[Photoshop] Maintaining Color Balance without a background space reference (ie an image completely filled with nebulosity)
2 replies205 views
Brent Newton avatar
Hey all, I've been working on an f/6 Orion set, meaning that I can get M43 and only most of M42 in frame - and as a result of the exposure times, the entire image has visible banding of nebulosity.
Ive been using the color sampler tool in Photoshop to keep track of color in parts of the image, but I am somewhat limited in maintaining the background color. The closest method I've found is to sample the darkest parts of the nebulosity, but I know there's still interstellar medium there because it appears when the curves are severely stretched.
I can see some color changes image-wide but the sampler has the advantage of seeing any single change in RGB for 256 values, which is finer than I could consciously notice. Are there other methods of finding the black / neutral point? Is there way to sample an entirely different image and then apply that white balance to the Orion image?
KuriousGeorge avatar
I usually use a 32x32 or 51x51 average pixel sample (on a known white or black area) and use Photoshop > Image > Adjustments > Color Balance > Shadows (black) or Highlights (white).
I also use…
1.  Photoshop > DeepSkyColors > WhiteCal
2. Pixinsight > ColorCalibration
#2 may give you the best control, but the others work well too.
Brent Newton avatar
Had not heard of that PS plugin before - it will take some tweaking but it gives me promising results. I also had not thought of simply using a larger sample size, that will probably be simplest.
Deep Sky Stacker removing too much color from my Orion stack
Hello everyone, I am having a problem with DSS. Single 120" Image: https://www.dropbox.com/s/4z58cbukm9c8ag8/IMG_9866.CR2?dl=0 Stacked and Calibrated (dozens of Darks, Flats, and Bias) using 3 hours of exposure (Cropped and Binned in Star Tools)...
Addresses stacking and color preservation issues relevant to nebula processing.
Jan 7, 2017
