Help needed with WO MiniCat 51 tilt issues
6 replies93 views
Jeramie avatar
Greetings! Looking for some help with my new WO MiniCat 51 and the tilt issues it has.
Imaging Setup:
WO MiniCat 51 WIFD
ZWO AM3
ASI2600MC Duo Air
ZWO EAF
Bin 1
180s exps
Test FOV:
Markarian’s Chain Widefield
Guiding:
.28 - .45 total RMS
Problem Statement:
My new WOMC 51 seems to have some tilt/aberration issues that I am having difficulty understanding. As a disclaimer, I am fully aware of the MC51 and corner issues. Based on other’s processed images, I believe I can do better. I’ve done some testing and I’m looking for comments on what I’m seeing and potential ways to address it.
📷 ASTAP_Original_Tri_Tilt.jpgASTAP_Original_Tri_Tilt.jpg1. The original process I did of about 40, 180s subs came out looking very mediocre for the my guiding numbers so I started digging in. ASTAP shows quite a bit of tilt. (Image was solved and showed a rotation of 270 degrees, Image Inspection was set at 90 degrees)
📷 ASTAP_Original_Oct_Tilt.jpgASTAP_Original_Oct_Tilt.jpg2. Switching to the Octagon it shows extreme tilt as well.
📷 ASTAP_Fixed_Tri_None.jpgASTAP_Fixed_Tri_None.jpg3. I backed out all the tilt screws and reset them, this seemed to improve the tilt.
📷 ASTAP_Fixed_Oct_Severe.jpgASTAP_Fixed_Oct_Severe.jpg4. The octagon option still shows severe tilt, but it is improved as well.
📷 ASTAP_Imaging_Tri_None.jpgASTAP_Imaging_Tri_None.jpg5. After the tilt adjustment I did a short run of 20, 180s subs. I grabbed one of those subs and remeasured. The triangle method still shows almost no tilt, but it did regress some.
📷 ASTAP_Imaging_Oct_Severe.jpgASTAP_Imaging_Oct_Severe.jpg6. The octagon shows the same.
📷 Original_ImgIns_Mosaic.jpgOriginal_ImgIns_Mosaic.jpg7. Here’s what the corners look like from the original capture and process of 40, 180s subs. Also, this process had drizzle enabled for some reason.
📷 Fixed_ImgIns_Mosaic.jpgFixed_ImgIns_Mosaic.jpg8. And here’s the mosaic from the test run of 20, 180s subs after the tilt showed to be “almost none”, but these stars look way worse than when the tilt reported to be severe.
Questions:
1. Is there a better tool to understand the tilt of a system and to correct it? I’ve always used ASTAP and have found it to be reliable.
2. I image in B5 skies, and I believe that I can support 180-second subs with my darkness and guiding, but could these star issues be caused by oversaturation?
3. I understand that the “triangle” option for ASTAP Image Inspector measures a central part of the image, so should I be only using the “octagon” option to help correct how bad my stars are?
4. Am I misinterpreting these aberrations entirely and should be looking at other potential issues?
Apologies for the long read and appreciate any suggestions on this issue.
Jeramie
Well written Helpful Engaging
DavesView avatar
I take 10 sec to 30 sec images when correcting tilt. What works for me is a simple method:
1) take the image
2) open it in ASI FitsViewer
3) use the tilt identifier in FitsViewer
4) slightly push the big number(s) ( if one side has equal measurements, top/bottom/left/right) I push both screws associated with that side
5) refocus and reshoot and remeasure
NOTE: with the FitsViewer you have the luxury of looking at where it was via the previous subs instead of writing everything down and keeping a record of what you’re doing. I tried HocusFocus and ASTAP, but find this a simpler method that works for me.
I purchased the Z’Tilter for each of my ZWO cameras and can usually get it to less than 4% in a few measurements/adjustments. It is currently at 1% on my UltraCat108. With the accessories (everything known to man) on my RedCat51 III, I can’t get to the tilt tool built into the RedCat, hence the Z’Tilter for it. With the UltraCat108, I couldn’t get the STX (tilt tool) to work for two months. Went to the Z’Tilter and had it adjusted in 5 moves. With the focuser flop in my FLT91, I find that I often have to adjust tilt and can do so within a few adjustments prior to an imaging session. I always take a few test shots prior to imaging with any of my scopes.
Also, I would pick a better target than Markarian’s Chain for tilt measurements. Something with an even spread of stars like due north of M81. MC has too many distorted objects that are similar to stars.
Good Luck!
Well written Helpful Respectful Engaging
Jeramie avatar
Great suggestions and I appreciate the help. Envious of your tilt!
You touched on one thing that I was trying to understand and that was the tilt plate. If a camera sensor has four corners, why would you only have 3 adjustment screws? I’m sure there’s a good reason for it.
Purchasing the new plates now. I’ve got another 2600MM coming today and I’m sure it will need similar adjustments.
Jeramie avatar
Hey Dave- another question.
I completely overlooked the fact that the MiniCat has a 4-corner tilt adjuster built into the scope. Would you just use that one to adjust tilt over adding another device on the camera? Wouldn’t this make it more difficult to adjust?
Purchased one of the tilt plates for my C11 and looking forward to getting that in.
Jeramie
DavesView avatar
I would have used the RedCat tilt tool on mine, but I can’t easily get to it. I have the rotator installed right after the M54 adapter. It’s the same four point adjuster as the Z’Tilter , I think. Never looked!
Dan H. M. avatar
It’s hard to get an accurate tilt measurement on a scope with severe internal miscollimation like the Minicat. It is always going to confuse tilt within the optics (i.e., miscollimation) with sensor tilt (i.e. the camera sensor not being square with the rear element). The other confusing thing about the Minicat is it doesn’t have adjustable backfocus so you have no idea if you’re at the optimal distance when making adjustments to the tilt plate.
Personally, when I owned a Minicat I just set the CAA to the spot that delivered the best stars, then added a separate CAA onto the imaging train and rotated to where I wanted it, and ignored tilt entirely.
Alex Nicholas avatar
Try to remember too, that if the stars look good in a stacked image after you run BXT, then obsessing over the tilt (which honestly doesn’t even look that bad to me) is just destroying your own happiness in the pursuit of an unobtainable level of perfection.
The MiniCAT 51 literally says on the website that the stars in the corner of APS-C will not look great without correction applied in post processing. Yes, I understand that tilt can damage image quality, I recently returned a telescope that had SIGNIFICANTLY worse tilt than what you are dealing with here… But given what I’m seeing in your images you’ve posted, I’d be running BXT and forgetting about what the raw frames look like.
C11 Collimation Proof with ASTAP
Greetings, During a recent processing attempt I noticed that for the amount of data that I had collected my end result didn't look as crisp as I thought it should. I thought maybe my collimation was off and was part of the issue potentially. I lo...
Collimation issues can cause tilt/aberration problems similar to yours.
Aug 19, 2025
Matching sensor corners with subs corners
Hi there, I have a quite significant sensor tilt issue. Hopefully, I just saw a great thread on Cloudynights revealing that the M42 adapter plate delivered with my touptek ATR2600m can be used as a tilt adapter if one add 6 M2.5 grub screws. https://...
Directly addresses sensor tilt issues relevant to your corner problems.
Sep 17, 2025
Round stars using a guidescope at 1000mm - possible?
Hi All, I recently bought a ZWO FF130 to supplement my great little FF65. Normally with the smaller scope I’ve been getting good guiding with the ZWO 30F4/ASI120mm combo of between 0.5”—0.8” RMS. This is all sitting on an AM5N/TC40 (with weights in t...
Guiding quality affects image sharpness; your .28-.45 RMS may need optimization.
Feb 5, 2026
