ASI Air Pro Connectivity - My solution
ZWO ASIAIR PRO USERS 7 replies230 views
John Noble avatar
I love the ASI Air Pro and, it's functionality is all I need to enjoy this hobby. But like many ASI Air Pro users I've been battling the terrible internet connectivity for about 6 months now. My experience are rich and varied every night. Bar adding a antenna (I'm not that handy) I think I've tried everything. Even at home where I've set up station mode one or other of my modules (I run two in tandem for two cameras) will forget what it did last night and I'm back in a clear sky wasting cycle trying to get station mode back in action. At 10 F outside I just cant be out long enough to control my set up so I need something that let's me be inside while it works it magic.
Anyway the good news is I think I have a fix which will avoid needing to drop another bunch of $ on the ASI Air Plus so I thought I'd share. I bought a Vonets WiFi extender and then because I have two modules connected them to the Vonet's via a cheap ethernet switch. The extender works well with one module and linking to the second with an ethernet cable works a charm. At home I just log into my home WiFi and there are the Pro's if I'm out of range of home WiFi the Vontes creates a mini network that I can use in the field. It does add an extra ethernet cable between my two scopes but I think I can live with that. The crazy thing is even with the scope 6' apart and the Vontes on one the second ASI Air struggles to pick up the network - hence my switch to the cables.
Anyway I thought I'd share because I can't imagine I'm the only one that has been driven nuts by this.
I also have an old Ipad Mini which I use to monitor one scope while I control the other from my phone.
Thanks
John Favalessa avatar
I run 2 rigs with 2 ASIAIR's.  I have 2 wifi extenders at the rigs, each extending my home network.  they are directly cabled to the AIRs with RJ45 cat 5 (don't think that matters).  I didn't have to change any default settings in the AIRs. (it just works).  I join my iPad to my home wifi network and I can see both AIRs when scans.  The top first menu choice in the AIR interface on the iPad at the bottom is "switch device".  (I am testing the beta so don't know if you have this available yet).  Switching devices is easy but the screens do not immediately update the picture showing but the guiding immediately updates.  hope this helps.  I like the idea of having a hub out at the extender so I can run both AIRs with one extender…I'll give it a try one of these days.  -john
John Noble avatar
Thanks John I did buy two extenders then sent one back to try and keep things simpler. Your way works just as well!
The switching between cameras is a little cumbersome. I hit switch select the ASI Air Pro then it spins for a few seconds and comes back with the same connect screen so I select the ASI Air again and this time we are in! Not too bad considering it's all on an I Phone. That's why I decided to dig out the old IPad and just use that to monitor one of the rigs…..
Mike Lockwood avatar
John Noble:
Thanks
thank you John for this info.  I purchased a Vonets extender from the get go shortly after purchasing the Pro last year. Works well with my home network, but at times I have to enter the IP address....seems to always happen when it's cold as H*ll outside .
May I ask for you to post up an image of your setup .....I'm more of a visual type of guy.
thank you in advance
John Noble avatar
Mike
Here you go. I’ve attached the Ethernet switch and the Vonets to the dovetail with Velcro. The Vonets is powered by the asi air, then plugs into the switch. I then run a cable from the switch to the asi air. There is a second cable not shown that goes to my second rig.
The switch also needs a 5 V power supply which I take from my AC strip.
Of course the switch doesn’t have to be on the scope it could be anywhere it just seemed more compact to me!
Hope that helps.
john
very nice idea!  love the cable management.  I recently purchased the Air Plus.  I like some of the features, but not worth it if just for an upgrade.  I the wifi is much stronger; the power management is better; and no more SD card; the eMMC memory is very fast.   I now have an extra AIR Pro which I'll probably sell.
Thank you sir - very well done. I can understand the setup much easier now ( hard to teach old dawgs new tricks smile ).
So - then you connect the second cable to your second rig and all works well ? Brilliant idea !!
Clear Skies smile
Howard Richard avatar
I have a TP-Link AC750 Wi-Fi travel router. I set it up as a range extender. It runs on USB power connected to the Goal Zero power supply. No cables to the ASIair.
Station Mode with the ASIAIR Plus
I usually leave my ASIAIR Plus in station mode. What I am unsure of, and no manual explains this, but is it best to connect my Android tablet that controls the ASIAIR Plus to the ASIAIR itself or is it best to connect the tablet to my home Wi-Fi rout...
Station mode connectivity issues directly match your ASIAIR Plus station mode problems.
Nov 29, 2023
Two Things I Don't Understand About the ASIAIR Plus
1. When I have ASIAIR in station mode, where do I set my Android connection to: My Wi-Fi or the ASIAIR, or does it not matter? It seems to work either way, but I;'m trying to see which will get me the strongest signal when I am indoors. 2. When I...
Addresses station mode Android connection setup, your exact current frustration point.
Nov 9, 2023
Exposure Failure on ASIAIR Plus
Im curious what equipment people are powering through their ASIAIR? I bought an ASIAIR Plus and set it up with my AM5/2600MC Pro and 270mm guide camera. I was getting Exposure failure messages on ASIAIR and I could here the fan knocking on and off (i...
Discusses ASIAIR Plus equipment setup and potential exposure/connectivity issues.
Aug 6, 2023
