Screen door pattern
6 replies545 views
Warren avatar
What is the cause of the “screendoor pattern” seen in post-processed images?  It looks like xs noise in the nebular gas.
thanks warren
John Hayes avatar
Warren,
I think that you are referring to the problem often seen with NB data.  When you work with faint NB data, the signal level of the background can be quite low (particularly during new moon.) That means that when you do the flat correction, some pixels may be driven to have zero or negative values (after subtracting bias,) which PI clamps to zero. This can be caused by old bias data that may not provide sufficient offset to avoid having the data to cross into negative values when the flat correction calculation is done. Those zero values cause problems with the PI interpolation algorithm when you register the images. You'll know that you've run into this issue when you see a Moire pattern in the registered data. The problem is worse for images that require rotation and it looks like a 2D semi-rectangular or circular Moire pattern. The frequency of the Moire varies with the amount of rotation required. More rotation produces a higher spatial frequency pattern.
The fix for the problem is to add an offset to the calibrated data. If you look at the calibration dialog in PI, you'll see an option for "Output pedestal (DN)" under the "Output Files" tab. That's what that option does and that's why it's there. In this case, I had to add an additional 30 DN offset to the O3 and S2 signals to avoid this problem. Getting the offset adjusted to remove the zero pixel values completely fixes the problem. Just be sure to check the box to subtract the offsets when you stack the results. On possible side effect is that with an offset, the low-level statistical stacking filter can be affected and you may not reject data that would normally be tossed out. That may cause another side effect that seems to affect how local normalization data is computed. In that case, it may produce a very mottled background. Simply reverting to "additive with scaling" should solved that issue.
Well written Helpful Insightful Engaging Supportive
Warren avatar
Thank you John,   I am too new to astroimaging  to understand your explanation.  Also, I am probably not explaining what I am seeing in my images very well.  They just look real grainy, noisy.  I was told that what I see is not noi8se but the "screen door" effect.   My ngc7000 shows what I see as grainy in the gas if you zoom in. https://astrob.in/w9mh4o/0/
Warren
It's just noise. Post-processing doesn't seem ideal but that isn't the issue.
Lorenzo Siciliano avatar
Hi Warren.
If I spotted the issue correctly, it looks like a side effect of the algorithm used for the noise reduction or it could be an artifact of the jpeg compression.
Ciao.
Lorenzo
Well written Concise
David Redwine avatar
This looks like normal color noise from an unmodified OSC camera.  I checked your Rosette image and Topaz denoise did a good job cleaning it up.  If you don't have Topaz you can apply a 3 pixel  Gaussian blur followed a 2X down sample.  The level of your color noise seems to be too much for Photoshop's color noise reduction tool.
More subs will help reduce the problem in the future.
I will send you a PM with my Topaz results.
Warren avatar
Thanks David, for your suggestions. I dont have topaz so I’ll try gaussian blur & 2x.
Whats causes these distortions?
I am new to deeper imaging and like many am using itelescope as a learning tool. Live in LA and trips out to dark area are not frequent. So great way to fill in between. While I make decisions on what nicer rig to build myself. I am curious as what c...
Discusses distortions in post-processed images from deep imaging work.
Sep 29, 2023
Checkerboard pattern after stacking and star removal?
Hi all, This morning I stacked together some WIP data collected so far just to see how it's looking. No processing other than: - 45x300sec stacked with darks only (no flats, dark flats) Stacking with WBPP and in DSS produces the same result - Dyn...
Addresses checkerboard pattern artifact after stacking and processing steps.
Oct 24, 2023
Comet stacking - Need some help with noise
I'm currently processing some new comet data of 12P/Pons-Brooks that I got but I'm struggling with what comes out as walking noise in the comet stacks. This is a comparison to show what I mean. To the left is the current image (one starless c...
Covers noise issues in post-processed astronomical image data.
Feb 9, 2024
Aliasing pattern?
Hello everybody, hope this is the right place for this question. By performing an extreme stretch of some images resulting from my usual stacking process, I noticed that a "square" pattern often emerges in the background like the one in the...
Examines aliasing patterns from image stretching and processing.
Oct 12, 2023
