Is the Sky Watcher Heritage 130p suitable for first-time telescope buyers?
5 replies49 views
Samet AKTURK avatar
Hello friends,
Is the Sky Watcher Heritage 130p a suitable telescope for an amateur user considering buying their first telescope? What other telescopes would you recommend instead?
Thank you for your help and the information you provided.
Well written Respectful
If you are looking for a very portable scope that will only be used visually it should be fine to start with. It’s a lot better than the scopes a lot of us started with.
Concise Supportive
Andrew avatar
For visual yes
But photography through it no,
You’ll run into focusing issues when not using a Barlow.
I can’t recommend a specific scope without knowing your interests and what you want to do with it.
Samet AKTURK avatar
Tony Gondola · Apr 23, 2026, 01:04 PM
Thank you so much for your time.
Samet AKTURK avatar
Andrew · Apr 23, 2026, 04:55 PM
For visual yes
Actually, I'd like to start with observation. I've also read some suggestions about "smart telescopes" for getting started with astrophotography. However, looking directly at the sky with a telescope rather than through a phone screen seems more exciting, at least for me as a beginner. I don't know if this is true, these are just conclusions I've drawn from what I've read. Thank you so much for your time.
Respectful
Craig Towell avatar
It is a great little scope, with surprisingly good optics. It was my first scope back in 2011 and I still have it whilst all other scopes have been and gone. I directly compared mine on Mars and Jupiter with a 127mm maksutov and a 100mm f/10 achromat and the views through the H130p were the best to my eyes. I even put it up against a C8 I also owned and I actually preferred the views though the H130p again. Though it wasn’t the best example of a C8 to be fair.
The 130 heritage and a Baader 10mm BCO under a good dark sky is a serious DSO observing tool
Skywatcher experience needed - seeking user feedback and recommendations
Hello, Has anybody experience with the skywatcher Wave150i ? My wave 150i worked very good until I made some changes in the cable management. In order to have less USB cable between the telescope/mount and the PC, I installed on the telescope platfor...
Skywatcher user feedback relevant to Heritage 130p telescope consideration.
Oct 9, 2025
Astoundingly bad Popular Science article: "The best telescopes for astrophotography"
In case anyone happens to be browsing this who is brand new to the hobby, I thought I would share this amazingly bad list of recommendations I saw pop up in my news feed: https://www.popsci.com/gear/best-telescopes-for-astrophotography/ Do not buy an...
Article discusses telescope recommendations for beginners, directly addresses author's question.
Dec 3, 2025
