Halos and diffuse glow around bright stars with iTelescope T5
16 replies317 views
Claudio Pedrazzi avatar
Hi everyone,
I have a technical question about an artefact I am seeing in a stacked image, and I would appreciate the opinion of more experienced imagers.
The attached image is a stack of about twenty-five 120-second exposures of the Headphones Nebula / Jones-Emberson 1, taken with the iTelescope T5 system. The data were acquired through the Clear filter and the image shown here is displayed with Siril’s Autostretch, so of course the effect is strongly enhanced.
The telescope is iTelescope T5:
https://support.itelescope.net/support/solutions/articles/231902-telescope-5
As far as I understand, this system uses a Takahashi Epsilon 250, 850 mm focal length, f/3.4, with an SBIG ST-10XME CCD. The camera is explicitly described as non anti-blooming.
What puzzles me is the diffuse nebulosity / halo-like glow visible around some of the brighter stars. I am fairly sure this is not classical blooming, since I do not see the typical vertical streaks or charge-spill trails in the individual frames. But I am also quite sure that this is not real nebulosity in the sky, because the survey view of the same field does not show such diffuse structures around those stars.
So my current suspicion is that this may be some combination of:
  • broad PSF wings around bright stars, strongly enhanced by the autostretch;
  • scattered light in the optical train;
  • internal reflections or filter/window reflections;
  • CCD-related effects, possibly related to the ST-10XME sensor or microlenses;
  • or simply a known behaviour of this particular telescope/camera/filter combination.
I am attaching both the stretched stack and a reference field view, to make clear that the diffuse structures are tied to the brighter stars rather than to real emission in the field.
Does anyone have experience with this kind of artefact on SBIG ST-10XME, Takahashi Epsilon, or specifically iTelescope T5 data?
Is this a known effect, and is there a recommended way to mitigate it during processing, apart from avoiding overly aggressive stretches or masking the bright stars?
Thanks in advance for any insight. I am still learning how to distinguish real faint structures from instrumental or processing artefacts, so any diagnostic hints would be very useful.
Best,
Claudio
📷 comp_r_clear_stacked.pngcomp_r_clear_stacked.png📷 Telescopius simulation.pngTelescopius simulation.png
My first guess would actually be a high haze or very thin cloud layer in at least a few of the subs, have you blinked them? If it is atmospheric you’ll see a drop in the star count for the effected subs.
Helpful Concise Engaging
Are they still running an SBIG camera?! I hope not for pay! To answer the query, I’d agree with Tony above, this is high cirrus clouds and/or haze.
andrea tasselli · Apr 19, 2026 at 04:55 PM
Ehm :-) yes they do… it is the cheapest one, though!
And back to the question: thanks a lot for the hint! I think you are right, I am just too inexperienced to understand the problem…. here is the plot of the number of stars ….
📷 Screenshot 2026-04-19 alle 19.20.00.pngScreenshot 2026-04-19 alle 19.20.00.png
So thank you @andrea tasselli and @Tony Gondola I believe this is the explanation. The subs with few stars are the ones with the more evident halo…
Maybe I should have rejected based on the number of stars, instead of looking at the FWHM.
Respectful
That’s classic, if you just cull the frames below 288 it should be much improved.
Thank you very much for the suggestions. I tried to test the “thin haze / cirrus” hypothesis by rejecting the worst subframes.
Originally I had 27 Clear frames. I restacked the image using only 17 of them, excluding the frames with the lowest star count and/or worst FWHM. The result is attached here. Somewhat surprisingly, the diffuse halos / glow around the brighter stars are still present, even though the stack should now contain only the better frames.
I also attached the Siril plots for star count and FWHM. The selection was not perfect science, of course, but I tried to remove the most suspicious frames. The remaining stack still shows the same kind of broad light excess around the brighter stars.
As an additional check, I made a strongly enlarged intensity profile across two of the affected stars. The profile shows that this is not just a very local star-core effect: around the brighter star there is a broad, low-level pedestal extending well beyond the stellar core. That seems consistent with some kind of halo / scattered light / atmospheric diffusion, but I am no longer sure that it was caused only by a few bad frames.
So at this point I am wondering whether this could be a more general feature of the data from this session, perhaps due to a persistent thin haze, scattered light, or the optical/camera system itself, rather than only a few individual bad subframes.
Any further diagnostic suggestions would be very welcome. It is not a big problem, but I just like to understand things as good as possible :-)
📷 Screenshot 2026-04-20 alle 09.02.08.pngScreenshot 2026-04-20 alle 09.02.08.png📷 Screenshot 2026-04-20 alle 09.02.23.pngScreenshot 2026-04-20 alle 09.02.23.png📷 Screenshot 2026-04-20 alle 11.16.35.pngScreenshot 2026-04-20 alle 11.16.35.png📷 Screenshot 2026-04-20 alle 11.33.59.pngScreenshot 2026-04-20 alle 11.33.59.png
Really still think that a variable but persistent have is the culprit. If it doesn’t repeat then chalk it up to being bad data from a bad night.
Marcin Cikała avatar
Claudio Pedrazzi · Apr 20, 2026, 09:46 AM
Hi Claudio.
Even if you took only 17 photos, you can't be sure whether there were any cirrus clouds in the sky. Also the number of stars found on the frames does not show you a clarity of night. Only wheather stability - you can have still qute constant thin layer of clouds. I do not suppose the internal reflection, fog on the mirror, etc. in the Takahashi Epsilon scope.
Best regards, Marcin.
Spacetime Pictures avatar
FWIW: We operate two Epsilon 160EDs. On one of them, the focuser and imaging train face downward.
In this configuration, the corrector is quite exposed due to the short OTA and is extremely sensitive to dust. Bright stars (mostly in the blue band) then show an extended halo, reminiscent of haze or high clouds. The corrector requires periodic and thorough dusting.
Maybe that’s what you’re experiencing there?
Alex Nicholas avatar
Thats cloud/smoke or haze in the air, or potentially a dew affected mirror/corrector…
With my fast newtonian I have to run a long dew shield or my corrector/secondary will suffer dew quite early in the evening.
Having owned a ST10XME in my time (aging my self with this…) I can absolutely agree with you that that’s not blooming. In blooming situations, you see the spill of saturated pixels into surrounding pixels in vertical rows, you can see the very start of blooming on some of the brighter stars, with a vertical diffraction spike between the normal ‘X’ shaped spikes… that vertical mini-spike is likely electron spill-over…
andrea tasselli · Apr 19, 2026, 04:55 PM
For some tasks, an ST10XME is a significantly better camera than something with an IMX455 in it…. Just, probably not for making pretty pictures…
Alex Nicholas · Apr 21, 2026, 01:47 AM
Alex. The thelescope is placet on Utah Desert with night humidity of about 60% and dew point 20 Faranhait degrees lower than ambient temperature (c.a 10 Celsius degrees). It is very hard to expect dew on the optical elements even you cooling down the camera very fast and to very low temperature.
Spacetime Pictures · Apr 20, 2026, 07:50 PM
Yes. Dust is a second potential problem. But if yes I suppose rather the dust on the main mirror instead of corrector. Even it is extreme sensitive to dust. Dust is rather heavy and likely fall down to the mirror instead of the corrector (90 degrees to the OTA). Also the haze is rather constant on the picture. I am not sure if this effect is observable when the dust covers the corrector not uniformly (what should be expected). But yes, I think the dust may play a huge role.
Only what make me diffused is the detected stars numbers whitch is different from frame to frame. Dust does not make such effect.
IMHO the only way to solve the problem is to take some pictures from a good and clear night.
Best regards. Marcin.
Supportive
Jure Menart avatar
Hi Claudio,
You might want to try out NormalizeScaleGradient script for PixInsight, Last week I had 3 nights of clear imaging and 2nd night was the best (according to N.I.N.A. FWHM and number of stars). Until I integrated everything (especially blue filter, was by far the worst) next morning - it was sooo bad with glow it was unbelievable. When I brielfy checked subs it wasn’t immediately obvious what is wrong (but was if I was really careful and compare to other nights).
When I ran the NSG it was quite obvious (sorry I don’t have access to data at the moment to show both integrated images, I only have the output screenshot of NSG for blue filter):
It’s quite clear that ‘transmission’ was really bad second day (points are blue filter subs, 180s each, over 3 nights, you can also see the low horizon data from 3rd night).
So my proposal is to try to run your data with NSG and see if you can isolate ‘the glowy’ subs. It saved my blue filter integration (as this was by far most affected).
Thank you very much to everyone for the very interesting comments, suggestions, and diagnostic ideas.
There are several good points here that I would really like to investigate properly. Unfortunately, I am not able to follow up on them immediately, but I hope to have some time in the next few days to look more carefully at the data and try some of the proposed tests (though I do Not have Pixinsight)
If I manage to understand something more, I will certainly come back to this thread and report what I find.
Thanks again — this has been very helpful.
Sorry to come back to this topic again, but given the many thoughtful replies, I felt it was only fair to do a bit more checking and report back.
I do not have PixInsight, so I tried to investigate this in Siril.
One thing I realized is that the glow / diffuse halo is present on all four nights. To test this, I made four separate nightly stacks, using exactly 4 frames for each night, just to keep the comparison uniform and avoid differences caused simply by stack depth.
I am attaching those four nightly stacks, all shown in Siril Autostretch.
📷 r_clear_04_10_stacked.pngr_clear_04_10_stacked.png📷 r_clear_04_11_stacked.pngr_clear_04_11_stacked.png📷 r_clear_04_14_stacked.pngr_clear_04_14_stacked.png📷 r_clear_04_17_stacked.pngr_clear_04_17_stacked.pngI am also attaching three Siril plots for the full sequence:
  • FWHM
  • background
  • number of stars
In these plots I added vertical separators between the different nights, since I verified that in this sequence the frame order is chronological.
📷 FWHM.pngFWHM.png📷 background.pngbackground.png📷 stars.pngstars.pngFinally, I am also attaching the frame list / conversion list, to show the chronological order of the frames across the four nights.
📷 list.pnglist.pngSo, at least from this additional Siril check, the glow does not seem to belong only to a few isolated bad subs, or to only one night. It seems to be present throughout the whole dataset, although with varying strength. This seems less consistent with only a few isolated bad subs, although I cannot rule out a more persistent atmospheric cause affecting multiple nights.
At this point, I also intend to ask iTelescope support for their opinion, in case this is a known characteristic of the system or of this particular dataset.
Thanks again to everyone for the many useful suggestions.
Best regards, Claudio
Well written Helpful Respectful Engaging
bigCatAstro avatar
Claudio Pedrazzi · Apr 26, 2026 at 10:23 AM
  • FWHM
  • background
  • number of stars
Interesting update here. To be honest, the only time I’ve ever encountered or seen something similar was when I used to try imaging with my old Celestron C8-N and dew would partially form no matter how I tried to address it. Dew would not totally form but it would be enough to cause hazy images on different nights and different targets.
Well written Respectful Concise Engaging Supportive
I hope I am not doing anything improper by quoting the reply I received from iTelescope support.
So, it now seems very likely that this was at least partly an optical maintenance issue, possibly related to the cleanliness of the corrector or primary mirror, rather than only a processing mistake on my side.
Honestly, I learned a great deal from this whole “issue”, and I find their offer to refund the sessions more than fair.
Many thanks again to everyone who took the time to reply and help me think this through.
Below is the support reply:
Hello Claudio,
T05 is a system focussed mainly on collecting photometric science data.
https://support.itelescope.net/support/solutions/articles/231902-telescope-5?utm_source=Telescopius&utm_medium=link&utm_campaign=TelescopeSimulator
It isn't going to achieve good s/n or contrast for deep space images.
The corrector or main mirror possibly requires cleaning.
I'd suggest refunding your sessions. Please let me know the transaction id's and the number of points required.
Best regards,
Mladen Dugec
Observatory Quality Manager
iTelescope.net
