Hello, just a quick one to get some info of someone with experience on the Samyang / Rokinon 135mm.
Just ordered this lens and hoping to turn it into a third little wide field rig for imaging.
(Playing around at F2 should be fun compared to the F5's of my other rigs)
I'm now working on figuring out the best mounting solutions, which comes with the question:
how well does it maintains focus during the night? And how often do you adjust it?
as I'm seeing conflicting stories depending on where you're looking, which is understandable at F2. And I'm trying to figure out if I should be buying mounting solutions that are able to hold a ZWO EAF... or; if I can save a bit of money and just go for a standard mounting solution + bahtinov mask.
And I'd rather not waste money on the more expensive mount + another ZWO EAF it if it isn't needed.
Or find out later I should have spent the money because it was needed and need to buy an entire different mounting solution.
