cosmosexplorer avatar
Every time an exposure ends it takes about 7 seconds for it to appear on the screen it is very inconvenient when I’m trying to focus on a star, I have to wait 7 seconds every time for it to catch up to see my adjustments same issue doing regular acquisitions on targets, I tried reinstalling the ascom platform, zwo driver, I even reinstalled nina and nothing made any difference, my new laptop is an acer 16 ram, ssd, AMD Ryzen 7 7730U, and the weird thing is that my home pc has no problems running my camera, it responds instantly but it would be very inconvenient to drag my big home pc setup out to the remote site, anybody else run into this issue?
Are you going into a USB3 port on the laptop?
Yes, tried all 3 and no difference. Thanks for responding.
Brian Puhl avatar
Turn off star detection/image analysis, see if that makes things faster.
I will give that a try next time I get it set up, thanks.
TiffsAndAstro avatar
cosmosexplorer · May 25, 2026, 02:20 AM
More details on the camera model please.
When you say remote site, do you mean bottom of you garden or a 1000 miles away?
What control pc are you using for the remote gear? The new laptop or a mini pc?
When you say 7 seconds delay, is that to you laptop or seeing it on your laptop from your desktop?
Are you using any usb hubs or usb extension leads anywhere?
Georg N. Nyman avatar
I got the same problem with my QHY600 - but my solution is to use for quick focussing the QHY app - there I can choose “LIVE” - that means, it refreshes within less than one second. I presume that you find a similar app for ASI..
Kamil Fiedosiuk avatar
As a temporary solution, you can enable subsampling (region of interest), set the crop f.e. 1000×1000 and drag over the entire frame, to chose some bright star.
Thomas Dahmen avatar
USB Limit auf 9 unter dem Kamera Setup in N.I.N.A eingestellt.
Damit ist die höchste USB Übetragungsgeschwindigkeit gegeben.
Wenn ja, ist auch wirklich USB 3.0 an Übertragung möglich.
Evtl. falscher Port oder falsches USB Kabel ( Typ; Länge ) .
Michele Rainville avatar
This maybe a windows device configuration issue try these suggestions:
To access and modify USB settings via Device Manager in Windows 10 and 11, press Windows Key + X and select Device Manager. Expand the Universal Serial Bus controllers section, right-click the specific USB device or hub, and select Properties.
Within the Properties window, key settings are found in two tabs:
  • Power Management: Uncheck Allow the computer to turn off this device to save power to prevent Windows from suspending the device (a common fix for devices disconnecting randomly).
  • Advanced: Click the USB Settings button to manually adjust Power Management and Data Transfer configurations for the specific device.
For broader system-level controls, such as USB Selective Suspend or USB Battery Saver, you must navigate to Settings > Bluetooth & devices > USB (Windows 11) or Control Panel > Power Options > Change plan settings > Change advanced power settings (Windows 10/11), as these are not directly editable within the Device Manager interface.
Thanks, I will give this a try and let you know if it works.
Well written
Rick Veregin avatar
One other thought. With my laptop I have had problems with the USB3 cables at least with longer cables (even active cables), but they worked fine on my desktop. The solution was to use a USB2 cable. I have a 30 ft usb active cable and it takes only about a second for a full frame download to my laptop. My theory is some laptops don’t provide enough power to the USB.
Rick
Robin Bosshard avatar
In my setup the steps that happen after the actual download take up most of the time it takes to display the image: debayer, stretch an star detection/annotation. I got a nice boost to the speed by using the gpu/cpu acceleration plugin.
Michele Rainville · May 25, 2026, 12:59 PM
I changed the USB settings and it sped it up a little bit, it went from 7 seconds to 5 seconds, but I experimented with another image capture program called APT, I downloaded it then ran my camera on it and it responds instantly so I’m thinking it’s probably a setting within nina somewhere and I just have to figure it out.
Dann USB Limit auf 9 unter dem Kamera Setup in N.I.N.A pfüen.
Nigel Pendred avatar
When focusing on a star with a colour camera I temporarily turn off star detection and debayer tabs. Turn back on when imaging…
Jared Willson avatar
Make sure you are using the native driver for your camera in NINA, not ASCOM. If you connect via ASCOM the overhead is huge and the time between images increases dramatically.
Well written Helpful Respectful Concise
