Rotating camera with Williams 6AIII reducer?
4 replies427 views
Dan Kearl avatar
I  have the Williams 6aIII on the GT 71 scope and an asi 294 camera.
How do you change the camera rotation if needed to match a previous shoot without
messing up the back focus by turning the ring on the reducer?
Am I missing something?
Wont I screw up my flattened field by adjusting the ring?
How else do you turn the camera?
nerdybeardo avatar
I use the William Optics Rotator.  Relatively inexpensive and as long as you don't need full automation on it it works well.
matthew.maclean avatar
I use a Blue Fireball M48 rotator between the flattener and my camera. There are a few third-party brand manual rotators that you can get for M48 or M42 threads (depending on your camera and other adapters).
You might not notice a relatively small rotation of the flattener, but I think it’s probably best to leave it alone once you have it set the way you like it.
Well written Concise
Eddie Bagwell avatar
I just purchased the William Optics 63mm Manual Rotator and use it in front of the reducer. The 360* markings with "set arrow" make it easy to line up a previous image angle.
Richard avatar
I ve got a WO rotator that I used with my z103, if that would fit, I ve got no more use for it if you are interested and in Europe feel free to contact me
Williams 71 gt with rotator back focus
I have my Williams 71 gt scope set up perfectly with back focus of 64mm.. I bought a Rotator because Williams is too cheap to have one and when I put it on it messed up all the focus, I cannot even polar align now. Has anyone had this problem? I took...
Addresses back focus and rotator issues with Williams 71 GT scope setup.
Nov 14, 2023
