Introducing AMSP: Automatic Multi-Session Processing script for Siril, fully automatic
12 replies205 views
Cyril Richard avatar
Hi everyone,
I’d like to share a new Siril Python script I’ve been working on:
AMSP – Automatic Multi-Session Processing
This script is designed to fully automate the preprocessing workflow, with a strong focus on simplicity and robustness.
The idea is straightforward:
  • no manual sorting
  • no complex setup
  • just drag & drop your data into Siril and let the script handle everything
AMSP relies entirely on FITS header keywords to organize and process your data automatically. As long as your files contain properly structured metadata, the script will take care of the rest. It works particularly well with acquisition software like NINA, CCDciel, ASIAIR, and likely many others.
All sessions are automatically combined per filter at the end, so you directly get your final stacked images.
Key features
  • Fully automatic workflow based on FITS headers
  • No need to sort files manually
  • Multi-session support out of the box
  • Designed to be beginner-friendly while remaining powerful
Note: the script requires FITS files with proper header keywords. It won’t work with files lacking this information.
I’m also sharing a video from DeepSpace Astro that demonstrates the workflow and helps understand how it works in practice.
Feedback is very welcome 🙂
https://www.youtube.com/watch?v=80LwMI-WEJE
Well written Helpful Respectful Concise Engaging
This is a big step up for Siril. Bravo for doing it!
I just ran an OSC data set through this and it completed the job in about the quarter of the time it took WBPP. The stars were also very slightly tighter. I think this is a game changer for Siril users, especially for people processing complex narrowband or mono data sets.
It really makes me happy to read what you've written :)
I'll update my script regularly as soon as I receive bug reports.
Well written Respectful Engaging Supportive
Fabrice Lamidey avatar
This is awesome Cyril! Thank you.
I have a couple suggestions : an apostrophe in the file of folder name will halt the process (Bode's galaxy for example) so maybe treat that case.
A failed plate solve will stop the whole process while it could finish without a solution… maybe offer it as an option.
Xisf support would be awesome for people migrating from WBPP who enjoy the compression.
Thanks again!
Helpful Respectful Concise Engaging Supportive
Hello. Thx for the feedbak.
Fabrice Lamidey · Apr 29, 2026, 02:40 AM
OK, I will have a look.
Is is an option. Disable distortion correction.
I’m sorry but this is unlikely to happen. However, you can batch convert your XISF into FITS right before in the Siril conversion tab.
Should be fine now.
patrick cartou avatar
Hi Cyril
I come to test this script and …. “plate solve failed”.Capture d’écran du 2026-04-29 17-41-26.png
What may I do ?
Thanks by advance (merci).
Patrick
patrick cartou · Apr 29, 2026, 03:44 PM
What may I do ?
you could uncheck the distortion correction in the preferences.
Merci Cyril pour la réactivité, je vais essayer ce que tu me dis.
Je te mets le copier-coller des dernières lignes du terminal:
17:37:40: 🗑 Removed: masters
17:37:40: ━━ Phase 5 – Register & Stack ━━
17:37:40: M 63/—/120s: 1 session(s), 58 frame(s)
17:37:40: Exécution de la commande : cd
17:37:40: Définir le répertoire de travail à '/home/cartou/Images/_preproc/process_M_63_nofilter_120s'
17:37:40: Définir le répertoire de travail à '/home/cartou/Images/_preproc/session_2026-04-15/light_M_63_nofilter_120s'
17:37:40: M 63/—/120s: single session, no merge
17:37:40: Exécution de la commande : load
17:37:40: Lecture FITS : fichier pp_light_M_63_nofilter_120s_00001.fit, 3 canal(aux), 3840x2160 pixels, 32bits
17:37:40: Exécution de la commande : parse
17:37:40: Chaîne d'entrée : $RA:ra$_$DEC:dec$
17:37:40: Chaîne de sortie : 13h16m59s_+41d55m04s
17:37:40: Exécution de la commande : platesolve
17:37:40: Utilisation des coordonnées de la cible depuis l'en-tête de l'image : 198.977687, 42.015405
17:37:40: Utilisation de la taille de pixel de l'image : 2.90
17:37:40: Utilisation de la longueur focale de l'image : 1399.00
17:37:40: Résolution astrométrique de l'image de en ligne Gaia DR3 (via Vizier) pour un champ de vision de 0.52 degrés, en utilisant une magnitude limite de 20.55
17:37:40: Findstar : en cours pour le canal 1...
17:37:40: Définir le répertoire de travail à '/home/cartou/Images'
17:37:40: ↩ Returned to working directory: /home/cartou/Images
17:37:41: _preproc directory removed.
17:37:41: Siril error: Command 'platesolve' failed: Generic error
A +
Patrick
Je ne trouve pas dans Préférences l’équivalent de “distortion correction”…où dois-je chercher, Cyril ?
J’ai aussi fait un autre essai et regarde dans le tout début de l’exécution du script, apparemment j’ai un souci avec GTK:
8:10:48: Mise à jour des profils de travail.
18:11:26: Début du script /home/cartou/.var/app/org.siril.Siril/data/siril-scripts/preprocessing/AMSP.py
18:11:27: PyQt6 is installed
18:11:27: astropy is installed
18:11:27: Gtk-Message: 18:11:27.478: Failed to load module "xapp-gtk3-module"
18:11:27: Siril Wizard – Automatic Multi-Session Processing v1.0.11 – connected
18:11:27: Configuration loaded from /home/cartou/.config/siril/amsp.json
18:11:52: Scanning 124 FITS file(s)…
18:11:52: Scan done: 124 files (124 subs, 0 masters), 1 night(s).
Affaire à suivre. Encore merci pour tout ce boulot que tu réalises…
Patrick
Respectful
This is in the script preferences
Thanks a lot, Cyril !
This topic is closed to new replies.
FITS File Analysis Tool Python
fits-analyser.py astronomical_analysis_description.pdf Hello fellow astrophotographers! I've developed a Python script to help me quickly analyze my FITS files and track my progress across different targets and filters. The main goal was to get a cle...
Analyzes FITS files with Python, directly relevant to AMSP's FITS header-based automation.
Oct 10, 2025
