Look Ma, No Clips!
1 reply38 views
This is an image (60×10s, L filter) taken few days ago, somewhere in Cygnus, once I finished fiddling with the primary mirror cell of my GSO rebranded 6” f/4 Newt. As the title may suggest, I removed the clips keeping the mirror attached to the cell and hence no more clip-induced fans spreading from brighter stars (not that it ever stopped me imagine, mind you). No mask or other gismos, just the pure, un-adulterated mirror surface, warts and all. I also changed springs and washers, inserted shims to avoid mirror shift and cleaned the whole shebang which quite clearly needed a once-over after 4 years in the field. Because me messing around with it and also changing the focuser, tilt correction is gone a bit out of the window (ASTAP reports mild tilt, around 13%) so the furthest corners do NOT enjoy a distortion-free life. That will be for another night though…
📷 Test_PH150_ASI294MM_L_60x10s.jpgTest_PH150_ASI294MM_L_60x10s.jpgAnd if you’re asking yourself what’s the trick the answer is: 3 dabs of RVS @ 70% of mirror radius (neutral diameter), equidistant from the cork pads.
Well written Helpful Respectful
Removing any diffraction sources in the light path is always a good idea. Aside from spike, a Newtonian can deliver excellent stars if treated the right way. Since it’s a GSO you might want to make sure that with your selected image train that the bottom of the focuser tube never intrudes into the light path as well. That might clean up your stars even more.
