D750 built-in timelapse oddities
6 replies183 views
Tonkabot avatar
I'm new, and after my second night I'm seeing some weirdness when the camera doesn't take as many pictures as I told it.
I'm just trying to get Orion as a first target.
Using the built-in timelapse feature, I have the D750 set to take 256 images, one second apart.  My images are 3s long, ISO 800 with a 105mm F2.8 MicroNikkor lens.  Just sitting on a big tripod.
But it seems like it doesn't take the full 256 images.   There were like 180 or so.   Also when taking the darks, I told it 64 and it quit after like 20.
It didn't give me any battery warnigns or anything.   Cold out, like 5 F last night.
What is going on?      I have many questions, I am just trying to start somewhere - and if I can't trust my camera to do what I say…
Not sure I understand what you're trying to do. Are trying to create a time-lapse video or use the intervalometer?
Eddy Cochez avatar
Is it possible that you put intervaltime on 1 sec. If so you should put intervaltime on 4 sec.
3 sec exposure and 1 sec of pause between 2 frames.
Also be sure that date and time are correct in your camera.
Eddy
Tonkabot avatar
Eddy Cochez:
Eddy
Hi Eddy,
  I was worried that it was something like that - that the 'timelapse' feature I am using as my intervalvometer would not work correctly if my exposure time was longer than the interval time.      I'll experiment with that change before I go out again.   Date and Time are correct.
  I am also worried that maybe the camera builds up a backlog of images to write to the SD card and eventually cannot keep up and quits, or something like that.
Tonkabot avatar
Just trying to use the built-in feature as my intervalvometer.   It is nice that I don't need a shutter release cable or any extra wires.
Eddy Cochez avatar
If the backlog is the problem you just take 2 or 3 seconds as pause. Meaning  interval is 5 or 6 sec. 3 sec exposure and 2 or 3 sec pause. You have to find it out with your sd-card.
dkamen avatar
If you want to take 3x3second shots 1 second apart then you must set the interval to 4 seconds and tell it to do 1 shot and 3 intervals. You must also set a total shooting time of at least 12 seconds. It's all here:
https://imaging.nikon.com/support/digitutor/d750/functions/timelapsephoto.html
The intervalometer on my D7500 has a similar logic, the interval must be long enough for all shots in the shots per interval. E.g. if you ask it to take 15x10second shots at 5 second intervals, it will take only the first picture because 15>5 so the remaining shots per interval are cancelled. Took me 3 years to actually read the manual and figure out why the intervalometer wasn't working like I thought it should
D.
Loosing over half my Exporsures due to Guiding, how can I Improve?
I've been upgrading my gear recently to a ASI air and a guide Setup. It has times in which it works really well but looking at the data over a night, I can confidently throw away over half of my data because the guiding just wouldn't work pro...
Losing exposures during astrophotography sessions; guiding issues may cause incomplete image capture.
Oct 15, 2023
Image creep from sub to sub
Hello, I often have a problem when taking lights that my images move between subs. By that I mean there's a few minute difference between each frame. This movement is not consistent. There is no star trailing or any significant elongation (anythi...
Image movement between exposures could explain missing frames in timelapse sequence.
Sep 22, 2023
Hello from Los Angeles
Hi Everyone! I'm new to astrophotography (only been doing it for a few months) but I'm fairly experienced with visual astronomy and did some work in radio astronomy for a couple years. I got into astrophotography when I got asked to teach a c...
Camera settings troubleshooting relevant to astrophotography beginner learning.
Apr 16, 2020
