Need Help -- Irregular Flare Pattern on Brighter Objects
2 replies64 views
Max Hamm avatar
Here is a pic of M13 I took with my Meade LX70 R8 8" Reflector and I've noticed not only in this picture but any photo I take with that scope there are odd, irregular flare patterns on the brighter objects. Can anyone tell me what's wrong with my scope that's creating this odd flaring? I know it's not tube heat because I had the scope out for several hours beforehand. The collimation is spot on so I know it's not that. I know it's not my DSLR camera because I can use the same camera on my Celestron Omni XLT150 Reflector and the flare pattern is normal.   If anyone knows what's causing this, please help.
opse3141 avatar
Hello,
The flare patterns on the bright star is maily because of "scattered light". Please check bolts or nuts inside the tube. Black pen, black paper,or black tape (non reflecting) is recommended. Check reflecting materials(mailny metal) near spider, secondary mirror support, focuser attachment. Primary mirror cell 3 craw can scatter the light. In that case, you should make ring cover over the 3 craw like this.
Richard M.
Max Hamm avatar
Thanks for the insight Richard.  I think it's the shinny aluminum from my focuser tube because at focus the focuser tube sticks out about 1/4" into the main tube.
Hello from Barcelona
Hi there! I've been into astronomy since the mid '90s , but with a huge parentesis till 2015. When I was doing Astronomy in the 90's all that I wanted is to get a real motorized EQ mount, a film SLR camera, remote shutter and a 80mm long ...
Irrelevant; introductory post unrelated to optical flaring or telescope issues.
Aug 20, 2019
