New Askar 50p telescope: solving star halo problems
7 replies96 views
Wandrille VINCENT avatar
Je viens de tester ma nouvelle Askar 50p et j’ai un problème de halo autour des étoiles. Y-aurait-il une solution pour résoudre ce problème?
📷 WhatsApp Image 2026-05-14 at 11.46.33.jpegWhatsApp Image 2026-05-14 at 11.46.33.jpeg
What camera and filter, if any, did you use?
J’utilise une 533 MC pro. Pour cette photo je n’avais pas de filtre.
You should always use an UV/IR filter in front of this camera’s sensor as their windows are just AR treated. The glow surrounding the brighter stars is just a reflection of the out-of-focus IR light from this doublet lens. Your colors are also affected by the IR leak.
Well written Helpful Insightful Concise
If I use a different filter, such as a narrowband filter, will the problem go away?
Hadi Zaheer avatar
Wandrille VINCENT · May 14, 2026, 02:30 PM
Yes, it will do. Any filter which cuts out UV and IR will be fine. This should be the case for narrowband filters as well. You can always look at the bandpasses (if provided) for a particular filter to be sure.
Well written Helpful Respectful Concise
So the problem is just because I don't have a filter?
Hadi Zaheer avatar
Essentially yes. Like Andrea said, the sensor window on this particular camera (among others) doesn't cut out UV and IR. So without a filter the camera sensor picks up those wavelengths. As the refractor isn't corrected for such wavelengths, they will give you the bloated stars.
