Chuck Schreiner avatar
For the first time, I had several satellite trails that didn’t get handled in WBPP in Pixinsight. The only thing I know that I have recently changed in the settings was I set image integration minimum weight to 0.
This was a multiple night data gathering and the last night had a bunch of trails in the subs. But I have of course had satellite trails before that were totally handled by WBPP.
It’s fine - I got rid of them in photoshop. But any ideas why this might have happened? (I had all the calibration frames - flats, bias, darks)
Well written Respectful
HR_Maurer avatar
If there are satellite trail artifacts present, usually the rejection statistics in the image integration is the thing you should look for. However, statistics can work if there is enough data to get a reasonable mean, and identify the outliers. So the amount of valid subs is a crucial quantity. If you set the integration minimum weight to zero, it could be that the algorithm rejected too much data, and you’re left with a too small amount of data to reject these trails. The trails are simply not longer identified as outliers, but as signal. Possibly, your sky quality changed during exposure, which can make rejection more unreliable even with proper image calibration.
If you have the possibility to add more data, i would suppose to do that. If not, you can try tweaking the integration / rejection settings. Maybe also trying median instead of mean. In my experience, this can improve things a bit, but you shouldnt expect a wonder. And all the integration settings available today are quite complex, due to the sheer amount of different available rejection algorithms.
If your sky quality changed, you might also try local normalization. In my experience, this is something WBPP didnt do well in the past (so i dont include it in my WBPP workflow anymore, and do it “manually” instead).
Well written Helpful Respectful Engaging
ItsMeAstro avatar
I’m using a great AI tool from Seti Astro to remove satellite trails : Cosmic Clarity Suite
See :
https://www.youtube.com/watch?v=kSee0w2cse8
and
https://www.setiastro.com/cosmic-clarity
HR_Maurer · May 13, 2026 at 08:34 AM
I think I have ample subs (5-6 hrs). There was a lot of variance in the sky - 3 different locations, 4 different nights (and one night with shorter exposures).
I haven’t done the WBPP processes manually in a long time. So, the way you do it is to process up to local normalization, then do that, then restart at image integration?
Thanks
ItsMeAstro · May 13, 2026 at 09:03 AM
See :
and
I will check this out. Thanks. (Except with the new Pixinsight update - I read that SETI tools won’t run on Macs …I hope this is wrong)
HR_Maurer avatar
Chuck Schreiner · May 13, 2026, 01:44 PM
Thanks
hi Chuck,
my problem is, in between two deep-sky image session, there is at least one PI update, and a lot of things changed since i used it last time. So i try to set up WBPP, run it, and often end up starting over after image registration, or doing everything “manually”. I’m often not up to date with the newest PI developments in recent years. It is partly because of weather conditions, partly because the sky quality at home got worse, and partially because im growing old.
Respectful
HR_Maurer · May 13, 2026 at 02:26 PM
hi Chuck,
Exactly my issue, too. Between weather, sky quality and getting old - I mean it took me 2 months to shoot 6 hours!
Respectful Supportive
