gmadkat avatar
Hello all,
Soliciting feedback on my image here... https://www.astrobin.com/g4jty8/
I used Pixinsight to create the masters and processed RGB stars separately, used Photoshop to get the nebulosity and
used extracted Lum for details on the nebula itself and touched up in Photoshop camera raw.
Thanks everyone!
Gowri
cougar1 avatar
I can only say incredible !!!!  I just started in in astrophotography, so learning the ropes.
Gamaholjad avatar
It's a great image already. Have you thought of using Ha as a luminance for more detail and soften the image even more. Think about using ACDNR in pixinsight as well if you haven't done so already.
Helpful Respectful Concise
gmadkat avatar
Thank you so much! I did use TGVDenoise on  both RGB and Chrominance reduction, and I used extracted Lum and Ha Lum just on the bubble for detail too. Let me see if I can reduce noise further.
Thanks again!
[RCC] NGC 7023 - The Iris nebula
This is my first topic on the forum I'm kindly asking about constructive critique of my Iris nebula. Frames acquired from Poland, Bortle 5, maybe Bortle 4 around this sky area (lower LP). Nearly 14 hours, L: 7 hours and RGB: 6 hours. Camera: ASI ...
Similar nebula processing critique request with detailed workflow description.
Jul 19, 2023
[RCC]: Pelican Nebula
Hi all, I'd like to ask for some feedback on my Pelican Nebula: https://www.astrobin.com/sbf9nw/C/ I had quite a lot of problems with this data (it was very humid) so I am happy to at least get something out. I also like the framing, which was on...
Oct 30, 2023
LRGB vs RGB, trying to create an apples to apples comparison
Hi everyone, probably this has been done a million times over already, however I wanted to give this a try. In a recent image thread where I shared my newest image (https://www.cloudyni...ns-of-ngc-6914/) a fellow forum member posted an interesting t...
Discusses LRGB vs RGB processing methods relevant to author's approach.
Dec 29, 2023
LRGB-Combination in Pixinsight
I'm imaging in LRGB, and as my images get better and overall integration times get longer (RGB channels getting better), I noticed one of my biggest problems is combining L and RGB in Pixinsight. In acquisition, I use the same sub exposure time f...
PixInsight LRGB combination techniques directly applicable to author's workflow.
Sep 18, 2023
