Celestron GPS11 with fungus
9 replies160 views
Paul Campbell avatar
Found a used Celestron GPS11 for 750, including a working mount, in my town but it has a few bits of fungus on the corrector plate and primary mirror. For the foreseeable future, it would be used for planetary imaging. Maybe one day I could get an eq mount for it.
Worth it or hard pass? How hard is it to clean the corrector plate and mirror? I seem to be getting mixed reports on how complicated of a procedure this is. The seller is pretty well known guy in the community around here and I bought my c8 from him.
For that price I would say yes, it’s a good deal sort off. If the fungus has not actually etched the glass the you are in good shape, it can be removed from the corrector plate. I dilute solution of Hydrogen Peroxide will do it. The primary is a bigger problem because whatever you do to remove the fungus will likely harm the aluminum coating of the mirror. Not that big a deal because the mirror can be recoated but something to take into account. It won’t be free to do.
Lynn K avatar
The correcter is not that hard to clean. Make sure you place the corrector back in with the mark on the correcter edge at 3 o'clock looking from front of scope. Mark the shimes placement and replace in the same spot. There is no need to remove the secondary.
Use 100% cotton balls on the mirror, wiping from center out to edge. There are many liquid cleaners altenitives. Never use a dry cloth/ cotton ball and blow off all dust first.
Lynn Krizan
Tony Gondola · Jun 19, 2026, 08:55 PM
Thanks, Tony. Good to know.
Lynn K · Jun 19, 2026, 09:04 PM
Lynn Krizan
Thanks, Lynn. The idea of shims make me nervous but maybe i’m over thinking it. I’ll look at some videos
Respectful
Lynn K avatar
Both Celestron and Meade shimed the corrector plate. This was done to center the secondary, not the corrector. The reason the mark on the edge of the corrector needs to placed back at the 3 o'clock position is to rotate the secodary for best Sperical Aberration correction.
There should be a set of 3 shimes. There may be 4. Mark where each is placed and put them back in the same place. I have found Celestron doesn't do a great job of shimming to center Secondary/Corrector. It's good enough for visual. After all, It a spherical optical design and a sphere is a sphere. But for Hyerstar imaging I had to re-shim /center the corrector/secondary. That was recomented by Starizona.
The new Edge version has set screws as apposed to shims. A very needed upgrade. However It may be more difficult the turn the set screw to the same rotation, as opposed to putting the shims back in. Celestron seems to do a better job on centering the Edge secondaries. That because the secondary needs to be centered in the flattener in the baffle tube.
I have an older Carbon Fiber C11 & C9.25 and a Edge 8. The C11 collects dust and the Edge is only used for visual. I use the C9.25 on galaxies at a dark site. It doesn't get much use either. I mostly use refractors using narrow band in Bortle 7.
Lynn Krizan
Lynn K · Jun 20, 2026, 03:50 PM
Lynn Krizan
Super helpful! Appreciate the notes. Well now it’s tempting to make shim corrector adjustments on my C8, I didn't know the factory shimming was an issue. It’s tough, i’m always gauging the risk/rewards from performing operations like this. My images come out pretty well for my standards, but maybe there's a whole other level of sharpness I could be getting in my images.
What are your thoughts on the HyperStar? I was considering getting another c8 or maybe a c6 and HyperStar but it sure sounds nice to not have to worry about collimating another system. Any suggestions on refractors? I’d like to get something for wide field use and open to really anything in the 100-500mm focal lengths. I keep looking at the 135mm rokinons.
Walter Leonhard Schramböck avatar
If the fungus is small - take it and just use the telescope!
My old Meade SC EMC 10” also has small traces of fungus. I just ignore it and use it for the coming years until I can afford something better. I have no plan to invest time or money to get rid of the fungus. If it starts affecting my images, I will buy something else. Nothing stays forever.
Well written Concise Engaging Supportive
Lynn K avatar
Hi Paul, I started imaging with the original Celestron Hyperstar on a forked C8 (around 2004). The original didn't have any collimation adjustments and would ony cover a small chip. I later bought a Celestron CGE,C11 Hyperstar 2 combo from Starizona (around 2008). I origally only did Ha mono imaging. When I moved to the Hyperstar 3, the Hyperstar lens was wide enough to acomidate a filter drawer. At that time no one made them but Gerd Naumann. I got Starizona to make an adapter for it. I may have been the 1st Hyperstar user to use a filter drawer. It worked very well. Some time latter Starizona came out with theirs and the rest is history.
Pros and Cons of a Hyperstar: It's very fast at F2 with a larger aperture than refractors. Reflectors can be f4 to f2.8. It gathers signal very quickly, which I needed with my limited field of view. It's not easy to collimate, and my experience is when detached and replaced it does not hold collimation. Todays new tools can make that easier. Hyperstar is tring to make a mass produced SCT into a F2 astrograph. Not an easy task, but can be done. The RASA is an easier alternitive and designed with a single use. I still have the C11 and Hyperstar3, but it collects dust. If I was dust off the C11/Hyperstar, I would only do it with OSC and Dual Band filters on emission nebula mounted in my Pod. No break down or reasonably. If I was going do Fast SCT imaging at a dark site, I would go with a 8” RASA and OSC ASI2600MC. If you like challenges and you like fiddling, then you might enjoy Hyperstar. AT F2 all optical issues are increased. If you prefer plug and play, go with a small refractor.
I prefer fast refractors. I invested in a used FSQ106ED with the F3.6 reducer/flattener. I have invested in the expensive Tak 645 Reducer QE at 1k off from China. They have dropped in price, now that the FSQ106ED is no longer made. I also use at a dark site the FSQ85ED with the Tak RB-QB F 0.73x reducer at F3.9. (also no longer made). The Asia alternatives seem to get good results.
I read about bad results fro the Celestron dew heater placed on the corrector. It over heats and near imposible to equally distribute the heat over the corrector. It’s least distructive to place a dew heater in center od a metal dew shield.
Lynn K · Jun 21, 2026, 07:45 PM
Thanks, Lynn! Interesting notes and history on the HyperStar.
I really enjoy the tinkering aspect of astrophotography, and I think I will eventually get a HyperStar system and make it a dedicated rig so I don’t have to go through the swapping pains.
I do really like the idea of getting a simple, fast, setup too…something that doesn't need constant attention. I have an older eq-g for my c8 and I have an iExos mount that I initially started with. I’ll probably get a small refractor for that. My first lense was a Tamron 300mm f/2.8. While it’s a cool lense, it’s not really meant for astrophotography. Im looking into the qhy minicam8 as well. Feels like an affordable entry into mono.
Just to go back to my original post, I think i’m going to skip on the c11 but appreciate everyone’s input.
Respectful Supportive
