"Hi everyone,
I'm planning to 3D print a custom base to mount a Baader Diamond Steeltrack on my Sky-Watcher 254/1000 Quattro (10") Newtonian. To make sure the design is perfect and avoid any flexure or tilt, I need to verify the exact dimensions.I have my setup in a hosting so i need some measurements before installing
If anyone has this setup or a compatible base, could you please provide the following measurements?
Screw Hole Pattern: The exact distance (center-to-center) between the 4 mounting screws (e.g., 85mm x 85mm).
Flange/Dovetail Diameter: The diameter of the circular part where the Steeltrack body actually sits and is clamped.
Measurements of the dovetail or adapter.
If you have a 3D file (STL/STEP) or a technical drawing, that would be even better!
I am using an ASI2600, so rigidity is my main concern. Thanks in advance for your help!
Clear skies!"
