IMX585 sensor with long focal length (>2000mm) - Can it work?
14 replies490 views
Kartik Atre avatar
Hi All,
Not sure if this has been discussed elsewhere. I am thinking of experimenting with using an IMX585 sensor camera with my Celestron C8 at native (or even 0.7x reduced) focal length.
I understand this is grossly oversampled. Has anyone tried this? Or with another OTA of similar or longer focal length?
For context - this will be deep sky work.
Thoughts?
Thanks, Cheers and, CS
Kartik
Well written Respectful
Alex Nicholas avatar
A guy local to me has just recently started imaging primarily with a QHY Minicam8 and a Celestron EdgeHD 925… His results are stunning, especially on nights of good/great seeing!
I’ve used a 585 on an 8” SCT. reduced and at prime with good results. A lot of people are afraid of over-sampling but if your seeing is good enough it can pay off. If you’re looking to make images where you can’t see the galaxy because of the IFN, it’s not going to be the best approach but if you like detail, give it a go.
Gabriel Wiklund avatar
There is a guy in our local club who has that exact combination and he is very happy with it despite that the seeing here is below global standards.
Tobiasz avatar
I have several cameras but mostly use the IMX585 (& HDR) with my RC10 at 2m FL and sometimes without a corrector for NIR imaging.
The setup has a small FoV, is massively oversampled and you need excellent guiding for sharp images. Why do I do this? Because it’s fun.
My last project was the more violent cousin of the cigar galaxy: NGC1569.
I can recommend this combination to anyone who likes a challenge and/or loves small targets like me. The only “downside” is that your mount has to be really calm and your guiding has to be top notch.
Well written Respectful Concise Engaging Supportive
Jan Erik Vallestad avatar
I agree with Tobiasz that this would be a combination for those with an outstanding mount and experience. Otherwise you will be setting yourself up for a tough time.
A C8 at native focal length would require a mount providing you with stable 0.29” RMS in order to avoid bloating and loss of resolution (with the pixel size of the 585). With the reducer you could get away with 0.42” and if you then bin in post you could live with 0.84” which is entirely doable. Maybe this works better with narrowband than it does with broadband though, I’m not sure.
I use my C8 without a reducer and I’ve used two mounts for this. Last season I used my Juwei 17 which didn’t stand a chance really. I got some good images but I could never get the 0.38” RMS needed to sustain full resolution, so I had to use bin2 in post as a minimum. With my AM5 this season things have fared better, but still not doable to get that 0.38” mark on a regular basis - so I’ve still needed to resample several most images in post in order to get satisfying results. The IMX533/571 has faily larger pixels than the IMX585 so in theory it should be a better/easier combo - but it’s still not the easiest.
People are different though, so what I find unacceptable might be what someone else find very acceptable.
If you want good detail (not bloating and loss of resolution) you could get away with the reducer and binning in post, as long as you are comfortable with that limitation. Native focal length would be a huge stretch IMO, unless you have excellent seeing and an excellent mount, not an AM5, AM7 or the likes of it - They are great, but not for this kind of tracking IMO. No amount of Russell Croman’s tools will make bloated images look good. An observatory grade mount however will make imaging like this effortless.
That being said, if you own the equipment already just give it a go and see if the results are enough to make you happy - which is the main thing anyways.
Well written Helpful Engaging
Tobiasz avatar
Jan Erik Vallestad · Apr 20, 2026, 07:51 AM
I can confirm these numbers. I am using an Avalon M-UNO with new belts which is lucky guided with MetaGuide and even with mediocre seeing I see the FWHM and eccentricity degrade when the guiding RMS hits 0.45” and above. As you said, it is not a big deal in post processing but it is a real challenge.
If the conditions permit, then my system can run consistently between 0.25-0.4” total RMS, which my WD20 could never achieve because of its high and rapid periodic error.
Regards
Well written Helpful Respectful Concise
Andreas Zeinert avatar
0.41”/pix might be considered as oversampled in textbooks but the fact is that deconvolution programmes such as BlurXT better work with (slightly) oversampled data. Even if you seeing is average (let’s say about 2”) you should keep the bin1. I used the 585 sensor on a Edge with focus reducer (around f/7) and it worked fine :
https://www.astrobin.com/adr2vi/C/
I really d’ont see a problem with that, some people here on AB shoot with 0.27”/pix and this can still be interesting but needs of course decent sky conditions.
Tobiasz · Apr 20, 2026, 09:12 AM
Regards
I think if you’re willing to do some image culling, those general figures can be fudged a bit…
John Hayes avatar
Kartik Atre · Apr 20, 2026 at 03:13 AM
Hi All,
Thoughts?
Kartik
The IMX585 sensor has 2.9 micron square pixels. If you are in a region with 1” seeing, the optimum pixel size for your C8 is around 4.6 microns so you’d be a bit over sampled. That means that you’d be operating with a lower SNR, which you could make up by simply using more exposure time. On the other hand, if your local seeing is closer to a more common 2”, the optimum pixel size would be 7.6 microns. In that case, you would still be slightly oversampled by using 2×2 binning but you’d pick up a factor of 2 in SNR. You can always oversample but you should understand that the penalty is in the SNR that you achieve and oversampling does not produce a sharper image. It is true that BXT does a bit better with a slightly oversampled image but it’s not a good idea to use that fact to justify extreme oversampling. SNR is ultimately more important than sampling when it comes to producing a high quality image. A good middle ground is to slightly oversample and to make up for the loss in SNR with a bit more exposure time. I think that with your telescope, you are going to find that you’ll get the best performance by binning 2×2 with that sensor.
Here are the charts showing the optimum sampling rate based on MTF analysis that I did a few years ago.
Tony Gondola · Apr 20, 2026, 01:51 PM
Absolutely, that’s a fair point. I guess thats down to the imager to figure out depending on how the mount performs (and the sky conditions). I don’t want to take that big of a hit myself, as I would throw away more than I'd like so I keep my aim at having acceptable results for bin2 for that reason.
Kartik Atre avatar
Thanks everyone,
This has been educational and fun. Currently, I use either the 533MM Pro or 2600MM Pro with this telescope. But keen to give it a go - just for fun - even if to prove that this is a bad idea 😅
Cheers everyone
Kartik
Respectful Supportive
SonnyE avatar
Kartik Atre · Apr 21, 2026, 02:36 AM
Thanks everyone,
Cheers everyone
Kartik
There is do, or do not. There is no try. 😉
Work it, Baby. Work it!
Vin avatar
I used an 1800mm fl f15 ETX125 (on an M-Uno mount funnily enough) with both 4.68um and 9.3um bin 2 pixels). And this is Bortle 9 conditions with 1.5-2” seeing. The 4.68um gave more pleasing images even though it was theoretically over sampled I guess. It was a nice DSO cannon.
The only downside was the speed - or rather lack thereof - at f15.
Based on that I’d have thought that binning the 2.9um 585 sensor 2×2 should work well for you.
Kartik Atre avatar
SonnyE · Apr 21, 2026 at 05:55 PM
Thanks everyone,
Cheers everyone
Kartik
Hahaha! Will do. Thanks Yoda! 🙏
Jupiter and Io – First Attempt with a Deep-Sky Setup
This is my first attempt at Jupiter using a setup that’s primarily optimized for deep-sky imaging: C8 EdgeHD with 0.7× reducer and ASI294MC Pro. At this focal length, Jupiter comes out to roughly ~65 pixels across the disc, so resolution is clearly l...
Similar deep-sky setup with C8, reducer, and camera sensor comparison experience.
Feb 16, 2026
