I'm using SG Pro to capture my images and using the calibration wizard to determine the setting for my Flats. Do my flats need to have the same Gain/Offset as my image set or can I use a different setting? Thanks!
All your calibration files should use the same gain/offset. This is key to making sure they correct all the sensor pattern noise. Because of the amp glows, it is also important that your flats be taken at the same temperature as the lights as well, and the same really goes for bias and obviously darks as well.
Hi all While I've been largely locked under clouds for a couple of months, I thought I'd write some software that I've been meaning to get around to for a while. I use a standard LCD computer monitor for taking flats. I plug it in to my i...
Discusses flat-field calibration software relevant to author's flat capture process.
Hi @strobin, I tried my luck at the official ZWO-Forums, but didn't get a response until now, and tonight will be clear skies at my location, so i wonder if here is anybody who can give me an advice about this topic: After more than half a year u...
Addresses gain/offset settings directly relevant to author's calibration question.
