Phi avatar
Good Morning
I’m looking for a bit of advice.
A colleague of mine gifted me the following setup:
Mount & Core Platform
  • Sky-Watcher EQ6-R Pro
Imaging Telescope
  • Starwave 80ED-R ED Doublet Refractor
Reducers / Optics:
  • Lightwave 0.8× Reducer
  • Lightwave 0.6× Reducer
Cameras
Main Imaging Camera:
  • Altair Hypercam 183C PRO (colour)
Guide Camera:
  • Altair GPCAM2 130 Mono
Guiding & Alignment
  • Altair MG32 Mini Guide Scope
Control & Software Plan (this bit I bought myself at his recommendation)
  • MeLE Quieter 4C N100
  • Software stack:
    • N.I.N.A.
    • PHD2
My questions is really what am i missing?
Any help that can be provided would be really appreciated
Below are some photos of the stuff I have
Cheers
Phil
📷 WhatsApp Image 2026-04-06 at 11.16.50.jpegWhatsApp Image 2026-04-06 at 11.16.50.jpeg📷 WhatsApp Image 2026-04-06 at 11.16.50 (1).jpegWhatsApp Image 2026-04-06 at 11.16.50 (1).jpeg
Helpful Respectful Engaging
That’s an amazing gift!
Mounting the main scope is easy. The mounting rail is already attached to the tube. Once you get the mount setup, the tube rail slots onto the top of the mount, secure by turning the two large black knobs.
That bracket will work for mounting the guide scope but You’ll eventually want something more secure.
Since you’re new to all this I would advise taking it slow and learning step by step and please do it during the day until you learn your way around.
There are tons of videos on YouTube so it’s time to start learning. The curve will be steep as astrophotography is a complex undertaking. You’ll get there, just take your time.
Two last things. You don’t have to mount the mini-pc to the scope. It will be perfectly happy attached to a mount leg or even on a table next to the scope. That’s how I do it.
You didn’t mention any software to drive the mount. I would suggest Green Swamp Server for that task.
On power, you basically need 12V DC. There are power boxes on the market that are designed just for this sort of thing. If you are going to be portable that’s what you’ll need. If it’s just your backyard then line to 12V power adapters will be fine. Just make sure you have a 6 amp supply or better for the mount.
Well written Helpful Respectful Engaging
Shane Mansell avatar
Good luck Phil! It looks like Tony gave you the advice you need on your questions. I just wanted to compliment you on your choice of colleagues! :)
Phi avatar
Shane Mansell · Apr 6, 2026, 03:39 PM
Thanks. It really was a generous gift from a colleague.
He isnt even a permanent member of staff, hes a contractor, we just have this shared passion. Hes been very patient with me as hes gotten this all sorted.
Its funny, another one of his colleagues joked that its probably a split of him wanted to do it and his wife saying he cant get anymore gear until he gets rid of some. Which if that is true its equal parts hilarious and lovely that he thought of me to give it to.
Respectful Supportive
Phi avatar
Tony Gondola · Apr 6, 2026, 03:09 PM
This is really helpful thank you.
I’m going to take it in stages for sure. All pretty much during the day so i can see what i’m doing.
The bit i’m really stuck on is actually powering the mount. Do i need something like this? https://www.firstlightoptics.com/10micron-mount-accessories/10micron_2457577A.html?gad_source=1&gad_campaignid=20038846920&gbraid=0AAAAApFAqdy3LEG83ua4n5NR2mXfaR_MC&gclid=CjwKCAjw1tLOBhAMEiwAiPkRHq2vNM3MQ_kfCvikpHJLb2_3hKppkPV9QOs0GOOZhVNCwSiJA7FPxhoCvzQQAvD_BwE
And this? https://www.amazon.co.uk/220V-12V-Adapter-72W-Refrigerator-Black/dp/B0FHK21ZYP/ref=sr_1_1?crid=1C0S1Y30AU5QX&dib=eyJ2IjoiMSJ9.VYwvM5eDCnThKLkG6ILunyscEool98TOj1nUJ2oB4aYZsK7PYzCmLz7mPvl4hMruRuO42ytdA25dqCHObZ2IHyCr8E7hs2S8NtFwPd2KsX2jeNRKRkw3BVK-UJEi0JyLNUwNfqqg8Cib9g3xPVoUICSLqKNuXHwevlrd0ZXNHRlqQOlzfIGgHSicw8cxpj-FNfryPTxau_WdYl2CPNv-UgEkeGntq27TX181iz1lR-t7y9C5mZlTy3Cua81Aj1q1IJ2jofN6gQ6JElsGTHOrKHt3xJ0_AyyUgyhavUzxSM0.nnEP_qJPAlkBadQdZVT4V0kQQ1HcBt9a-iQGGN2tdeI&dib_tag=se&keywords=uk%2Bplug%2Bcigarette%2B6amp&qid=1775556646&s=electronics&sprefix=uk%2Bplug%2Bcigarette%2B6am%2Celectronics%2C236&sr=1-1&th=1
The cigarette lighter attachment really puts me off.
I’ll look at some tutorials as well thanks :)
Respectful
Brian Puhl avatar
I would very highly advise against that finder bracket. For a guide scope ideally you want two points of attachment (with separation). Usually this means mounting it to a dovetail and then mounting it to your scope. Without it, you will encounter flexure between the guide scope and the main scope, leading to unexplainable trailing in your exposures. It could be caused by temperature differences in the metal, or just the weight of a cable, shifting. Stability is key here.
Well written Helpful Respectful Engaging Supportive
Phi avatar
Brian Puhl · Apr 7, 2026, 11:08 AM
Thank you Brian. What would you recommend?
Phi avatar
📷 1000045397.jpg1000045397.jpgjust wanted to say I've been brave enough to put it together :D
Brian Puhl avatar
Phil Ward · Apr 7, 2026, 11:54 AM
Doesn’t have to be anything fancy, but the top of your scope rings will have holes to mount another rail or dovetail. Find one that fits your scope, and mount some basic rings. Personally I run losmandy D plates on the top and bottom of all my scopes. Gives me lots of surface to mount the miniPC and hubs, etc. I don’t run guide scopes anymore but this is where I’d put them.
Basic rings like this, size them accordingly.
To make things easier, you can get a basic vixen rail to mount the rings to, then mount the whole thing to the losmandy, but it’s a bit overkill if you don’t have to.
JTSAN avatar
When I first started using my EQ6-Ri I had an issue where the light on the mount would start flashing. The problem was the voltage to the mount. The Sky-Watcher spec indicates a maximum voltage of 16 volts. I had been using a 12V supply but decided to switch to a higher-voltage supply and the issue went away. If your mount stars flashing when the mount is moving to a target, you should upgrade the supply voltage to it. Most inexpensive 12V supplies drop their voltage to 11 volts or less load. FWIW, here is what I purchased. It was a 15V 4A supply and the mount has been working flawlessly for the past 3 years.
https://www.amazon.com/dp/B083LX7CHV?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_5
JTSAN · Apr 7, 2026, 02:25 PM
The important part of this is the power supply needs to supply enough amps. I’ve never had a problem with my 12V, 20 amp supply. I would not recommend a higher voltage supply. Get 12V but make sure the amperage is high enough.
Well written Respectful Concise
JTSAN avatar
Tony:
My spec manual says i can use 16v. whichvis why i chose a 15v 4A supply to solve the problem. I’m guessing a 12c 20A supply will do the same, but I’m also guessing a 20A supply is a lot or expensive. I guess whatever delivers 12-16 volts at 3A will work. I recently added a 12v, !0A supply to another mount and telescope I am building and that supplies enough power to all my add-ons.
I think the ideal voltage for an EQ6 is 13.8V, 5 amps. The acceptable range is 12v to 16v. As long as your power supply provides a voltage in that range and can deliver up to 5 amps you shouldn’t have any problems. The reason for my comment is I’ve seen a lot of people have problems with electronics because they are providing the correct voltage but not enough amperage. It’s a common mistake.
Well written Helpful Respectful Concise Supportive
Phi avatar
Hadi Zaheer avatar
Hi Phil
I’m personally using something like this with a power source like this to power mine and find it works quite well.
Phil Ward · Apr 11, 2026, 11:00 AM
@Tony Gondola @JTSAN @Brian Puhl @Shane Mansell
hi guys
Sorry i dunno if i was clear enough in my post.
As far as i can tell the only power lead that will work with this mount is this:
https://www.firstlightoptics.com/astronomy-cables-leads-accessories/lynx-astro-silicone-power-cable-for-sky-watcher-az-eq5-az-eq6-eq6-r-eq8-r-mounts.html
Is that right?
Or would something like this work?
https://www.ebay.co.uk/itm/297962720710?_skw=EQ6-R+Pro+power+supply&itmmeta=01KNY3ENBC7DG95EP717GNE54V&hash=item455ff64dc6:g:dfoAAOSwVXNfSusw&itmprp=enc%3AAQALAAAA0GfYFPkwiKCW4ZNSs2u11xBsAZbDVeacLoYYSECKwiDchBp2OGoHdMGNyVxv0C7vhwNY0yr4S%2FY64Q04cBnGEa6%2Fm9Z8sUBB%2FppamWFtYSxoXuvMF9MJDNgeVBps07DTOgExoIjRATY8Zfw3aPej74QpEGQBzsUVzI%2F7pC9imp9rk7WYr%2B1gioGb4%2FO1X6rBvFCfk133C%2Fs6QPdEWo%2Bn%2FS5MBSS9UE0HOhCJLicxQ0lo95eYrWcrQbnLoLBQl9gyj2n7Iv1zuqRKOaOzwzXOwy4%3D%7Ctkp%3ABk9SR-7VusOvZw
I think they both will work. You know, when I got mine I didn’t realize that all it had was a ciggy lighter adapter. I really wanted to get out that night so I cut off the adapter and joined the wires from a 12V supply I had been using with another mount. Just make sure you get the polarity right.
Phi avatar
Hadi Zaheer · Apr 11, 2026, 11:53 AM
Hi Phil
This is exactly what i need :D thank you
Phi avatar
Tony Gondola · Apr 11, 2026, 01:06 PM
hi guys
Is that right?
Hah thats some dedication. I’d be too scared to do that. I’ll get the one that Hadi has recommended as that seems to be the best option
Hadi Zaheer avatar
Phil Ward · Apr 11, 2026, 02:22 PM
Hi Phil
Just for reference, I've personally got a 12v 5A power supply rather than the one I linked. The 13.8v 4A one I linked seems to be a new one that's replaced those ones at FLO. Alternatively I’ve recently been grabbing the 12v 10A ones that Pegasus astro do which are working well with the rest of my gear.
I'm still relatively new to all this so hopefully someone more experienced might be able to chime in if there's potential for issues with that particular combination of adapter/power supply :)
Dale Ghent avatar
No mention of which ASCOM driver you’re going to use for the EQ6. Your choices are:
  1. GSS (Green Swamp Sever)
  2. EQMOD
  3. Sky-Watcher’s own SynScan app+driver
Those are listed in my own order of preference. If you choose to go with EQMOD, please review the configuration guide for it in the NINA documentation. I don’t actually use any of these drivers as I don’t own a Sky-Watcher/Synta mount. However that’s what I’ve come to abide by after years of doing NINA support. GSS and EQMOD are both fine, provided EQMOD is correctly configured.
Phi avatar
Dale Ghent · Apr 14, 2026, 05:49 AM
  2. EQMOD
What do these tools do?
I’m currently going to be running NINA and PHD2. Is there something additional i need?
Hadi Zaheer avatar
It's the way you get your mount to communicate with Nina. I would second the green swamp server drivers as well!
Phi avatar
Hadi Zaheer · Apr 14, 2026, 12:55 PM
Cool thank you
Phi avatar
📷 image.pngimage.png@Tony Gondola @Shane Mansell @Brian Puhl @JTSAN @Hadi Zaheer @Dale Ghent
I just wanted to say a massive thank you to you all for helping me get to this point with the equipment.
I think i’m there now in terms of what i need physically, cabling and whatnot isnt plugged in yet as i wanna do a dry run of just getting the various components to talk to each other
Dale Ghent avatar
Great, glad you’ve gotten to this point.
One thing to note, and this is a common thing I see with the Sky-Watcher mounts like the EQ6, is a habit to use minimal counterweights to balance the RA axis, where one ends up with a heavy counterweight at the very extent of the shaft. This is a recipe for post-slew disturbances that require increased settle time. More counterweights, moved higher up the shaft, minimize the post-slew vibrating that a large weight at the end of a skinny cw shaft will induce.
