I have uploaded two versions of M57 taken with my newly acquired Seestar S50: one based on 20 s IRCUT subs and one based on 60 s LP-filter subs. Both were stacked in Siril with drizzle 2×.
📷 M57 (Ring Nebula) with Seestar S50, balcony observatory :-), no LP filter, 20 sec subframes
https://app.astrobin.com/i/t1sqz5/
📷 M57 (Ring Nebula) with Seestar S50, balcony observatory :-) , LP filter & 60 sec subframes![]()
https://app.astrobin.com/i/2kpf0v/
I am trying to understand something I see in the pre-stretch histograms of both stacked images.
I attach three Siril screenshots:
one original, non-debayered 20 s IRCUT light;
the 20 s IRCUT drizzle stack;
the 60 s LP drizzle stack.
The screenshots include both the histogram and the image statistics.
The single original light looks quite normal to me: the background distribution is broad, with a tail toward low values, and the minimum is 0 in all CFA channels.
In the stacked images, however, the RGB histograms show a very sharp lower cutoff, even in logarithmic scale. There seem to be essentially no pixels below a certain threshold. At the same time, the statistics do not seem to indicate a simple fixed zero floor: for example, in the 20 s IRCUT stack the minimum values are about 4405, 5110 and 4995 ADU in R, G and B, while the median is around 5790 ADU. In the 60 s LP stack the minima are different again, about 187, 2835 and 0 ADU, with a median around 4350 ADU.
My current interpretation is that the sharp cutoff is mostly the expected narrowing of the background distribution after stacking many calibrated frames, perhaps combined with Siril normalization, drizzle and rejection, rather than simple clipping to zero.
Does this interpretation sound reasonable? Or is there something specific in the Seestar FITS / Siril drizzle stacking workflow that could produce this kind of sharp lower histogram edge?
I also notice that both the single and stacked frames contain saturated pixels near 65535, so the 60 s subs may be locally saturating some stars. Any comments on that point are also welcome.
