Darker or brighter background: which looks better?
20 replies710 views
Which Backgorund Do You Prefer?
Single choice poll 98 votes
77% (75 votes)
23% (23 votes)
Interactive Sky avatar
Which background do you think looks better, darker or brighter?
Darker 📷 2026-04-30T17.34.25.png2026-04-30T17.34.25.pngBrighter 📷 2026-04-30T17.34.45.png2026-04-30T17.34.45.pnghttps://app.astrobin.com/u/InteractiveSky?i=zmvbuc
I don’t think backgrounds should be completely black but achieving that is very dependent on the quality of your skies and data. I know for myself, shooting under B8 skies, Pulling the black point of the background is sometimes the only way to get rid of the low frequency gunk that lurks there. I also don’t think that background brightness needs to go too far. A value of around 15 is enough. You want it up a bit just so as not to destroy the very faintest of detail in an image. It’s a dance to be sure.
Well written Helpful Engaging Supportive
Anderl avatar
something around 20 measured with the little pipette thing in photoshop or affinity.
i like adding a layer (photoshop / affinity) colored in my target value, inject some noice (similar to my picture) and add it so that no area within my picture has any darker spots
Andrew avatar
Depends on the subject
Galaxy with few background things - dark
nebula with lots going on - light
SonnyE avatar
In the examples given, I prefer the brighter and voted accordingly.
But it comes down to a matter of taste, or sometimes a lack there of.
I don’t dabble or try to make a silk purse out of a sows ear. I’m a Post Processing minimalist. I want what my camera see’s, not some tooty-fruity Skittles rendition.
But that is just me.
TiffsAndAstro avatar
Interactive Sky · Apr 30, 2026, 05:36 PM
These both look dark to me :)
Spacey avatar
The darker one and you can probably push your data even further in the stretching
John Hayes avatar
The background level that we all perceive will vary with variations between monitors and room lighting. The better question to ask is, “What should the background level be for a galaxy image?” So, have you looked at this presentation?
https://www.youtube.com/watch?v=1XBon7x6kio&t=2562s
The guy who gave this talk goes into some detail about how to get the background right for a galaxy image with respect to the color and the brightness level.
Craig Towell avatar
Hugely depends on viewing device. On my monitor I will process a perfect background with the correct ADU value but when I view that image on my phone or iPad it looks horrendously bright, so I often make two versions
Helpful Respectful Concise Engaging
Dave & Telescope avatar
I’m generally setting galaxy background a little lower, around 0.08-0.09 average. Nebula fields are brighter, at least 0.15 or more depending on the target. Some variability exists depending on target but in general for me galaxies a little draker than nebulae.
Dave
Franco Grimoldi avatar
The “bright” one seems to be showing more information and looks way more natural.
Interactive Sky · Apr 30, 2026 at 05:36 PM
Both of these are too dark.
Claudio Pedrazzi avatar
That’s an excellent question—one I’ve asked myself countless times as a complete beginner. In my opinion, it’s also a matter of personal taste! Recently, I was thrilled to have achieved what I considered a much better processing result on the Nebula Headphones, but a more experienced amateur astronomer friend told me, “The background is too dark!” And I still like the image with the dark background! Finally I uploaded both of them in my gallery as different versions.
Well written Respectful Concise Engaging Supportive
Willem Jan Drijfhout avatar
Perception of darkness/brightness is also very dependent on the background you’re showing your images on. On a white background a darker sky can look unnatural very quickly. On a black background, a somewhat lighter sky may look a bit more washed out.
Other than the question ‘what darkness level is best’, I find it particularly important that in a portfolio of work the darkness is more or less the same throughout. A standard step for all my images is to apply in the end BackgroundNormalization set to ‘target background’. My setting there is 0.07, which is a bit darker than your bright, but quite a bit lighter than your dark.
Well written Helpful Respectful Engaging Supportive
John Hayes · May 2, 2026 at 05:14 AM
“The guy who gave this talk…” 😀
Can definitely recommend the presentations from ‘that guy’. They’re often pretty good.😉
Claudio Pedrazzi · May 3, 2026, 12:18 PM
I second image ( to me, on my screen) looks hugely better. I can see two open clusters, it gives the image context.
Coincidentally I'm trying to process this same target and it sucks :)
Astro Hopper avatar
I have created some PI scripts to help me exactly with background when stretching photos. This video is presentation of this scripts!! https://youtu.be/uV2HI0TdNn0
Anthony (Tony) Johnson avatar
I believe that unless you are going for IFN or you are photographing an area of sky that has nebulosity in it the sky background should be black, and even then a black background makes your faint details stand out more, maybe not to the point of clipping your blacks, and I believe that even these areas benefit from added contrast, but I’ve see way too many images on astrobin that just look washed out because they failed to add the contrast needed to bring out the color along with the faint details. The colors that we strive so hard to achieve with selective processing, are just muted to be point of looking bland, looking as though there is a piece of wax paper place over the image. I also believe there is a misconception going around that if I make my sky background too dark I will loose the finer details, I believe the opposite is true, by leaving your sky background bright you are actually loosing detail in the finer gaseous areas, plus washing out your color. Also you are leaving so much “on the table” as it where by not exploiting the tonal range of your image. We spend hundreds of dollars on filters that block light pollution so that it doesn’t add brightness to our images through light pollution, but then we introduce brightness or don’t reduce it through our processing. I feel this is counterproductive to our efforts to bring out the different colors we spend hours upon hours trying to capture only to be left behind from some notion that a dark sky background is bad. I heard a very prominent astrophotographer say one time that the sky isn’t black. I beg to differ. All we hear is get to a dark sky site to get the black skies, spending hundreds of dollars every month to send out scopes to a dark sky site to take advantage of “dark skies”. Sure there’s always air glow and some form of light pollution in the air no matter where we go, but should we leave it in our images just because its there. I don’t think so. Well thats the way I see it, I’m sure some will disagree. Everyone had their own take on how images should look and there is no hard and fast rule in processing. This is just one opinion.
Just remember when you go to a jeweler to purchase a diamond, let say, he doesn’t show it to you on a white background, he puts in on the black velvet to revel its luster and sparkle, These images that we fuss over and like I said before, spend thousands of dollars, and spend countless hours over multiple session teasing out the hidden gems in these objects, shouldn’t we do our best, like the jeweler, to show them to their very best.
Anthony (Tony) Johnson · May 4, 2026, 02:46 PM
The only way to make the background black is to clip the left edge of the histogram and lose data. You can make it as dark as you’d want within the bit depth of your image via histogram, curves, GHS, all without clipping.
A pure black background is the equivalent to a complete silence in a recording, it can never be achieved without losing data and it feels very unnatural.
Well written Helpful Insightful Respectful Concise Engaging
Bill McLaughlin avatar
This is one of those questions with a simple answer - that does not satisfy those wanting simple answers.
“It depends” 😉
“For every complex problem there is an answer that is clear, simple and wrong.”
― H. L. Mencken
Well written Engaging
At the end of the day, It really comes down to the intent of the photographer and the limits of the data. The sky background has a certain look to it through a telescope visually that’s very dependent on sky conditions and magnification so you might try to replicate that. Astronauts report that visually, it’s the blackest black you can imagine, you can try and replicate that. The bottom line is that while there is a well repeated rule that it should never be black, there can be reasons for it to be. I agree that actual data should never be clipped but a dark background doesn’t necessarily mean that it is.
It reminds me of the common opinion that images should never be totally noise free even though noise is a camera/processing artifact, not a quality of the object itself. I really don’t think we should cling so tightly to absolutes in this hobby. Cases like actually clipping data, getting good focus, having round stars are and should be, non-negotiable. Other areas like noise, density of sky background, saturation and interpretation of color, is a lot more grey and open to the vision of the artist.
Advice needed on hard printing of a specific image
I’m looking for an advice to order a print of an image that you can hang on a wall. I wanted to print few images from time to time as a gift but did not feel like printing a version of traditional DSO object would be a unique enough. There are millio...
Relevant for understanding print appearance differences across media types.
Feb 19, 2026
Imaging narrowband versus a 'darker' sky location.
Hi all, If I am imaging with 3nm filters (either mono or OSC) say from a Bortle 6 location - no moon (my garden). Would using the same filters/cameras in a Bortle 4 location provide much better data, worth travelling to…. or would it not be really as...
Directly addresses darker versus brighter imaging conditions and their effects.
Oct 23, 2025
