Filter Wheel Questions
2 replies95 views
Alan Brunelle avatar
Hi All,
As a RASA user who never used, never could use, a filter wheel, I have a couple questions on their use.  I will be wanting to employ a filter wheel on my imaging Newtonian.  It is a 12 inch, f4 unit.  It will have a 100mm secondary when imaging.
I intend to use both a 1.25" format camera (most often) and likely a C-sized sensor CMOS camera (less often) with the setup.  I really do not expect that I will be doing a lot of narrow band imaging, but may add H-alpha data to RGB on occasion.  I have 1.25" filters for the small sensor camera.  I was thinking that maybe the best way to do this would be to install a filter wheel that can handle 2" filters.  But I was hoping to hear from you guys that there are 2 inch to 1.25 inch filter adaptors that can allow use of 1.25" filters in the 2" wheel.  Do the adaptors exist?  And if yes, will it work?  The intent is not to use the 1.25" filters with the C-sized camera.  But using a 2" filter with the 1.25" camera may happen.
Thanks
Alan
Tommy Blomqvist avatar
Thanks Tom!  That seems like a pretty definitive solution.  I clearly am very poor at searching for this stuff on the internet.  I looked a couple of months ago without success.
Well written Respectful
Questions about autofocus with the Rokinon/Samyang 135mm f/2.0 ED UMC
I am looking to expand my travel rig and add this lens for a wider field of capture. In particular I would pair it with my QHY 268MC, C-sized camera. I have noticed a couple of mounting setups, each of which include mounts and connections that pair w...
Discusses C-sized CMOS camera use, relevant to author's planned camera setup.
Aug 7, 2023
Conversion of Astrodon filters from 1.25 to 31mm by Optical Structure, One filter destroyed
Hi, I have converted my filters from 1.25 to 31mm. Is has been done by Optical Structure. One of the filters, SII 3nm, is destroyed. I attach a link to two images that shows the filter itself and a flat that shows that the filter is destroyed. Link t...
Discusses filter wheel usage, relevant to filter conversion and installation issues.
Sep 17, 2020
