forum poster's text:
"... but you can just use PixelMath to do the percentage blends to get a better/proper Hubble mapping that isn't so heavily
green weighted. I think its the following":
R/K: 0.4*Ha + 0.6*SII
G: 0.4*OIII + 0.3*Ha + 0.3*SII
B: 1.0*OIII
"This is another I saved off from this site a while ago, for a natural color blend":
R/K: 0.76*Ha + 0.24*SII
G: 1.0*OIII
B: 0.85*OIII + 0.15*Ha
jeff
Jerry Yesavage avatar
If you use PI and want an interesting recipe, maybe try Rick Stevenson's ColorMask script:
https://pixinsight.com/forum/index.php?topic=7751.0
Jim Brown avatar
Yes, I use PI. Thanks for the tips! I am going to try that ColorMask script.
pfile avatar
what jerry pointed to is the only narrowband flow i ever use for SHO. other people talk about color balancing or mixing to get the hubble palette but to me rick's method is the most straightforward.
rob
Jarrett Trezzo avatar
I feel like Cocoon is just not a good narrowband target, it's more of an LRGB. You got all that broadband dust and reflection.
Jim Brown avatar
Thanks Jarrett, that sounds like part of the problem I'm having. Do you have a suggestions for a good narrowband target?
Thanks
Jim
snakagawa avatar
I agree with Jarrett. I could not get good colors with Cocoon either (Astrodon 5nm filters). OSC images looked much better. You could use NB images to produce L frames so that you can reduce the stars in the background. Although, you may still want to use non-NB frames if you want to bring out the dust lanes.
There are plenty of easy (bright) and good-looking NB targets. How about Veil Nebs, Heart & Soul, Elephant's Trunk? They are rich in colors (the three main NBs).
I am shooting a bit more obscure and difficult (faint) large planetaries these days with NB.
Seiji
Jim Brown avatar
Thank you for the suggestions. I am trying Veil tonight and the next few days.
Jim
Processing Veil Bicolor in Pixinsight
Hello everyone! I've found myself stuck with processing yet again and wanted to ask cor a consensus view on some steps to take to get the result I'm looking for. I've collected about 2 hours each of the Veil Nebula in widefield using Ha, ...
Processing Veil Bicolor in Pixinsight — discusses narrowband color processing techniques relevant to author's work.
Jun 4, 2018
Mosaics
Hi Folks, I'm just starting out on my first mosaic, and looking for suggestions, tips & tricks on the process to make tricolour NB images of large objects. I tried Photomerge in PS 2017 but it aligned my 3 NB file sets out of register. Then I...
Mosaics — mentions tricolour NB images combining Ha, SII, OIII filters author is exploring.
Feb 13, 2017
Is the OPT Triad Narrowband Filter worth it?
I was thinking about trying the OPT Triad filter with my SX color cameras on my C11" SCT. I noticed some great images here but before I pull the trigger to get one, I am curious to get feedback by users. I'm in the suburbs of Orlando with Bo...
Is the OPT Triad Narrowband Filter worth it? — directly addresses narrowband filter equipment and results.
Feb 13, 2019
