John Nelson avatar
I have been having a problem ever since I started plate solving in NINA and I cannot figure out where the cause lies, its super odd too. When I plug in the target and hit slew & center, on its first attempt it goes way off track. But I noticed that it goes to where the target will be in about 3-5 hours. So i figured the problem lied in the calendar settings or time, but I had no luck there. However after that initial picture it is super accurate. So I let it go since it does do its job very well after that but I could not image targets low on my horizon since it would image the trees in the way even though that target was well into the sky at that point. Now that I am sending my rig to Star front, I would like to solve this issue. If you guys have any advice please let me know.
Respectful
Quinn Groessl avatar
I don’t really know how to prevent your issue, but in the advanced sequenver add to your sequence a go to alt/az coords and a solve and sync command. It adds half a minute to the beginning of your sequence and can be done before its truly dark anyway so not really any lost imaging time.
If you’re using the simple sequencer, my best advice is to learn the advanced and do what I said above.
I have an Eq6 and don’t see that behavior. What program are you using to control the mount? Are you using the handbox? Are you starting in the proper home position? When the mount syncs in NINA are the numbers close?
John Nelson avatar
Quinn Groessl · Apr 2, 2026, 07:48 PM
I’ve never used advanced before. I figured i would have to in order to efficiently remote from home so maybe ill give it a try beforehand.
John Nelson avatar
Tony Gondola · Apr 2, 2026, 08:08 PM
Everything should be in order, although i havent checked the coordinates of the targets since i dont know them off the top of my head. I will look into that though, thank you.
Spacey avatar
Try double checking the site information for your mount. If you are using EQ-Mod it is this screen but regardless the latitude and longitude need to be set for the actual location of your mount in your software.
John Nelson · Apr 3, 2026 at 06:54 AM
It’s not too difficult to learn. I initially used this guys sequences.
https://youtu.be/Gcekn0lw2IY?si=_aJ0jR69vU5UOTra
Instructions to get his sequences are in the video description and I believe he shows how to get them in the video. He’s inactive now, so the sequences are a bit older, but they still work great. Eventually you kind of learn how to use them and modify them to your liking.
Supportive
That’s a good recommendation, that’s who I learned from. The advanced sequencer really isn’t difficult once you get a grip on the logic and it’s extremely powerful. I’m not sure what you’re using for mount control but I highly recommend Green Swamp Server.
Spacey avatar
You can handle the advanced sequencer. It is far easier than your initial impression. It is only the interface that takes a little while to get used to.
I use EQ-mod as it allows me to control 2 rigs through one PC. GSS is not capable of doing so. Nothing is simpler than EQ-mod imo.
Spacey · Apr 3, 2026, 02:26 PM
The OP is trying to get just one rig to work correctly. I’m suggesting GSS, assuming he’s not already using it, as a possible solution to the problem.
John Nelson avatar
Tony Gondola · Apr 4, 2026 at 09:38 PM
When i send out everything to texas i was planning on putting sharpcap on there as well for the occasional moon photography. Maybe ill slid in gss and give it a try. My only question is i dont see how that will solve this oddly specific issue im having.
We really don’t have enough info to say that it will or won’t. I can say that GSS is a much more modern bit of software and was built from the ground up to support Skywatcher mounts so it’s worth a try. Not sure how you’ll be able to reconfigure for lunar/planetary remotely as this normally requires reconfiguring the image train with a Barlow. I certainly would not send any rig to a remote facility until it’s working absolutely correctly.
Well written Concise
John Nelson avatar
Tony Gondola · Apr 5, 2026 at 01:29 AM
I would image the moon with what i have and just record the video at the appropriate exposure and gain in sharpcap, i did it for the lunar eclipse so i know it will work. It occurred to me that i didn’t thoroughly explain my process. Before i image anything i go to the framing tab in nina and type in the designation required, then once i hit slew and center i would setup the sequence in the legacy sequencer. Thats the beginning process, super simple and easy to get into a routine. Im sure ill figure out advanced sequencer or even gss, but i slew and center separate to the actual sequence, is that a problem?
You can work that way if that’s what you’re comfortable with. That really dosen’t address you’re original problem of your firstl slew being wildly off. I’m assuming from your last post that you are using eqmod as your mount control software? I’m also assuming that you’re not using the hand controller anywhere in the process??
John Nelson avatar
Tony Gondola · Apr 5, 2026, 03:52 AM
no not anymore, just eqmod.
Assuming you are powering up in the correct polar home position (tube up, counterweight down) then all I can think of is there’s a setting in eqmod that causing the issue. That’s why I suggested trying GSS.
John Nelson avatar
Tony Gondola · Apr 5, 2026, 05:57 PM
Okay I can give it a try here in the near future, I just have to wait for the weather to play nice.
Markus Gorski avatar
Hello, I had a similar problem. My mount was lagging behind by about 45 minutes.
The solution was: A minus sign ("-") had crept into the longitude coordinates in N.I.N.A. After deleting this minus sign, the alignment was correct.
Best regards, Markus
alpheratz06 avatar
John Nelson · Apr 2, 2026, 07:03 PM
IMHA, any decent mount, properly aligned, with correct date, time and location, should deliver a go to with an error less or much less than a couple of degrees , strating from CWD position.
Personally, I would like to investigate to zero-in the root cause, because this is totally abnormal. And same thought as many people here, I wouldn’t deport a mount in a remote location with a potential timebomb in it.
John Nelson avatar
alpheratz06 · Apr 12, 2026, 04:26 PM
Thats the crazy part, its not even a ticking time bomb. To me its more of a inconvenience to me than anything else since all that issue does is prevent me from shooting targets low on the horizon like the helix nebula or thors helmet. Outside of that, after its first slew its completely accurate. The only reason I am asking is because I know there will be new low horizon targets for me to shoot in Texas compared to where I am at in Maryland. I also imagine its nice to send a rig with no issues to begin with across the country for you to use.
Its your choice but most would agree that it’s a must to have a rig with no issues before sending it off for remote installation.
John Nelson avatar
Tony Gondola · Apr 12, 2026 at 07:40 PM
I definitely do agree which is why i put this out there. Its just annoying how hard it is to diagnose.
If you haven’t done it yet I would certainly give Green Swamp Server a try it’s free and it might help you to nail this down. Just get it going by itself, no NINA or anything, just GSS. Do a basic setup, define the home position and all that. For a test, input coordinates directly into GSS and try a slew.
Slew rate does not make sense
Hi, I have a problem where NINA (or possibly SynScan Pro or the mount) is slewing way faster in the RA axis than it thinks it is. This leads to the mount overshooting substantially and I have no idea how to fix this. The following is what I can see:P...
NINA slew accuracy issue matches author's initial off-target slew problem.
Oct 13, 2025
DST with StellaVita and Skywatcher mount.
Hello, I am having issues some issues with meridian flip not working and I believe it has to do with the mount settings. In my SV I have this in the mount information. We’re in DST time currently in Canada which is why there is a 1 hour difference be...
Time/settings issues with mounts similar to author's potential calendar problem.
Sep 12, 2025
