Wanderer ETA Tilt Corrector N.I.N.A. connection button behavior
13 replies177 views
Jozef Bodden avatar
Hi everyone,
I'm trying to connect my Wanderer ETA Tilt Corrector to N.I.N.A. and I have a specific question about the expected behaviour in the software.
Several AI assistants (and some online sources) have told me that the N.I.N.A. connection button for the Wanderer ETA should turn green once communication between N.I.N.A. and the device is established. However, when I contacted WandererAstro support directly, Frank Wang told me that the button never turns green under any circumstances.
My question: Has anyone here successfully connected the Wanderer ETA Tilt Corrector to N.I.N.A.? If so — does the button turn green, or is there another visual indicator that confirms the connection is active?
Any real-world experience would be very much appreciated!
Clear skies,
When you connect in NINA does the usual “connection successful” window open up? I would certainly take the developer’s advice over AI’s.
Dale Ghent avatar
Why not ask Wanderer directly? They created the NINA plugin for the tilt corrector.
Well written
Jozef Bodden avatar
Dear,
Wanderer already approached 2 times and gave no solution.
Well that the button does not turn green.
Where you can see if the connection was successful in, for example, NINA is not indicated.
The switch from ASIAIR to NINA only makes sense to me if the automatic tilt correction is carried out in the Wanderer ETA.
Incidentally, the reaction of the Wanderer software builder was that your AI products are not always right! I believe so, but where can you go?
Jeffrey Kieft avatar
I don’t have a Wanderer tilt corrector but I do have a Wanderer flat panel (which is OK, not great).
When connecting this device, or any other, the connection button in NINA does not turn green. Rather, when a device connects you will get a message in the lower right of the NINA window that has a green checkmark, like this:
📷 Screenshot 2026-04-27 at 8.41.23 PM.pngScreenshot 2026-04-27 at 8.41.23 PM.pngIf it fails to connect, the green check is a red X. This is likely what the AI assistant meant: a “green button.” If you see this appear in the lower right, it connected.
For the Wanderer flat panel, NINA calls the Wanderer Empire software, which is what controls the equipment. I believe this is also true of the tilt corrector. If you don’t have that installed, it may not connect:
https://www.wandererastro.com/en/h-col-106.html
If you have not installed, or Wanderer Empire is not running when you try to connect, I recommend doing that.
Well written Helpful Concise Engaging
Fabrice Lamidey avatar
Dale Ghent · Apr 27, 2026, 01:19 AM
That's exactly what he did 😁
Jozef Bodden · Apr 26, 2026, 03:55 PM
Hi everyone,
Clear skies,
The connection in NINA is actually made through Wanderer Empire, their software. In NINA, you will see the pop up signaling the connection has been made. In Wanderer Empire you will see the Connect button change to Disconnect (but it will not turn green).
Well written Helpful Respectful Concise
Dale Ghent avatar
Fabrice Lamidey · Apr 28, 2026, 03:08 AM
Why he would ask here and an AI when the vendor already gave him the answer is a bit strange, isn’t it?
Dale Ghent · Apr 28, 2026, 03:22 AM
Trust issues maybe 😁
Jozef Bodden avatar
Dear,
I think that in NINA I should use the best ETA automatically in a Tilt sequence. I also asked Perplexity AI and it makes an example of this. Maybe or certainly I chose the wrong approach. I'm going to try this way tonight.
In addition, I am actually familiar with ASIAIR and unfortunately not yet with NINA. Still a bit hesitant to switch.
Jeffery Richards avatar
Also in NINA, if it is connected the icon for it in the equipment tab will have a little power button next to it (indicating it can be turned off since it is turned on and connected).
Jeffery Richards · Apr 29, 2026, 08:53 AM
But is there an equipment tab for the tilt adjuster ?
Jozef Bodden avatar
Dear,
Started yesterday via NINA's advances sequencer together with the Wanderer ETA. Successful in itself. After 3 iterations you will receive a table (not like in the YouTube videos) where you process the data in the Wanderer ETA with possibly a correction of your back focus.
So yes it works but also takes a lot of time
Jozef Bodden avatar
Dear,
Unfortunately, different AI programs also give different answers.
NINA and the Wanderer ETA work together (automatically) to correct the Tilt deviation. I found it strange that I had to generate a folder with Attemps between Autorun and Attemp01! Then it worked.
Furthermore, it is not possible to visually get the tilt deviation in the aberation inspector NINA. By the way, a window.
I don't understand that.
Can someone confirm me below or show me the right way in NINA PLEASE?
An AI proposal was:
• In NINA > Hocus Focus you turn on Save.
• For example, you choose as storage path: C:\HocusFocus\ .
• The Wanderer ETA must then use exactly the same path, so also C:\HocusFocus\ .
If your sequence works with subfolders per attempt, it may look like this:
C:\HocusFocus\Autofocus\Attemps\Attemp01
C:\HocusFocus\Autofocus\Attemps\Attemp02
The ETA does not expect “Attempts” as a magical NINA map, but that the output of Hocus Focus ends up there and can be found again in the same place by Wanderer. The setup instructions explicitly state that the Hocus Focus save path in NINA must match the save directory you set in WandererEmpire. As a result, the automatic tilt correction then works by itself, because the ETA can read the measurement data from that path.
A spreadsheet to convert Hocus Focus result in pratical move/turns of a manual tilt adapter plate
Hi, I recently got a wanderer astro ETA. It works great but I wanted to better understand the way it works and I asked OpenAI to prepare a spreadsheet to check what the ETA was doing and also to use old Hocus Focus results as the ETA works only for t...
Discusses Wanderer Astro ETA device setup and practical configuration details.
Jan 7, 2026
