Bigger scope for Jupiter imaging or dedicated cooled astro camera for DSO
18 replies146 views
Mark Worthington avatar
I have a budget that can be assigned to another bigger scope or to an Asi533mc pro.
Case for bigger scope : I can’t get details on jupiter, such as festoons with my 250pds,mounted on AZEQ6, camera Asi662mc, uv/ir cut filter, 2.25x Baader Barlow, 15000 frames, 10-15% stacked in autostakkert, wavelets in Registax. Jupiter > 40° altitude. Despite being sure the GRS was well focused. Only option left is to focus on a nearby moon, and try again. I’ve not seen many if any good images taken with the 250pds,but have with 12” F5.3. This is too heavy for me though. Other options, orion optics VX12 or VX12 L. C11 has lots of good images.
BUT, I’d like your opinion on whether i’m hitting issues with atmospheric issues here, in which case a larger aperture won't help. Perhaps an adc, but not sure, as I csn’t see any hint of festoons at all. Surely, the 250pds should be capable of showing the festoons.
Case for better astro camera: the Asi662 mc is too small. My D7000 is larger sensor, but not nodded. Asi533 mc pro looks a very good balance, and is next big step up. I have an asiair plus, several scopes.
So, which is the wisest choice for capital expenditure? Getting an even bigger scope, with risk that i’ll find it's no better if it's atmospheric conditions causing the issues or going for the Asi533 pro, virtually guaranteed to give better images for dso?
Thanks in advance
Mark
Unless you live in the tropics I’ll opt for the camera,
andrea tasselli · Apr 27, 2026, 06:12 PM
Thanks Andrea.
Tomorrow, I'll have one last opportunity where Jupiter will be around 36° altitude, just when it’s dark enough, but critically, Callisto will be around 10’ from its edge. I’m going to target focus on this moon, drop gain back for Jupiter, don’t refocus and we’ll see what happens. Possibly my last chance before conditions become too poor. Forecast is actually for clear skies too! The stars are aligned. Just need to avoid screwing things up.
Jeffrey Kieft avatar
In regards to planets and detail, this podcast featuring Daniel Mounsey is really worth listening to: https://podcasts.apple.com/us/podcast/the-observers-notebook-seeing-and-transparancy-with-dr-d/id1199301885?i=1000758651935
While it focuses on visual observing, it has great insights into seeing vs. transparency, the effects of tube currents, temperature gradients, etc. and the dramatic effects these have on observing details in planets. One point he makes is that larger aperture is not always better, because bad seeing effects are amplified. He points out how things like shooting over a rooftop or a parking lot a few blocks away vs. over a body of water, how your scope is stored, etc. can make more of a difference than your aperture.
Anyway, it was kind of an eye opener for me.
Well written Helpful Respectful Engaging
Jeffrey Kieft · Apr 27, 2026, 08:50 PM
Thanks Jeffrey
I’ll certainly be listening to that podcast. 👍
Respectful
Rick Evans avatar
I’m not a very proficient planetary imager but I have had a lot of experience this past year using many different scopes and cameras on Jupiter. I don’t really travel anymore and live in a region with perpetually poor seeing. I’ve used everything from 4 inch to 12 inch aperture and various scope designs. I’ve also used most of the more common planetary cameras.
Unless you have access to at least 3/5 seeing on a regular basis I am skeptical that aperture rules. Many will say that lucky imaging technique, done well, can largely overcome seeing problems. My experience is that while this is true up to a point, it was never possible for me to turn 1/5 seeing or 2/5 seeing into a remarkable image of Jupiter.
In my skies I am mostly content with 6 or 7 inches of aperture. For example, although I have my 12 inch scope ready to go… I plan on using a 140mm refractor tonight on Jupiter since seeing is forecast at about 2/5. I think the best you can do is to match your camera sensor pixel pitch to the F number you are imaging at. I think the most used formula is 5*sensor pixel pitch should approximately equal the f number you are imaging at. Another important point in my experience is that when you multiply your frame rate by your exposure time in frames per second, the result should be as near to 1000 as you can get. I am also careful to leave the gain a bit on the dim side to avoid overexposing highlights.
Also, I think a planetary camera is better than a cooled camera. Frame capture rate and many camera parameters in planetary cameras favor imaging something like Jupiter while cooled cameras tend to excel at deep sky objects.
Rick
Rick Evans · Apr 27, 2026, 09:46 PM
Rick
Thanks Rick.
Very interesting experiences! Tomorrow i’m planning on an alternative approach, because calisto will be near disc of jupiter, and i’m planning to go for focus on that moon, not on jupiter. I’ll have a 15-30 minute window.
I think my exposure an frame rate is OK, around 4-5ms and 250fps.Gain around 250. It’s my focus i’m not convinced about.
The comment about the Asi533 was whether I should commit my budget to that, as i’m also interested in dso too, or put the budget towards a bigger aperture. But i’m getting the feeling, that could be unwise,if indeed, seeing is never good enough.
I need to at least be sure i’m doing the best I can with my 250pds though, so i’m seeing-limited, not equipment/ability - limited.
Thanks
Best wishes
Mark
Mark Worthington · Apr 27, 2026, 07:05 PM
You really can’t get diffraction limited images of the moon or planets at such a low elevation. Both seeing and atmospheric dispersion will bite hard. I really wouldn’t bother.
With nearly 10” of aperture you can get good images if:
Your seeing is very good.
Your optics are perfectly collimated.
The subject is high in elevation, preferably >60 degrees.
Your sampling is correct (imaging F/ratio should be 5 to 7 times the camera’s pixel size)
You use proven lucky imaging techniques.
Even with all that, the subject really benefits from larger apertures. The best images seem to come from apertures in the 14 to 16 range, under excellent seeing conditions.
Tony Gondola · Apr 27, 2026, 11:16 PM
Thanks Tony,
To answer the points in order,
Not sure on seeing last time, but was able to crank up mag to 300x without mushy view for once, 40° altitude, f/ratio to 2.9 micron pixel size was 3.6 so undersampling, 15000 frames, 4ms, 250fps. But, i’d still expect to see features like festoons appear, albeit small.
Best wishes
Mark
40 degrees elevation is too low, even if the seeing in good. Planets and lunar hard, you’ll shoot many sessions before everything lines up for you. You do need to stack the odds as much as you can.
Tony Gondola · Apr 28, 2026, 12:28 AM
Thanks, do you have any experience of adc to partially compensate for lower altitude?
Mark Worthington · Apr 28, 2026, 12:59 AM
I believe they work well but I don’t have any experience with it myself.
Well written
You’d better use one having the experience of aligning it with the horizon as it goes tracking the planet or you can forget about blue features at 36deg altitude. IOW, you can’t improvise with these things. And I very much doubt that focusing on a satellite will help you out, your best bet is to focus on the planet’s limb. That’s why my recommendation is to switch to DSOs and forget about planets unless you live in the tropics so you’ll always have planets around in the right conditions to improve your skills.
TiffsAndAstro avatar
Do you have an eaf for you scope? Not so much for the auto Focus, more not having to touch the focus knobs by hand?
For £60 ish might be worth trying first.
TiffsAndAstro · Apr 29, 2026, 07:26 AM
No. I’ve assumed the focusser knob might be too stiff for it to turn on my 250pds. Would this go onto the rough focusing or fine focusing knob?
Jeremy Jackson avatar
What framerate are you seeing with your camera and ASI Air?
Well written Respectful
Jeremy Jackson · Apr 29, 2026, 10:40 AM
Currently i’m just doing planetary, well Jupiter specifically. Around 250fps at ROI 640X480
Wow that is pretty good.
Doing solar work with 432MM camera and ASI Air, I would see 120+fps for a few seconds and then would drop down to 10fps. I switched to a PC running SharpCap because of the frame rate I was seeing on ASI Air.
Jeremy Jackson · Apr 29, 2026, 01:57 PM
Yes, the planetary cameras like the Asi662 can certainly shift! I have an asiair, but it's not been used in anger yet, i’ve been focusing on planetary and for that I've always used sharpcap with an old laptop outside. I’ll be switching to dso soon. I’d really like to get the cooled Asi533mc for that, as the Asi662 won’t cut it. Too small! Maybe could be used for small galaxies though.
Concise Engaging
