Hello From Detroit
Multiscope Setup 3 replies73 views
John Noble avatar
Glad to find this group. Just started using a dual set up right now I run two separate rigs on the same target. I would tandem mount but my CGME won’t carry both scopes at least I don’t want to risk it!
I use a WO FLT132 for luminance (mostly Ha) and a Z61 for everything else. I have an ASI62000 MM on the 132 and a ASI2600 MM on the Z61. Gives roughly the same FOV.
For a travel rig I plan to mount the Z61 and a 200 mm lens on the Ioptron GEM28 in tandem.
Clear Skies
CCDMike avatar
Welcome!
This is a nice setup.
In your photo the sky seems covered with trees, though!
I hope this is not the case😉
Always CS
Mike
John Noble avatar
Unfortunately it is but only to the East - I also have a miriad of power and cable lines to deal with. That said I find a way!!!
The trees are getting a hair cut in a couple of weeks!
Mau_Bard avatar
Hi John, and thanks for posting your configuration.
It is interesting the combination of different sensor sizes and directly proportional focal lenghts, in order to get similar FOVs. It's a smart idea!
All the best for 2022 and CS!
Mau
Respectful Supportive
Questions about autofocus with the Rokinon/Samyang 135mm f/2.0 ED UMC
I am looking to expand my travel rig and add this lens for a wider field of capture. In particular I would pair it with my QHY 268MC, C-sized camera. I have noticed a couple of mounting setups, each of which include mounts and connections that pair w...
Travel rig setup with lens and camera similar to author's planned configuration.
Aug 7, 2023
First light with new setup including Mono-Camera and ZWO AM5! Wow, what a difference!!
Hey all, This is my first forum contribution reporting my first light with a new rig I built. I just wanted to say hi and maybe have a conversation. First off, I started astrophotography about two years ago and I had a lot of fun since, so I decided ...
First light report with new rig setup; author building similar dual-scope system.
Nov 30, 2023
Feedback on Chinese manufactured refractors
Hello everyone! I am planning to substantially change my current setup and among the changes is buying a refractor with a 150 - 160mm aperture. My equipment is located in a private observatory in Europe, so American manufactured alternatives are rule...
Refractor telescope discussion relevant to author's WO FLT132 and Z61 scopes.
Sep 12, 2023
