Andy Wray avatar
I decided to try and image the horsehead nebula tonight and for the first time experienced a huge halo around a star.  Can anyone give me any advice as to what may be causing it please?  FYI:  this is a skywatcher 200Pds newtonian with skywatcher coma corrector + ASI1600MM Pro. See picture below:
It's a reflection of the un-focused ghost of Alnitak or otherwise said an image of the inlet pupil of your scope. Typically, it's your CC's fault.
Andy Wray avatar
Thank you for replying.  I think you are probably right about the CC being the culprit as the only other glass in the optical train was a filter and I can't imagine that creating such a large halo.  I'm not sure that there is anything I can do to minimise that effect rather than just keeping away from really bright stars ... do you have any other view?
Well written Respectful
Joey Conenna avatar
While not ideal, some techniques can help reduce this type of halo in post. Below is a link to one, and an example of my before and after.
https://digitalstars.wordpress.com/2019/10/27/tutorial-how-to-eliminate-star-halos-in-pixinsight/
Andy Wray:
There are ways to remove or attenuate the halos in post-processing but no, there isn't much you can do other than avoid those bright stars or change the CC with one with better anti-reflection coatings.
Concise
Mike Jaworski avatar
I had to deal with this same exact issue as well.  I was also using an asi 1600.  Turns out it was the filters, though I initially thought it was the CC.
Read more here.
I did some post processing to remove some of the artifact even after adjusting my spacing.  I wrote a little of it here.
Halo in my images
Hello people and happy new year. So i am suffering from a big halo in my images. I did a topic on flats recently and it was pointed out to me that i have internal reflections. So i covered the entire inside of my telescope with velour including the i...
Halo in my images — directly addresses the same optical artifact problem
Jan 1, 2024
Skywatcher 150 PDS /OAG/ coma corrector
Hello I'm struggling achieving focus with my newly acquired 150 PDS and 0.9 coma corrector. I'm trying to use my Askar M54 OAG (I assume you can use it with this scope?) My focuser runs out (just) of inward travel. I've packed away and co...
Skywatcher 150 PDS /OAG/ coma corrector — similar equipment troubleshooting with same coma corrector
Sep 29, 2023
Weird rainbow pattern next to Alnitak
Hello guys. So after a while i got my full spectrum modified camera back, and i tried imaging with it. I took several pictures from several targets. When i was imaging the star Alnitak there was a weird rainbow pattern in the image and i have no idea...
Weird rainbow pattern next to Alnitak — similar optical aberration issue with bright stars
Jan 15, 2024
