Hi there,
I’m having some issues with my ASI 533MC Pro. Anything I connect to the USB Hub of the camera ends up getting disconnected because of connection failure. It does not matter if it is the guiding camera (ASI 220MM), the automatic focuser (EFA Pro), the filter wheel (EFW 5x1.25") or the mount (Sky-Watcher EQ-AL55i Pro SynScan GoTo WiFi), it will repeatedly get disconnected and fail. If I connect those directly to the Asiair Plus 256GB, it works just fine without failing, with the same cables, so it seems like the only possible failure point is the camera.
Has anybody experienced something similar? Any suggestions on how to fix it?
Thanks,
Dioni
