Hi everyone,
I'd like to reach out to the community for advice before finalizing my equipment choices.
My background:
I'm an amateur astrophotographer based in the French Alps (Savoie, 45°N). For the past 3 years, I've been using a Vaonis Vespera 1, which has been a fantastic tool for discovering deep sky imaging — I'm genuinely grateful for what it taught me. However, I now feel limited in my practice: no planetary imaging, no ability to swap tubes, and little flexibility overall. I'm looking to move to a more modular setup.
I'm not after the "best" setup on the market — just the right one for my actual use case: backyard sessions in the Alps + occasional car-accessible dark sites, planetary imaging of Jupiter, Saturn and the Moon, and more technical deep sky work with the flexibility to swap optical tubes. I plan to sell the Vespera to help fund the new setup.
The setup I have in mind:
ZWO base:
- ZWO AM5N mount (harmonic, 15kg payload without counterweight, EQ/AZ mode)
- ZWO TC40 carbon tripod
- ZWO ASI585MC Air (IMX585 4K + integrated ASIAir + integrated guiding + TEC cooling)
- ZWO EAF focuser
Optical tubes (used alternately):
- Askar FRA500 (90mm f/5.6, 500mm, APO quintuplet, integrated field flattener) for deep sky
- Skywatcher Maksutov 180/2700 for planetary
Total budget: ~3,600€ | Net after Vespera sale: ~3,000€
My questions:
1. Does this setup seem coherent for my use case?
2. Can the AM5N comfortably handle the Mak180 (7.8kg) without a counterweight?
3. Is the ASI585MC Air suitable for both high-frame-rate planetary imaging and deep sky with the FRA500?
4. Is the FRA500 a good choice as my only deep sky refractor, replacing the Vespera?
5. Are there any missing accessories you would recommend?
I'd really appreciate any feedback on this Vespera → modular setup transition, especially regarding the AM5N + Mak180 compatibility and the ASI585MC Air for planetary use.
Thanks in advance!
Especially take note of the dynamic range. When doing comparisons it matters very much which version you’re talking about.
