Ota Size, Scope Decisions, and Gear to fit remote imaging requirements.
16 replies260 views
Wes Schwarz avatar
This is a repost from cloudynights. I’m trying to make a decision of a scope purchase for remote imaging.
I would appreciate any feedback.
Im currently debating between the Askar SQA 106 and 130 scopes. I have secured a pier at a remote observatory and to stay in the $200 a month class I need to have my rig setup under 35". I will be setting up at this new remote location https://deathvalleyobservatories.com/
A flat panel like the wanderer which lays at about 180 against the ota when open does not impact the 35" length.
the sqa 106 is 23" with dew shield extended
the 130 is 25" with it retracted and 30" extended
I am also planning to use an asi 6200mm pro with a 7x2 efw and a wanderer rotator
A quick chat gpt assessment indicates the following with everything connected including usb cables.
SQA106
Dew Shield Retracted: 20.3" + 6.7–7.8" = ~27.0–28.1"
Dew Shield Extended: 23.1" + 6.7–7.8" = ~29.8–30.9"
SQA130
Dew Shield Retracted: 25" + 6.7–7.8" = ~31.7–32.8"
Dew Shield Extended: 30" + 6.7–7.8" = ~36.7–37.8"
What that means in plain English
SQA106 still looks comfortable.
SQA130 is still borderline retracted and over a 35" cap with the dew shield extended.
What Id like now is some real world feedback.
Im using a strainwave so the distance from RA to the top of the scope is very compact compared to an eq mount.
I would prefer to use the bigger 130 but Im just not sure its going to work especially when I need to focus the scope.
I can ask them to just partially extend the dew shield by maybe 1"
What would be huge is if you can remove the manual rotator from the focuser of the SQA130 and retain the focuser itself.
That would shave a good bit off of the scope. Im sure the focuser itself will be fine for my setup.
Well written Helpful
SonnyE avatar
I’ve been thinking about this since you first posted it (or I first saw it).
I do remote imaging but not at the level you are speaking of. My remote Imaging consists of my backyard to my home office via WiFi. But it is remote in many of the ways. ~75 feet as the crow flies.
Due to the finicky ways of my equipment, I don’t dare put it any great distance from me. I experience enough problems with software acting up to know it isn’t for me.
One of your dilemmas I faced when installing my FR/FF and Rotator. I got rid of the manual rotator and installed my FR/FF directly to the back of my telescope, an AT130mm EDT refractor. Final answer with my equipment, Dew shield retracted, is ~ 42 inches overall length. It was a requirement of the manufacturer when installing the FR/FF prescribed for the telescope. It also helped me to assemble my imaging train into a ridged threaded assembly. Removing the manual rotator was simply unscrewing it from the focusing tube of my telescope and screwing in the FR/FF. It left me with 728mm FL @ f 5.8.
It seems odd to me that your planned provider has chosen the 35” threshold as a cutoff point. Seems rather limiting, or a way to squeeze more funds from potential users. Do they provide a list of what fits within their 35” requirement? It must be a requirement to avoid collisions between customers equipment’s. “This is your lot size for our development.”
I believe you will be better off doing the SQA106, just for peace of mind you won’t get stuck with some other arbitrary charges in the future.
I “frog hopped” from my 80mm triplet to my 130mm. My only physical “requirement” was to avoid a block wall near my location. Which wasn’t a real problem at all. I did not need to move my mount.
I don’t see where you listed your imaging train length. That might alter your 35” length limitation. (Seems quite an arbitrary length requirement. We’ll put the piers 72” apart and impose a 35” length on the agreement).
I did find this: Frequently Asked Questions - Death Valley Observatories
So my suggestion would be to contact them about your specific concerns. My specific concerns would be response times to any problems that happen. Reality may differ from what appears to be promised.
SonnyE · Apr 13, 2026, 05:25 PM
I “frog hopped” from my 86mm triplet to my 130mm. My only physical “requirement” was to avoid a block wall near my location. Which wasn’t a real problem at all. I did not need to move my mount.
I guess the reason is to optimize spacing in order to maximize profits. These installations are money factories based on solid business models. The closer the rigs can be spaced together, the higher the income density is. Honestly, I was tempted for awhile. Not to place a scope for hosting but for doing a hosting site myself.
Wes Schwarz avatar
They have been pretty reasonable about my choice and they are willing to work with me on the 130. I think thats what Im going to go with now that they are back in stock.
SonnyE avatar
Tony Gondola · Apr 13, 2026, 05:46 PM
Same as devolopers with land. How many homes can we cram on this footprint property.
Babysitting 487 piers with Myriads of problematic rigs is not my idea of retirement income.
SonnyE avatar
Wes Schwarz · Apr 14, 2026, 05:26 AM
I’d bet you would love the 130 over the 106. To me, I like nebula, so I’m more interested in center objects. That was why I made such a big jump from my 80mm to my 130 when I leaped.
I’ve been really happy with my 130, but the bottom line is I successfully brought everything closer and bigger. And a few favorites too much so.
Make sure your mount is up to the weight. IE: my total load is~ 34 pounds, on my 50-pound Photographic Instrument rated GEM mount.
I like the cutting-edge stuff. But learned a long time ago to stay back enough that the parts and guts fly over me. Now, I’m just settled in and happy with my equipment, but not my control software. I don’t think I could be happy not being able to go wrestle with my demons and I don’t do waiting on somebody else to get out of their chair to do my baby sitting. When it works good, it’s bliss! When it doesn’t, it’s hell on Earth.
So I’ll stay close to my backyard, beer, and my bed. 🤣
Engaging Supportive
Rainer Ehlert avatar
Keep in mind that the biggest swing diameter is when the scope is in 45° position as far as I have found out. This would mean setting up a scope at 45° Latitude and pointing to the North (Home position) is the biggest diameter. If my calculation was correct 18 years ago when I built my 2 pier Observatory.
And keep in mind also that balancing will make one end longer depending on what you have hanging on it. My Takahashi TOA 130 is very front heavy for example.
Rick Krejci avatar
When I asked DVO about flat panel lids, they indicated that the swing out type (I mentioned the wandererastro) vs the rotate sideways like the Depp Sky Dad OFP2’s, they said “it definitely needs to rotate sideways — otherwise the swing diameter increases significantly.”
Rick Krejci avatar
Wes Schwarz · Apr 12, 2026, 08:14 PM
Removing the rotator would do nothing to shorten the scope. The focus point is the focus point no matter what’s in the train. The focuser would just have to go out that same amount.
By the time you add the camera, 3” for cabling and add in the focus and account for RA center to farthest extent of scope or camera/cables, I really doubt that the 130 will fit in 35” . I would think it’s more getting in the upper 40s.
Wes Schwarz avatar
SonnyE · Apr 14, 2026, 04:14 PM
Its a big jump for me. I too am used to troubleshooting and being near my gear. The Asi Air did make my mount invisible for the first year or so and then a few poor firmware updates vaporized the whole experience for me. I have historically been a remote go up into the mountains under dark skies imager. I always tried to get the best bang for my buck with gear because I rarely get to image. I also developed a hatred for windows after being faced with updates and restarts while remote. A remote observatory is different because you can update right there at the pier. If you have an ip switch you can reset the PC, the mount, etc. Im using an HAE69 b EC mount which can handle the weight no problem. And because its strainwave I don’t need to worry about balance. With that said, I fully anticipate troubleshooting will be involved.
Wes Schwarz avatar
Rick Krejci · Apr 15, 2026, 01:08 PM
Yea, I think you have to be specific like share a link to the product. I believe some of the old wanderer panels folded out 90 degrees and extended the product like the old Altinak flat panels. 90 degrees of motion will increase your swing, 180 degrees is not a problem.
Wes Schwarz avatar
Rick Krejci · Apr 15, 2026, 01:11 PM
You know that is a good point, the focal point stays the same. I overlooked that concept. I think its going to be ok, we have had a few discussions.
Bill McLaughlin avatar
SonnyE · Apr 14, 2026, 03:54 PM
No kidding! There is enough hassle with two sets of high end equipment and 30+ years of experience. I cannot imagine the trouble presented by dealing with 400 plus newbies with cheaper equipment. Sounds like a nightmare to me!
I would imagine that support with any remote host is going to be limited, it has to be. Even having one person on site full time is cost prohibitive and cuts into profits. I suspect that at least some of the people are doing it because they enjoy it and really aren’t looking at it as a job. I’ve never looked at a remote hosting contract But I’m sure there’s a section covering expectations of both the host and the tenent. The host gives you the pier, electricity, connectivity and hopefully, security. You can expect the roof to open when it’s safe to do so and to close in advance of adverse conditions and that’s about it. If I were doing it, I’d sure a heck would properly vet any prospective renter before accepting a contract, both for their sanity and mine!
Tony Gondola · Apr 17, 2026, 03:34 PM
One reason I like my site. More expensive than the huge operations but is is in the yard of a very experienced Astro-guy and he is able to do almost anything. Since it is a small operation, you get more personal attention and I am often on the phone with him as he does something for me.
The bad news for others is that there are no more spots and probably won’t be for some time as people tend to stay once there.
Dcolam avatar
Bill McLaughlin · Apr 17, 2026, 06:29 PM
This sounds like a nightmare for the experienced astroguy.
Wes Schwarz avatar
Good for you, I am glad you are happy with your exclusive location.
Well written
