APT having issues saving images with Nikon Z6
Imaged with APT 3 replies81 views
Joe Kent avatar
I have been using APT for a while without any major issues but today my camera keeps disconnecting when running a light plan.
It is a Nikon Z6 connecting via usb.
I can sometimes take the first image but it then disconnects when saving the second.
This also happens when I take a single image (not in a plan).
Have checked all cables, etc. but the hardware is exactly the same as last week when I imaged all evening without issue.
Has anyone else experienced anything similar?
Thanks,
Well written Engaging
Ivaylo Stoynov avatar
Hello Joe,
Please make sure that USB power management is disabled. You can find more info how to check it here - https://www.youtube.com/watch?v=vqeXGMl5jYc
Joe Kent avatar
Thanks Ivaylo, worth a try but no that's not it. USB management was already disabled.
Well written
Please send me the log file to the support email address. (Settings->Main->Export Log)
Well written Respectful
CEM70 Disconnects via USB
Hi All, I've been having a recent issue with my CEM70 dropping connections. I have the CEM70 connected via USB to a mini PC. It is powered by a 12v 5a adapter that is plugged into the wall. (via power brick) I've run this same config for abou...
Camera USB disconnection issue with different mount/hardware setup.
Nov 26, 2023
Canon R5, ASIair Mini compatibility problem?
Hello, For the first time, I tried using my Canon R5 with my C8-N reflector on an AVX, with a Orion Deluxe Mini guidescope and asi120mm mini guide camera for guiding, all controlled by ASIair Mini. Here's all the failures I had before I gave up: ...
Camera USB compatibility problem with imaging equipment setup.
Dec 25, 2023
