Is the so called “60%” rule a thing for strainwave mounts ?
Eric GagnéTony Gondola
26 replies751 views
Eric Gagné avatar
I really like my EQM-35 Pro but with the FLO pier extension on it it’s getting a bit heavy for me to carry in and out of the house so I’m thinking of getting a harmonic mount.
My rig weighs 13.6 pounds so I am wondering if it’s too close to the AM3N 17.6 pounds limit as I’d rather avoid using counterweights.
My first choice would be a NYX-88 if money was no object, other options might be a Wave 100.
So back to my question…..does the 60% generally considered as the max percent of capacity we should use apply to those mounts ?
Rafał Szwejkowski avatar
Not really, and it hasn’t really been actually true for quality mounts in general. Just one of those conventional wisdoms that gets repeated all the time.
Alex Nicholas avatar
I’ve put considerably more load on many mounts than the manufacturers would recommend, and had great results too… Its all a matter of knowing your mount.. I used to image on an EQ6-R (this is 20 years ago now) with my imaging scope being a C11 XLT with a SBIG ST10XME + 8 position filter wheel and AO-8, and I used a William Optics Megrez 102 (102mm F/7 doublet APO) as my guide scope… All up, this was about 34kgs including a ADM dual losmandy saddle plate, camera equipment, scopes, dew heaters, dew shield etc etc. The mount was rated to 20kg. I used 5×5kg counterweights, always made the balance east heavy to maintain worm gear to worm wheel connection, tuned the worm/worm wheel meshing on both RA and Dec, belt driven, aftermarket bearings installed throughout and lubricated with a low temp teflon grease… The mount was extremely overloaded, but with very careful balancing and configuration I was able to have the mount operate just fine like that for a very long time. I’ve also had plenty of load on my harmonic mount, 120APO + 60mm APO with a full mono camera setup, computer, power box, dew control etc etc. without a counterweight… No issues at all.
TiffsAndAstro avatar
Minl at mlastro suggests about 70% for the sal-33 for imaging, compared to visual.
I think with careful balancing you can certainly exceed the manufacture’s suggested max load. I think that most are being conservative in this area. I used to run a Meade lxd75 (remember those) for doing lunar imaging with a homemade 10 F/7.5 newt. the total payload was around 40 lbs. with very long moment arms. I couln’t do precision guiding with it but it never harmed the mount, i fact i still have it today.
If you think about it from an engineering point of view, if the load is balanced then the issue is really about moment arms, inertia and damping. A compact RC will be less troublesome than a long newt., even if the payload weight is the same.
Things might be a bit different with Harmonics though. It would be worth researching how these drives actually respond to out of spec loads. I suspect that it’s more of a problem with the reduction gears than the Harmonic dive itself.
Eric Gagné avatar
Except for MLAstro about the SAL-33 I can’t find a single manufacturer that says anything about visual vs imaging capacity. So I’m back to square 1 😁. Trying to figure out if an AM3N is enough, or go to the Wave 100i or byte the bullet an get the NyX-88.
Probably because a mount built from Legos and plywood is going to be good enough for visual.
Glenn Mitchell avatar
You might consider the AM5N. Your rig is certainly within its weight limits not requiring a counterweight.
I have two. One running a 65mm refractor. The other running a 107mm refractor.
The solution you might consider to carrying gear in and out of the house is renting a pier at a remote observatory. My piers are at Starfront Remote Observatories in Texas. Bortle 1 skies.
I do use counterweights with my rigs. 5kg each. Not required. I find I get smoother slews and better guiding.
Jared Willson avatar
Eric Gagné · May 23, 2026 at 07:34 PM
I would say the 60% rule no longer applies to mounts, regardless of whether they are harmonic drive or conventional GEM’s with counterweights. That rule was really just a reaction to some manufacturers who tended to overstate their mount’s capabilities.
In the case of strain wave mounts, the weight capacity (without counterweights) is usually more about when the tripod gets to be too unstable to have confidence it won’t fall over in a strong wind or if lightly bumped. It’s less about the motors struggling to move the scope around at normal tracking rates. That’s just a generalization, but I think it’s still true.
That being said, strain wave mounts tend to have less accurate tracking than GEM’s with counterweights of similar capacity at a given price point. That’s simply the price of portability. Most people have adapted to this by using shorter/more frequent guide corrections which is perfectly workable if not quite optimal. Will the AM3N track accurately enough for your uses? Well, the manufacturer only guarantees ± 15” of PE which is a lot. Plenty of people manage to get that down under 1” with good guiding. I don’t know what focal length scope you are planning on mounting. If it’s just your 135mm, I’d say no problem at all. You said your rig weighs 13.6 pounds, though, so I suspect you are thinking of a different scope. What scope? How much aperture/sail area? How long a tube/moment arm? And how do you intend to guide the AM3N?
Jared Willson · May 25, 2026, 02:13 AM
I have said this time and time again, and for some reason, nobody ever wants to hear it or listen to it… The advantage of a small (AM3 class) harmonic mount over a well serviced, belt modded HEQ5 is that it is smaller, lighter and doesn’t require a counterweight in most circumstances. The belt modded HEQ5, with well meshed worm/wheel, and a proper application of a suitable PFTE based lubricant will outperform the harmonic mount for tracking accuracy and smoothness all day long… Same when you step up to a EQ6-R pro vs AM5 class mount. The AM5 is significantly smaller and lighter, thus, more convenient, but it won’t outperform the EQ6-R Pro…
Convenience: Harmonic mounts win hands down - every time.
Suitability: For ‘most’ people, an AM5 class harmonic mount could be a forever mount.
Accuracy: Harmonics will never outperform a suitably well looked after and configured GEM (will beat them out of the box maybe, but not once tuned).
If you want convenience, or you’re shooting exclusively wide-field (sub 750mm F/L), Harmonics all day.
If you want the best possible accuracy at a budget/mid level price point, get a quality GEM and tune it to its optimal performance.
If you require more accuracy than a GEM can provide, direct drive/friction drive mounts are the next step, with high resolution encoders… but for that, expect to pay 3x what a HIGH end harmonic will cost…
I had a VERY well tuned Losmandy G11… With every scope I’ve used on it from a 12” RC, through to a 65mm Quintuplet APO, it would happily guide away at 0.4~0.6” without issue… even in a light to moderate breeze… I lement not keeping that mount, alas, degenerative disc disease in my cervical spine and two herniated discs in my lumbar spine mean that I simply can’t deal with the weight… I now use a harmonic mount, and my performance is not FAR off what the G11 could do, but wind affects me more, seeing affects me more, guiding parameters and corrections are CONSTANT compared to the G11 than would get a dec correction every 20~30s and a RA correction maybe every 15s…
± 10” PE on the harmonic vs ± 5” PE with the G11 sucks… but convenience > performance when your spine can’t move a 40kg mount/tripod around anymore.
Eric Gagné avatar
Jared Willson · May 25, 2026 at 02:13 AM
The 135mm is sitting on a light pier at Starfront, I sold it a year ago. The one I’m talking about is an Askar 71F. It was a complicated setup that required adding a few things that added weight.
Surge avatar
Glenn Mitchell · May 25, 2026, 01:32 AM
Just be aware that ZWO’s AM5 and AM5n stepper motors are smaller and lower torque than than the MLAstro SAL-33’s.
MLAstro used NEMA 17 motors on both axis which are 8mm longer (48mm) than the ones found in the ZWO AM5 (40mm) which translates to about 25% more torque. That’s a big difference.
SAL-33 NEMA 17 motor on the left - ZWO AM5 NEMA 17 motor on the right.
To add insult to injury, ZWO use smaller NEMA 14 motors on their DEC axis in the AM5. They fixed this in the AM5n but the motors are still not as powerful as the SAL-33 from what I’ve read.
MLAstro recommend 70% of load capacity for imaging after probably many hours in R&D, testing and tweaking. Obviously where the weight is located and moment arm plays a large role but if MLAstro recommend 70% on a mount which is engineered to tighter tolerances and is more powerful than the AM5(n), then I think I’ll take their guidance without a pinch of salt.
Sources:
https://www.cloudynights.com/forums/topic/853364-am5-teardown/
https://www.cloudynights.com/forums/topic/974626-mlastro-sal-33-official-thread/
Edited to redact “cheap Chinese” statement and added info about AM5n which now has a NEMA 17 motor on the DEC axis.
Well written Helpful Respectful Engaging
Eric Gagné avatar
TBH I am seriously leaning towards the NYX-88.
The SAL-33 would be a serious option if it wasn’t for the delay. I don’t want to wait 4 months.
The AM5N is a bad deal in my opinion, it costs more than the NYX-88, only has 1 more kg of capacity but I think it’s not in the same class as the Pegasus which I consider to be a premium mount.
And I don’t know what it is with the AM5N, maybe user errors but I have many topics on forums from people who have issues with guiding and that doesn’t inspire confidence
Well written Concise Engaging
Surge · May 25, 2026, 01:17 PM
TiffsAndAstro · May 24, 2026, 07:37 AM
Just be aware that ZWO’s AM5 stepper motors are smaller and lower torque than than the MLAstro SAL-33’s. I suspect that the AM5n also has lower spec steppers in it but haven’t found the details online.
SAL-33 NEMA 17 motor on the left - ZWO AM5 motor on the right.
Then to add insult to injury, ZWO use smaller NEMA 14 motors on their DEC axis in the AM5 - not sure what’s in the AM5n. Typically Chinese cutting corners ...
In my opinion the SAL-33 is in a different class than the AM5(n) and one of the reasons why I picked it as my first strain wave mount. It’s better designed and engineered than the ZWO mounts, costs about 50% less and by the looks of it has a better after sales support to boot.
I think if you must go strainwave, the SAL would be the way to go.
Anthony (Tony) Johnson avatar
📷 IMG_4488.jpegIMG_4488.jpegNot a very good picture of my setup, but this is my 12” Meade SCT, weight 45lbs, on my AM5 mount with 20lbs of counterweights. Been using this setup for almost 2 years with no issues outside of vibration with a breeze, hence the windshields. I get .45 to .80 arcsecond guiding routinely with a guide scope, not an off axis guider. So as far as weight restrictions are concerned I think I broke the mold on that one. Oh and the 45lb is with the scope alone, not counting the camera, guide scope, crayford focuser and dew shield. So yeah a couple of extra pounds. I have numerous photos taken with this rig on my page, if any of you are interested in how well it does. The scope is over 30 years old, so not the best in coma, no HD and what not, but I’m not complaining. It flips and goes home all by itself with no issues. Took a minute to figure out were to put the counterweights but after that its been smooth sailing.
Disclaimer: This is how I do it, of course I would never recommend anyone doing what I’m doing at all, just showing it can be done. Your results may vary. This pushes the AM5 well past the weight restriction for sure. In my defense though, before I bought the mount I looked up the weight of my scope online. My scope was mounted originally on an LX200 fork mount, so before I bought the AM5 and de-forked my scope, I wanted to know what the weight was. Every where I looked they said the scope alone weighed in at 35 lbs, right at the max limit for the AM5 with all the attachments, so I purchased the mound and de-forked my scope. Then I weighed it by itself and found out all the info I had found was wrong, I thought well lets give it a try and after much trial and error I finally got it to work, and its been working ever since. Again I’m not saying anyone should do this, just that these mounts take way more than they are rated for.
Well written Helpful Respectful Engaging Supportive
Eric Gagné avatar
Maybe the AstroCompulsion syndrome we all suffer from that makes us want to buy new stuff is blinding me a bit here and making me loose sight of the problem I am originally trying to fix.
Even with the scope and counterweights removed this thing weighs 37 lbs and is 5’ high. That’s a pain to take through the door, especially with the 8” doorstep that doesn’t help. The whole idea of changing is to reduce weight but now I’m thinking……. maybe order a SAL-33 and for the 4-5 months I will be waiting for it I could simply replace the cap screws that hold the head to the pier extension with thumb screws and carry the head separately, that would be 5 trips instead of 4……not a big deal.
I would need to make sure the SAL-33 is compatible with the StellaVita though, I’m not ready yet to move to Nina, for that I am waiting for Touch’N’Stars and PINS to be stable.📷 IMG_0637.jpegIMG_0637.jpeg
I’m wondering, and it depends on your situation of course but I never take in my mount, just the OTA. My EQ6 just sits in the back garden with two trash bags over it. Been out there for two years in all weather, no issues.
Eric Gagné avatar
I have been thinking about this but I’m worried about rust. The EQM-35 Pro has metal gears and they are exposed thanks to those external motors. I think they’re made of copper but the connections because the mount controller and the motors are not.
I can obviously keep it away from water but not sure if humidity would create issues.
I haven’t had an issue in Oklahoma but I suppose you could. That said, there are solutions involving covers and low voltage fans that should keep it from becoming an issue. Don’t forget, many of these mounts and scopes spend their entire lives an an observatory that’s unheated, uncooled and not humidity controlled. I really haven’t heard of any issues.
Well written Concise Supportive
Overt racism is not appreciated. Vendors from countries all around the world cut corners.
Robert Lagasse avatar
I have a AM5N which is 33lbs prior to counterweight as its “spec”.
I push well over 30lbs on this mount with my ASKAR130PHQ and hold perfect 0.2 guiding.
I would say no for the % rule like I use on my Celestron AVX
Surge avatar
Glenn Mitchell · May 25, 2026, 10:29 PM
I redacted that statement but they’ve made their own reputation with all the cheap knockoffs, fakes and in many cases cutting corners.
Michele Campini avatar
I've read something that suggests the AM5 motors are buggy or weak.
I want to tell you about this.
A few days ago, I accidentally aimed the asiair at an object that hadn't yet risen, so the mount pushed into the wall of my balcony and, using the declination lever, lifted everything below it by about 2 cm. Then the safety clutch engaged and it stopped.
So, there were the following to lift:
- 10 kg of the 200/800 Newtonian telescope and the optical train;
- about 11 kg of the mount, extension, and counterweight;
- about 6 kg of that square structure underneath;
- 15 kg (3 cast iron disks) placed at the bottom as ballast.
As far as I'm concerned, instead of the NEMA17s, they could have easily used NMA14s; they still had plenty to spare.
Well written Engaging
Michele Campini · May 27, 2026 at 10:29 AM
That’s exactly what happened till I got the weights I used for my 12 inch SCT to “balance” out the weight. The safety clutch would engage and the scope would stop, once I got the “sweet spot” for the counter weights figured out I’ve had no issues. So yeah IMHO the mount is very capable. Like I said, with counterweights and scope with accessories I’m over 66 lbs in total. Guiding on a good night is as good as anybodies I read about. Can even get to .33 arcseconds. How much better do you need it.
TimW avatar
Eric Gagné · May 23, 2026, 07:34 PM
I have the same mount and, while I’ve been happy with it, and have learnt a lot from using it, I’ve ordered a new harmonic mount. A bit lighter overall and more accurate guiding means it should be an interesting move.
Well written Respectful
