Tracking /Guiding issues half way through an Imaging session.
19 replies141 views
Seany75uk avatar
Hi guys I’m having issues with my tracking/guiding overnight and its really got me stumped.
I’m using thee following equipment
Skywatcher HEQ5 pro
Skywatcher Evolux 82ED
Player One Uranus C Pro
SVbony SV165 30mm guidescope
ZWO ASI662MC Guide camera
Controlled by an Intel N150, 16gb Ram Windows 11 Mini pc running NINA , PHD2 and greenswamp server
I’ve been imaging LBN 576 over the past month or so when weather permitted. I have my sequence set in NINA which I set off as soon as its dark enough I’ll be at the PC for a few hours after starting the sequence and it is all going great until after I go to bed. First hour or so guiding is excellent 0.2 - 0.3 RMS then meridian Flip works fine guiding isn’t as good but still reasonable between 0.5.and 0.7 RMS. All seems well so I go to bed and get up in the morning to the majority of the subs after I went to bed looking like the attached ones.
I can’t figure it out it as I always run my Seestar S30 at the same time (30 second subs in EQ mode) and that’s running its plan all night without issue, I’ve had probably 4 times the integration time from the seestar than I have over my main rig and it’s pretty frustrating.
Can anybody advise me please before I sell up and buy more Seestars 😂
Thanks
Sean
📷 2026-04-25_02-10-43_Oiii-Sii 7nm_-10.00_300.00_0138.jpg2026-04-25_02-10-43_Oiii-Sii 7nm_-10.00_300.00_0138.jpg
📷 2026-04-25_01-59-14_Oiii-Sii 7nm_-10.00_300.00_0136.jpg2026-04-25_01-59-14_Oiii-Sii 7nm_-10.00_300.00_0136.jpg ones📷 2026-04-25_02-27-09_Oiii-Sii 7nm_-10.00_300.00_0141.jpg2026-04-25_02-27-09_Oiii-Sii 7nm_-10.00_300.00_0141.jpg
Respectful
dayglow avatar
I suggest using PHD LogViewer to examine the PHD2 log file for events at the time tracking was lost.
Check to see if PHD was actually guiding and that the SNR reported for the guide star(s) was decent.
Well written Helpful Concise
Seany75uk avatar
dayglow · Apr 27, 2026, 07:05 PM
Thanks just had a look and it lost the star at 1:38am and never recovered I have set a trigger to restart guiding in NINA too. The seestar managed fine a few dropped frames but nothing drastic.
Sean
dayglow avatar
Remember to slew back to the target before restarting guiding.
Well written Respectful
Seany75uk avatar
dayglow · Apr 27, 2026, 07:33 PM
I have a trigger set up to recentre on drift too, I assumed that would cover it.
Ron avatar
You might need to click on “reverse DEC” on flip in PHD2.
Guiding will “work” fine initially as long as no corrections are made. Once you start getting DEC corrections, the star will move in the wrong direction unless the reverse Dec in ticked.
Ron
Ron avatar
Recenter on drift won’t work because the smeared subs can’t be solved, so the software has no idea where it’s pointing.
Seany75uk avatar
Ron · Apr 27, 2026, 08:54 PM
Ron
Thanks Ron I'll check that out.
Sean
If you have good guiding for awhile after the meridian flip (> just a min. or two) than it’s not a reverse after flip issue. The PHD2 logs are where I suspect you’ll find your answer. If it keeps loosing lock than the most likely culprits are clouds or a cable pull. The fact that the SeeStar also lost frames at the same time is telling. I would check your cable management and have another run, stay up and observe the system.
Helpful Concise Engaging
Seany75uk avatar
Tony Gondola · Apr 27, 2026, 11:05 PM
I'm not sure the seestar lost frames at the same time but it didn't loose frames for any where near the amount of time my main rig did. Cable management is OK there's no way any of them can catch I've always been very conscious of that. After looking at my PhD logs it seems to be clouds but it never seems to refind a star after it loses it but the seestar does no problem. Supposed to be clear tonight so will see how I get on.
Thanks Sean
That would point then to something in the way your NINA script is written. The “Restore Guiding” command must be in the triggers section so that it checks guiding with every loop.
You also need to understand that the SeeStar doesn’t really guide at all. Once it solves and starts imaging, it blindly just drives, rejecting bad frames as it goes. It runs a plate solve every few frames to recenter in place of guiding. Because of that, you would expect that it would keep going under conditions that would stop a rig that actually is guiding.
Well written Helpful Respectful Engaging
Alex Nicholas avatar
I would say PHD2 is not configured to rotate the calibration data after a meridian flip, as a result, you’re you’re getting good guiding up until the meridian, then the scope flips, and every guide correction being sent to the mount is the opposite of what’s required, thus, it’s pushing you constantly away from the guide star.
If that were true the OP would have seen it immediately after the flip which as I understand it, wasn’t the case.
Ron avatar
Sorry, Tony, but I disagree. If one’s mount tracks well and is well polar aligned, there should be no drift and therefore no DEC corrections. I personally have seen this exact behavior with my mount. It can go for quite some time before any DEC corrections are made, and then it goes crazy.
It’s easy to test. Calibrate PHD2 on one side of the meridian, then try to guide on something on the other side. All the better if the polar alignment is a little out. Let it run long enough to see several DEC corrections and see if they go in the correct direction. If not, then the tick box needs to be toggled.
Well written Helpful Engaging Supportive
dayglow avatar
There is a setting in PHD2 to determine whether the program takes meridian flip into account when generating guide commands.
Well written Respectful Concise
Brian Puhl avatar
There’s alot of speculation in here, but we’re beating around the bush a bit. If you drop a PHD log in here, I can tell you exactly what happened and steps to fix it.
Ron · Apr 29, 2026, 12:43 AM
All I can say is no matter how good my PA gets, I have never seen a case when there are no DEC corrections, both + and -. Maybe it’s possible but I’ve never seen it.
Brian Puhl avatar
Tony Gondola · Apr 29, 2026, 03:33 AM
Ron is correct, to a fault. Seeing can, and will affect the declination corrections. Your consistant back and forth corrections are just your mount chasing the seeing conditions. In a perfect world, if seeing was perfect and polar alignment was perfect, you would never see any declination corrections. I have seen plenty of nights where I can go for quite awhile without seeing dec corrections, but it’s rare as well. If I was using a high end mount and longer guide exposures, I’d probably never see them.
Now the other half of that story is if you do see a constant correction in one direction on declination, or when the majority of the corrections are on one side, this is high indicative of bad polar alignment. Generally speaking most mounts can guide through this, but at the end of the night you’ll find alot of field rotation in your images.
Seany75uk avatar
Brian Puhl · Apr 29, 2026, 11:23 AM
Thanks I'll double check my polar alignment, it's been fine. I used 3 point polar alignment in NINA done the process twice and the mount hasn't been moved since it just gets covered when not in use.
Sean
Rotation shift after meridian flip (no electronic rotator)
Hello, I recently noticed that during my last two sessions of shooting that I experienced a shift in the field rotation after the meridian flip. All images taken before the meridian flip are same orientation and matches with framing assistant, and al...
Meridian flip issues relevant to overnight tracking problems with HEQ5.
Oct 28, 2025
After Meridian Flip ZWO AM5 Stops Tracking
After Meridian Flip ZWO AM5 Stops Tracking Everything is fine, till I do the flip Scopes: Stellarvue SVX130T / Flattner: SFFX3 Focusers: Feather Touch 3.5 Cameras: ASI2600MC Pro Filter Wheel: ZWO 7 2" filters Off Axis Guider: ZWO Lg OAG, ASI174MM Con...
Post-meridian flip tracking failures similar to author's overnight tracking issues.
Oct 17, 2025
Round stars using a guidescope at 1000mm - possible?
Hi All, I recently bought a ZWO FF130 to supplement my great little FF65. Normally with the smaller scope I’ve been getting good guiding with the ZWO 30F4/ASI120mm combo of between 0.5”—0.8” RMS. This is all sitting on an AM5N/TC40 (with weights in t...
Guiding performance optimization with guidescope setup similar to author's configuration.
Feb 5, 2026
EQ6R-Pro disaster
Hey all, Last night I had a big issue with the system while it was imaging overnight. (EQ6R-Pro, ASIAIR plus, 150PDS, ASI120 mini guidescope) From looking at the log, guiding was great throughout the night (0.6RMS average) until suddenly the RA went ...
Overnight imaging system failures with similar equipment and guiding setup.
Sep 23, 2025
