Steve Heath · May 28, 2026, 09:06 PM
pfile · May 28, 2026, 07:19 PM
ok so i guess it’s the PI application itself that can’t delete the file. you can try opening that folder in the finder and see if you can delete the file(s) yourself… if you copy everything from /var to ..Cleaner/ (highlight the path, right click, select copy) then in the Terminal application say “open “ (no quotes, but put a space after open) and paste the path, you should get a finder window there. then you can try trashing that file that PI can’t delete and see what happens when you empty the trash.
chances are though when you try to check for updates again it will die on a different file, so you might have to keep deleting stuff on PI’s behalf.
this is a new one; the PI application should be able to delete those files, since it also created then. not sure at all what’s going on here but it’s par for the course with PI.
Well, I tried doing what you suggested in Terminal and it came back with no such file exists. If only I could go back in time and not upgrade to 1.9.4 Nothing but new problems everyday. Until going to 1.9.4, my Pixinsight experience was awesome. I applied for a Pixinsight Forum account last week but I’m still waiting for my “approval”. Doesn’t matter, I’m guessing the response to this issue would be much the same as I see with others, “not a bug”….
yeah you probably won’t get support for this. the reasoning goes that juan would never release a piece of software with this bug, and it didn’t happen on his computers, therefore it’s something specific to your computer which you need to figure out.
which 1.9.4 are you using? arm64 or x64? just out of curiosity.
i guess there’s a chance deleting the PI application and reinstalling will resolve this problem. your settings file is not affected by deleting PI and reinstalling, but if you want to be safe, you can go to the manage repository dialog and click save, then give any filename you want in any directory but the /Applications/PixInsight directory and save your repositories.
that way if somehow your settings file does get corrupted or erased you can restore your repositories by loading them from the file you saved.
