Hi all,
I have just started astro-photography a few month ago and I use now a Canon DSLR/Lens with a Star Adventurer on a good photo tripod without guiding.
I am quite happy with the result I get with my 70-200mm L @ 200mm up to 60sec or even 120sec exposure, but I am not happy with the images I get when I use the 100-400mm L mk I @ 400mm and 60 sec exposure : the stars are awful and often show a triangle-like shape as seen below. This is a crop near the center of the image.
Now, I would like to get better result with nice rounded stars, but I am not sure of the cause of this problem and I need your input
My question: is this star shape caused by a tracking issue (no auto-guiding) and/or vibration?
I would expect the shape to be more egg-shaped if it were linked to the limited tracking accuracy of my setup, but I am not sure.
As the 100-400 mk I is quite long when extended at 400mm, I was thinking it may also be a stability issue which would imply a different solution.
Now, I am considering purchasing a Lacerta Mgen III (or maybe ASIAIR based) guiding solution or possibly go with a far better EQ mount such as the iOptron GEM28EC which may not require auto guiding for the focal length I use (400mm). But as those items are not cheap, I would like to be sure that it would actually give me far better photos with my DSLR and lenses. As the Star Adventurer can only be guided on RA, I have some doubt auto-guiding would solve the problem.
TIA for your help!
TIA for your help!
