Tilt
6 replies115 views
eric belanger avatar
Hello .
I have a question about tilt and im not sure about what i found on the Web.
I have a new sharpstar 13028hnt and my stars are elongated all over the image . I think it's tilt because my backfocus seem to be ok . 55.6mm
My question is : does tilt affect the overall image quality or just the stars ? If the answer is just stars , i can live with that and use blurx
Thanks
Lynx Coleman avatar
It might be good to show an image of the elongation you are talking about; it's difficult to identify just from your words.
Tilt will affect your overall image quality.
Clear Skies.
Well written Respectful Concise Supportive
This sounds more like guide error than a spacing issue.
I was just testing yesterday and forgot to save an exemple .
My guiding was good . Around 0.6
Still doesn’t sound like a spacing issue. No spikes anywhere in the guiding graph for the session. Have you blinked your frames? You could get a spike or two and still have a good RMS.
Craig Towell avatar
Tilt generally manifests as an uneven distribution of star sizes across the frame, as some stars will be in focus and others not.
Spacing issues will generally manifest as elongated stars but the direction of elongation will either radiate out from the centre, or form concentric rings around the centre, depending on if the spacing is too close or too far.
If you have elongation that is all in the same direction and magnitude across the frame, that would point to a guiding/tracking issue.
Of course you can get a combination of all the above which makes things very tricky to pin down.
Armin Lukas avatar
I have the same scope. Perfect focus is really important, otherwise alls stars will be elongated. I use the ZWO EAF and it needs to be within 10 steps precise.
Also look at the collimation. I use the OCAL collimator, works fine.
My littte bad weather project: Sharpstar 13028HNT modification
Due to bad weather in Germany, I wanted to do some modifications to my Sharpstar 13028HNT. I’d like to share my first experiences with these modifications, though there is still more to do. A few things I wanted to try:Create a new mirror mask (notch...
Author has same telescope model; discusses modifications and experiences.
Dec 12, 2025
Diffraction Pattern Question
So I’ve acquired a small Sharpstar 15028hnt F/2.8 newt and been playing with it to see if it’s truly capable of delivering or working across a full frame sensor. It’s been a couple weeks of precise bench collimation, star testing, tilting, backfocus ...
Discusses Sharpstar telescope performance and star quality issues.
Aug 27, 2025
Question about Wanderer ETA and multi-night registration
Hi everyone, I don’t have the WandererAstro ETA (Electronic Tilt Adjuster) yet, but I’m seriously considering it and I’ve been thinking about a possible side effect. As far as I understand, the ETA adjusts each corner of the sensor independently. Thi...
Directly addresses tilt adjustment with Electronic Tilt Adjuster tool.
Aug 31, 2025
TS Optics 115/805 Photoline with 0.8 reducer - elongated star issues?
Anyone using the TS Optics 115/805 Photoline with the 0,8 Reducer for it? I have elongated stars on one side in the bottom and the top, but ok stars on the other side, when using 55mm working distance (APS-C Sensor). What is your experience with the ...
Addresses elongated star problems across telescope image field.
Nov 23, 2025
