Filters for lunar imaging
5 replies359 views
Stuart Taylor avatar
I have been imaging the moon with a ZWO ASI 2600MC Pro with no filters and wonder if there are any filters I could use to improve the image (such as contrast etc)?
Thanks
Moon - 14 Dec 2021
Dale Penkala avatar
Stuart Taylor:
Thanks
Moon - 14 Dec 2021
Hello Stuart,
I kinda posted this question a while back but it was for UV/IR Pass filters which will help you with steadier images.  If your interested here it the link to that post:  https://www.astrobin.com/forum/c/astrophotography/solar-system/what-ir-pass-filter-do-you-use-685nm-or-742nm/
I ended up with the Astromik Pro-Planet UV/IR Pass 642nm. I do not regret it at all, excellent filter!
Your contrast is more controlled in post processing (at least for me) with your tweaking softwares, Gimp, PS, Startools etc.. but if you wanted to use a polarizing filter that would help or even a ND filter might help, however to me are a more visual with the exception of the polarizing filter.
Dale
Supportive
Michael avatar
I visit Luna rarely so I just use my Ha (6nm astronomik) when I do, helps ease some atmospheric pains and also helps contrast I think.  Pretty happy with the outcomes usually.  There are more serious filters to use I believe but I will let the pros answer to those.
Re-read your post (still early here and waking up).  I use the 2600MM so your direction will be a bit different.  CS
Rafał Szwejkowski avatar
2600MC has a UV/IR cut window built-in so using a IR pass filter will not let through any signal.
Dale Penkala avatar
Was unaware of this! Thanks for the info!
Something else that I should have noted in my first post is most people (not all) will shoot the moon with an Mono camera so thats why the IR/pass filter was suggested. Occasionally I’ll shoot it with my main camera for full portrait shots and then convert to grayscale.
I use a 290mm for my Luna work and the Pro-Planet filter.
kurt ragsdale avatar
For my only third time ever shooting photos  last night with a zwo asi482mc camera and ritchey chretein ioptron 6 I used an orion ir filter with and got a lot glare on the moon shots I took last from the ones I took last month of  the moon.  I don't know if the 482 camera i have has a built in ir filter or not but the pics were definitely better than other two nights.
Filter Upgrade Time - Antlia Quad Band?
Hi folks: I've been imaging with from my Bortle 7/8 backyard for a few years now, and I'm starting to wonder if it might be time to consider upgrading the filters I'm using. I use an Optolong L-eXtreme for Ha/OIII targets which I've b...
Discusses filter options for imaging; relevant to filter selection question.
Dec 9, 2023
What purchase would make the biggest 'upgrade' to my set-up?
I currently use: - ZenithStar 61 APO doublet refractor (360 mm focal length; 61 mm aperture; f/5.9) - ZenithStar Flat 61 field flattener - Astro modified (full spectrum) Nikon D5300 DSLR - ASIAIR Plus - ZWO 120 mm guide camera/scope - Star Watcher GT...
General equipment upgrade advice; may include filter recommendations for improvements.
Dec 21, 2023
