Chroma filter advice
20 replies247 views
Jan Hlavačka avatar
Hi everyone,
I’m looking for some advice from people with experience using Chroma narrowband filters long-term.
I found a set of used Chroma 5nm filters (Ha, OIII, SII) from 2021 at a reputable astronomy shop. They are listed in excellent condition, and Chroma confirmed they are genuine 2021 production. Price is around €412 per filter, compared to about €687 new.
I know Chroma uses hard sputtered coatings and even offers a lifetime warranty on sputtered catalog filters, which sounds reassuring. However, I also came across a few reports (for example on CloudyNights) of some filters showing brown discoloration on the edges / possible coating issues after a relatively short time, which made me hesitate. I am also worried about the coating technology being outdated, and i want this to be a one time purchase so if the new chroma filters offer an performance improvement i am willing to pay up.
So I wanted to ask people with real long-term experience:
  • Have any of you used 2020–2021 Chroma narrowband filters (Ha/OIII/SII)?
  • Have you seen any coating degradation, edge browning, or performance changes over time?
  • Do you think buying a 2021 used set is a reasonable move, or would you personally spend more and buy new for peace of mind?
  • If you bought used Chroma filters, what specific things would you inspect before purchasing?
For context, these would be used on an f/4 Newtonian with an ASI2600MM
I’d really appreciate honest feedback from people who have actually owned and used Chroma filters for several years.
HR_Maurer avatar
I use chroma filters, purchased in early 2022. I put these filters into a filter wheel, and the edges are covered, so if i detach the camera i cant see the edges. I didnt notice any degradation so far. What i noticed though, was the central transmission wavelength (CWL) has been off in one of my filters. So it didnt match the requirements i had given with respect to f-ratio. I have access to a laboratory with some fancy spectrometers… So i returned the filter and got replacement.
Exactly at that time, Antlia entered the marked, and they do cherry pick their filters, to match the CWL to the customer’s need. I think every brand should have adopted to this practise since, because it makes a lot of sense. I had some discussions about this with Chroma, but i dont know for sure if they do it today.
Before i had these filters, i used other filters in filter drawers. And since i was a bit short of these drawers, a lot of handling was involved. Especially when handling in the dark and in a hurry, this can quickly result in some fingerprints. And if these fingerprints aren’t removed instantly and properly, thery might become permanent.
So, my recommendation would be, to not only look for degradation, especially at the edges, but also for finger prints, dots (from droplets), scratches or smearing from improper cleaning. Knowing how the filters have been used before, can help.
Well written Helpful Respectful Engaging Supportive
Jan Hlavačka avatar
A wrong CWL is pretty insane, i have never heard about that yet, and definitely wouldnt expect it from chroma
I think the filters look great, you judge:
📷 image.pngimage.png📷 image.pngimage.png📷 image.pngimage.png📷 image.pngimage.png
Jan Hlavačka avatar
HR_Maurer · May 29, 2026, 05:56 PM
i have heard some bad things about antlias halo performance, and had a really bad experience. One of their filters i recieved was defective, had some halo issues.. antlia responded in a week and said it is within factory tolerances.. thank god the retailer offered me a replacement
HR_Maurer avatar
Jan Hlavačka · May 29, 2026, 06:35 PM
it wasnt exactly wrong. The line emission was within transmission maximum, when measured at 90° incidence angle. That’s the transmission spectrum manufacturers typically show. However, it was closer to the blue end of it. At a smaller incidence angle, the CWL shifts towards the blues, so the filter would effectively reduced my f-ratio by some stops. Indeed, from a brand like Chroma i would expect this to be spot-on.
Jan Hlavačka avatar
HR_Maurer · May 29, 2026, 06:52 PM
What do you think about the condition of the filters i sent a few messages above?
HR_Maurer avatar
hard to tell from a photography. There is some dust, which shouldnt be an issue. Apart from that i dont see anything.
Try to inspect them with light from behind, play with the angles. Many blue is best for detection of issues.
Edit: i meant light from behind the viewer. Not backlight (in transmission). The AI at least did understand it wrong. However, if you CAN see something in backlight conditions (in transmission), too, thats even better.
Chuckbnobo avatar
I recently got Chromas and asked about the slightly blue shifted transmission of my Oiii. Note, still within spec for primary but peak shifted toward the secondary. I was told it should be fine for my setup. I havent had a chance to test them extensively enough to verify it though. I also wonder if others have had similar experiences, and if it has affected their results?
Andy 01 avatar
I purchased my Chroma filters in 2020, no issues whatsoever.
See my IOTD yesterday, I’m still very happy with them. https://app.astrobin.com/u/Andys_Astropix?i=7k6jip#gallery
Also they have great customer service. Highly recommended! 😀
CS, Andy
Respectful Supportive
Ashraf AbuSara avatar
Jan Hlavačka · May 29, 2026, 04:32 PM
Hi everyone,
I have just sold a Chroma SHO set (Ha 8nm, Sii 5nm, Oiii 5nm) 50mm round unmounted for about the same price. I was second owner (got them in 2023), and the first owner had them since 2020. They looked absolutely perfect when I sold them. No discoloration or coating degredation at all. I have used them well over a thousand hours in remote locations. Just ask the seller to send you some nice close up pictures of both sides of each filter, and maybe a set of recent flats taken with each filter and recent stacked images.
Chroma is great, but even their filters can have lemons. I had two Ha filters that had bad halo problems that got replaced by Chroma no questions asked. But since you are a second hand buyer, I don’t think Chroma would do that. Maybe I am wrong. If they do that would be even more incredible customer service.
Willem Jan Drijfhout avatar
I have a set of 50mm unmounted 3nm NB and LRGB filters from Chroma from 2020. Still using them every day and they look perfectly fine to me. These are very high quality filters, and my guess is that you will get some great use out of them for quite a number of years.
If the price you are offered is 40% below current new-price, that will be very similar to what the current owner paid for it in 2021. Chroma filters have seen dramatic price increases over past years. That’s bad news for buyers, but for owners, it means zero depreciation…
Jan Hlavačka avatar
Ashraf AbuSara · May 30, 2026 at 01:22 PM
Hi everyone,
Thank you for this feedback! I really appriciate it! I believe Chroma would do that, im pretty sure they have a lifetime gurantee for defects, but i have a different question. The seller has a 15 day money back return policy, so from the day i recieve the filters, i have 15 days to try them and if im unsatisfied, i can return them for the full price! The question is, what tests should i perform to assure myself they will serve me well? Thanks,
Jan
Respectful
Jan Hlavačka avatar
Guys, thank you for all the replies and help! I got a lot of New useful info i didnt know from this thread.
Christian Hilbert avatar
Hi Jan,
I've been using a Chroma OIII 3nm filter for many years, and it's by far the best filter I've ever used, with no change in quality over time. I have filters from other brands, some very good, but if I could, I'd buy them all from Chroma. On another note, I have to say that the company's after-sales service is excellent; they always help you with any questions or problems you have with the filter.
Christian
Well written Respectful Concise Supportive
Jan Hlavačka avatar
Christian Hilbert · May 30, 2026, 11:55 PM
Hi Jan,
Christian
Hi Christian,
I am glad you confirmed what i was thinking.. Now the main concern is that if i should get the brand new ones for the higher price, or get the used ones..
Jan
Bob Lockwood avatar
Jan Hlavačka I am glad you confirmed what i was thinking.. Now the main concern is that if i should get the brand new ones for the higher price, or get the used ones..
Buy the used ones, there’s no difference in the quality and still under full warranty.
The only reason I'd hesitate to buy an older and used one is because of the possibility of minor damage like scratches, but not because of any loss of filter capacity. In that case, the only option is to see and test them first.
Well written Concise
Bob Lockwood avatar
I don’t think you’d need to test them, but the seller would need to be honest in stating that the filters are in excellent condition and have no cosmetic issues. The OP did state that the filters are from a reputable astronomy shop and in excellent condition.
Jan Hlavačka avatar
Bob Lockwood · May 31, 2026 at 03:58 PM
Its better to be safe than sorry, the astronomy shop is very reputable, but i want to be 100% sure, because i think i would go crazy, if i found out the filters were somehow damaged or not performing as expected after the 15 day return period
Buy them, do a detailed visual inspection when you receive them, image with them as soon as you get a reasonable night. That should happen within the 15 days unless you are extremely unlucky. there’s always an element of “pay your money, take your chances” with anything used. In this case, you’re probably ok.
Helpful Concise Supportive
Always protect your purchases with something like Paypal coverage etc. In case of a dispute you can always have a recourse. But if seller is offering money back its a pretty good indicator that they are being honest about the condition of the item.
