Hubble palette on OSC, Hb or OIII?
22 replies345 views
Willem Jan Drijfhout avatar
Is there a general consensus about what is the best dual band filter to use on an OSC camera for a Hubble palette, besides the Ha/OIII?
Would that be an SII/OIII or an SII/Hb?
Well written
Ha+Oiii plus UV/IR for stars.
How does that give me the SII for a hubble palette ?
Interactive Sky avatar
Hello, Willlem!
As far as I know, you can create a synthetic SII channel if you want to use the Ha-OIII filter only. But usually, you would use the SII-OIII filter to capture SII.
Hope this helps. Clear Skies!
Well written Respectful Concise Supportive
Interactive Sky · Jun 2, 2026 at 06:07 PM
Hello, Willlem!
Thanks, a synthetic SII sounds intriguing. One would think that the SII signal would be independent from the other two?
So your advice is the SII/OIII over the SII/Hb.
Thanks very much, and clear skies to you as well!
Willem Jan Drijfhout · Jun 2, 2026, 03:46 PM
I would go quadro-chromic and get an Antlia SII/Hb DNB. Not cheap though…
Patrick Graham avatar
How does the Optolong L-eXtreme compare to the Antila filter you’ve recommended?
Well written
I don’t think they are comparable, one is Hbeta-SII and the other is OIII-Halpha. If you mean the ALP-T then it is much better than the L-Extreme but then one is 5nm and the other is 7nm (in fact even more). Performance with fast systems is the real discriminant here and there is no real alternative to Antlia for that.
Helpful Concise Engaging
Thanks Andrea……I think I’ll take a look at the Antila. May be a higher price but the filter is forever.
Rafał Szwejkowski avatar
If you don’t want halos Antlia is your only option really. Others are “virtually” halo-free (real YT influencer-speak) - and you will be unpleasantly surprised.
Franco Grimoldi avatar
Willem Jan Drijfhout · Jun 2, 2026, 06:18 PM
It is, in fact, independent. I’ve seen many tricks trying to replicate the “SII Feel” but they lack the depth of a true independent third channel.
This is just an attempt at it (SVbony SV220 7nm Ha/Oiii):
This is a “true” SHO using the filter from above and its Sii/Oiii sibiling:
📷 image.pngimage.pngNothing bad using just an Ha/Oiii but adding light from the Sii/Oiii has the additional benefit of increasing the Oiii signal.
Alex Nicholas avatar
Rafał Szwejkowski · Jun 2, 2026, 11:07 PM
Askar’s D1/D2 are stunningly good and 100% halo free in my testing… That said, not sure how great they are on a fast optical system.. I only used them as fast as f/4.8.
Furthermore, remembering that if you go Ha/OIII + SII/Hb, you’re pidgeon-holing your self into a deeply annoying truth about the night sky…
OIII and SII are incredibly sparse by comparison to Ha. Ha rules the night sky… If you’re only capturing OIII data while also capturing Ha, you will either end up considerably weak OIII data, or you’ll end up sacrificing SII or OIII in favor of the other…
If you get Ha/OIII and SII/OIII, you can shoot 4~5h with Ha/OIII, then 10h with SII/OIII, you’ll have 5h Ha, 10h SII and 15h OIII, which will typically mean your SII and OIII won’t get swamped by Ha data…
YMMV, but, As nice as getting the Hb is, I would prefer to double down on OIII… or in a perfect world where the sky was always clear and you have no other responsibilities, get all 3…. 5h Ha/OIII, 10h SII/OIII, 5h SII/Hb resulting in 5h Ha, 15h OIII, 15h SII, 5h Hb… then go to town with your data…
Tom Boyd avatar
Alex Nicholas · Jun 3, 2026 at 04:51 AM
I use the D1/D2 combo on my CarbonStar (f/4). No halos that I have noticed…
They have IR leak, small but it is there.
Mikołaj Wadowski avatar
I’d go for Sii/Oiii, Oiii often requires the most signal out of SHO. As far as I’m aware Hb looks nearly identical to Ha, just a fair bit fainter, so I don’t think it’s useful at all.
Mikołaj Wadowski · Jun 3, 2026, 05:48 PM
You’ll be wrong on both counts, generally speaking…
andrea tasselli · Jun 3, 2026, 05:50 PM
Huh, interesting. Here’s an example of Ha vs Hb, with the only difference being I added noise to the Ha data as Hb was far noisier. This is the first dataset I found with Hb data included. Can you tell which is which?
image.pngIf you know why Hb can differ from Ha you can probably tell them apart by looking at specific clues. This is a rather extreme example as it’s an area with very thick dust, which would show more differences. Despite that, I think you’d agree the difference is barely there.
As to Oiii requiring more data, check out https://www.simg.de/nebulae3/dr0_2/. The linear narrowband FITS maps are presented in Rayleighs, so you can quite easily see what each filter would look like on a CMOS sensor by setting the max cutoff to similar values, accounting for QE.
Jim Case avatar
I have been happy to combine the ALP-T HA/OIII with the D2 SII/OIII data, such as this version of Fleming’s Triangle (AKA Pickering’s Triangle} : https://app.astrobin.com/i/7lwijc
There are several other images in my gallery using the same combination.
Mikołaj Wadowski · Jun 3, 2026, 09:57 PM
Mine would be an educated guess at the very best, I’d say A is Hb and B is Ha, only because of the contrast difference.
I present my own data as proof that you can’t generally assume that Hb and Ha are scaled copy of each other. Starts with M27, see here: M27 Ha-Hb-OIII-RGB Composite - The Dumbbell Nebula - AstroBin
Here is another one:
📷 image.pngimage.pngI can’t see a way to transform one into the other
Now for an emission nebula:
📷 image.pngimage.pngHb: 78×180s
📷 image.pngimage.pngHa: 70×180s
And as soon I have got a chance let’s see how cygnus fares. I’ll be there’ll be surprises there too.
As for OIII vs. SII, again I took both advice from people I know have more experience than me in doing SHO and did my own testing and checking. While there are obvious zones where SII is dominant compared to OIII by dint on not having it at all or being obscured by dust or what else, the fact is that Oxygen is the third most common element in the Universe and Sulphur is just down in 8th position. That must have a bearing on how much we see of it, hasn’t it?
This are few shots from areas of the skies that are particularly rich in SII and for the life of me I can’t see the OIII emission being particularly weaker than the SII, quite the opposite if we look at their distribution. Granted one is more concentrated than the other.
📷 image.pngimage.png20 min each channel
📷 image.pngimage.png10 min each channel
📷 image.pngimage.png20 min SII 15 min OIII
In all cases the starless SII has been linear-fitted to the starless OIII so that they have the same background level. Auto-stretched in PI.
Finally, two raw unprocessed frames of a zoomed in image comprising the Thor’s Helmet. No price to guess which one is SII and which is OIII.
📷 image.pngimage.png5min each.
So I re-state my original assertion : you can’t, generally speaking, assume your original statements to be true.
Jordan Morley avatar
I use antlia's hb+sii and ha+oiii for a couple of years now. I add hb and oiii together for the blue channel. My hb+sii has halos but I couldn’t care less. Really easy and fast way to do hubble palette because I have very little cloudless nights
Concise
I quite like your IC2944. That would be my aim too.
andrea tasselli · Jun 4, 2026, 06:45 PM
Looks like processed data? I don’t think that’s very useful.
Ha is brighter than Hb, that’s all I can see from this comparison. Though I presume PNs might have some diffrences since they’re dense (therefore more absorption, similar to the thick dust lane in my IC 1318 example), the differences you’re seeing here are almost entirely due to different SNR. Without that, they’d be minimal.
Same here, these look denoised and the difference in brightness makes it pointless as a comparison when the data is stretched separately.
This is anecdotal advice vs properly calibrated data you can compare yourself at simg.de.
You could not be any more wrong, both O III and S II are emission from ionized sources which require different energies to produce an emission line photon. If there’s not enough energy to ionize O III it’s emission line will simply not appear, even if O I or O II is there.
We must not be looking at the same images here. All but the very brightest areas in both images are visibly stronger in S II. I imagine when capturing data you don’t get tens of hours of O III only for the very brightest areas that show up well in a couple subs.
These two are fine examples showing that it’s not always the case even for “normal” emission nebula.
This is not a good way of showing the brightness differences. Background level can be equalized with a simple subtraction, normalizing their brightness with linear fit makes no sense if you’re trying to show the difference in brightness, though I guess stretching them separately later “fixes” this a bit.
A WR nebula to show this comparison is possibly the worst example. Yes, extreme examples are true for both sides.
But why look at individual examples when you can look at the whole northern hemisphere and see for yourself, that S II is significantly brighter that O III in the vast majority of the sky. Look at the entirety of Cepheus, Orion, Auriga, or most of Cygnus almost disappears in O III, especially outside the two or three brightest nebulae. Just use the calibrated all sky map and see for yourself.
Of course it’s not an absolute rule, exceptions, particularly around high energy sources, do exist. Think PNs or WRs, those will be much brighter in O III as sulfur is ionized further.
