Troubleshooting C9.25 EdgeHD collimation and star shape issues
5 replies61 views
Chase Davidson avatar
Hi everyone,
I’m relatively new to imaging with SCTs and recently picked up a Celestron C9.25 EdgeHD after primarily working with refractors. I’m hoping to get some help troubleshooting a couple of issues I’m running into.
Current Setup
  • C9.25 EdgeHD
  • 0.7x focal reducer
  • Celestron T-adapter
  • ZWO OAG-L
  • ZWO 2" filter wheel
  • ZWO ASI2600MM Pro (recently serviced)
  • ZWO EAF
  • Guide camera:
    • Previously: ASI120MM
    • Just upgraded (haven’t used yet): ASI174MM Mini
  • Bob’s Knobs installed for collimation
I’ve confirmed backfocus with Celestron support, so spacing should be correct. It doesn’t help I’ve had two clear nights in the last 2 months of owning this new scope but here are my questions:
Question 1 – Collimation / Star Shape Issues
I’ve been working on getting my C9.25 EdgeHD properly collimated, but I’m struggling to produce clean, round stars. After several attempts at collimation (I’ll attach my most recent images), I spent about three hours collecting test data and still ended up with stars that have unusual or distorted shapes across the frame. The issue doesn’t appear to be isolated to one area of the image, the stars just don’t look quite right overall.
Since I’m new to SCTs, I’m not entirely confident that I’m approaching collimation correctly, even after upgrading to Bob’s Knobs to make adjustments easier. I’m unsure whether what I’m seeing is truly a collimation problem or if something else in the imaging train could be contributing, such as backfocus, tilt, or even guiding-related artifacts. At this point, I’m trying to narrow down whether this is user error on collimation, a setup issue, or something inherent to the optical configuration.
For those with more experience using EdgeHD systems, what are the most common collimation pitfalls that can lead to this kind of star distortion? Based on your experience, does this sound like a classic collimation issue, or should I be looking more closely at spacing, tilt, or another aspect of the setup?
(See images for examples)
Question 2 – Large Central Bright Spot (Not Removed by Flats)
Since getting my ASI2600MM Pro back from servicing, I’ve been dealing with a large bright spot in the center of my images that is present across all filters. This isn’t behaving like typical dust donuts, it’s more of a broad, centered illumination issue, and my flats are not correcting it. I’ve already gone through and carefully cleaned all of my filters multiple times and verified that there’s no visible dust or debris in the imaging train, but the issue remains unchanged. I’ve also taken new flats under consistent conditions, but the calibrated images still show the same problem.
Because the pattern appears across every filter and is centered in the frame, I’m starting to think it may not be related to the filters themselves. Instead, I’m wondering if it could be something on the sensor-side, such as contamination on the protective glass window, or possibly something more serious with the sensor following servicing. I’m also considering whether this could be a flat-field or illumination mismatch issue rather than a physical contamination problem.
Has anyone experienced a large central bright spot like this that flats couldn’t remove? Does this sound more like a calibration issue, or something related to the sensor or its protective window? Also, if cleaning is warranted, is it safe to clean the sensor on the ASI2600MM Pro, and what’s the best approach to do that safely?
Thanks for all your help!
Chase
Well written Respectful
voigtm avatar
One thought- are you using a Celestron dew heater ring, and if so, what power level ? There are a number of reports that you can get spikey stars when using a too-high level of heating using the dew rings.
voigtm · May 19, 2026, 06:00 PM
Great point! I do have a celstron dew heater ring. I completely forgot about that. I will try to reduce the power to it and see if it effects anything.
Respectful
voigtm avatar
Good luck !
Brannon Quel avatar
I have the non-edge 9.25 with the dew heater ring. I live in Central Florida and overnight temps are almost always at or below the dew point. I have a basic Pegasus dew zap controller with a simple dial and I keep it at about 25%, no dew at all and no spikey stars.
Well written Helpful Respectful Concise Engaging
Paul Larkin avatar
Hi, Chase.
I have an EdgeHD 8” with otherwise the same setup as yourself and struggled with start shape even with great (doughnut) collimation for a couple of years. The main problem turned out to be the correcter plate was shipped slightly rotated from its proper position (there are pen marks on the glass and tube which should have been aligned). But once that was sorted, there are still a couple of other things you might try (which have certainly restored my own sanity):
(a) If too hot, the dew heater ring can cause distortions, as others have mentioned. I have removed mine and gone back to a strap around the dew heater shield (I have read that all we need is the air in front of the glass to be above dew point. In any case, it works well).
(b) Knobs, which you have done. So much easier and no risk of damage with a screw driver.
(c) Use a Tri-Bahtinov mask, which is designed for collimation. But it is so much better with …
(d) … the SkyCal software (free and really works). SkyCal with the Tri-Bahtinov mask makes the process so much more ’enjoyable’. And it will also help you use the doughnut method if you want as well. Here is some info: https://www.cloudynights.com/forums/topic/987005-skycal-focus-and-collimation-software-v40-release/
I use SkyCal with theTri-Bahtinov mask first and get that spot on. Then check with the doughnut method to confirm. If one is good and the other not, then there is likely some other issue (in my case misaligned corrector plate, which is hopefully not your case).
Hope that helps.
Cheers.
Paul
